Another Speedo/Tach issue... Help : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 10-11-2012, 10:40 AM   #1
Ant_Farm
Motorcycle: '07 GSXR 600
Brand new to this forum, and in need of some help with my speedo/Tach... I recently removed my mirrors and rode that day with no problems... The next day I get on the road and after 10mins. out, all the numbers on my cluster dissapear and the the tach is stuck at 2k.... any ideas???
Ant_Farm is offline   Reply With Quote
Old 10-11-2012, 12:15 PM   #2
rv6john
Motorcycle: GSXR 750K6, 2007 Kawasaki Z1000, Aprilia SXV550, DR650
Re: Another Speedo/Tach issue... Help
No light either?
Check the plug into the bottom of the instrument cluster and if not the problem, the big plug on the left side of the cluster with the clear/yellow rubber boot.
Sounds like you might have knocked one of them loose.
rv6john is offline   Reply With Quote
Old 10-11-2012, 12:28 PM   #3
Ant_Farm
Cluster lights up, just none of the digital numbers show up, and the tach doesn't move... I've checked the plug at the bottom of the cluster, and everything is fine in that location... so I'm guessing I may have knocked a wire loose in the connector with the rubber boot. Anyone else seen or herd of this problem?
Old 10-11-2012, 02:54 PM   #4
rv6john
One other thing, the cluster seems to do some weird things when the voltage gets low. You might want to put a voltmeter across the battery and check for proper charging voltage.
14.0-15.5 volts at 5000 rpm.
Old 10-30-2012, 10:07 AM   #5
Gixxerator
Gixxerator's Avatar
Motorcycle: GSXR 750 K6
Got the same problem with 750 K6. It is not doing it all the time, speedo and tach disappear for a while and then comes back. The plug into the bottom is fine - no corrosion, all fuses are fine. Speedo and tach doesnt work, the red backlight is there, but no numbers.
Still lookin for solution, greetings from Bulgaria!
Gixxerator is offline   Reply With Quote
Old 10-31-2012, 08:24 PM   #6
chrisb1
My k6 600 does it too-appears like a growing issue-be nice if someone knew why. I have read of sugestions around dirty speed senser units?
chrisb1 is offline   Reply With Quote
Old 11-01-2012, 02:01 AM   #7
ty101
Motorcycle: gsxr750 k7 gsxr1000k8 triumph675 triumph955i
hi guys i also put up a post i found my problem dry plug left fairing but my mate,s 1000 was from harness side.
what we did was lift tank remove airbox ,the wiring from there to the main plug was where the problem seemed to be,took awhile to figure it out the main brown wire seemed to be the problem, when we pushed in the plug in at the end that joins up with cluster harness it would push out the wiring pins in the plug its self. nest to check that way and the harness under tank as well for damaged wiring
Hope this helps
ty101 is offline   Reply With Quote
Old 11-01-2012, 08:46 AM   #8
rv6john
Unfortunately, I don't think it can be a speed sensor. If it was bad, you would get an erroneous or "0" for a speed reading but everything else would work.
I think Ty101 has the idea. You have a bad connection somewhere.
Old 11-01-2012, 02:23 PM   #9
Ant_Farm
Well I finally got enough time to pull my farings off last weekend, and the problem was in the wire harness inside the rubber boot on the left side. The red/blue wire had came loose from the connector. It was an easy fix, so if anyone is still having this problem, I would start there. I also noticed corrosion on the connector so I went ahead and cleaned that up while I was in there. Hope this helps......
Old 11-01-2012, 04:27 PM   #10
rv6john
Glad you found the problem. Thanks for posting up the fix.
Old 11-05-2012, 02:28 AM   #11
chrisb1
I will check the plug out-I recently went thru my harness and put dailactic grease in my connectors. Wil llook for a loose wire or poor contact....
Old 11-05-2012, 01:50 PM   #12
Ant_Farm
Since this has become a common problem, I did a little more research on the issue. In most cases it is the red/blue wire that will lose contact or come undone from the wiring pin.
Sent from my iPhone using Motorcycle.com Free App
Old 11-13-2012, 02:51 PM   #13
chrisb1
Looks like my issue is a loose wire/connection in the main instrument harness plug. Thanks to those who suggested it.
