Bumpin rubber uglies : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 09-23-2012, 09:29 PM   #1
Destructo
Basking in Mediocrity
Destructo's Avatar
Motorcycle: 96 GSXR 750
So It begins another project as I wait for my carbs. I don't know if I should post this in here or if anyone cares but I thought I would document it for CCM or anyone else interested in making a bump starter for those serious race bikes with a total loss electrical system. Any way here is the beginning of it as I have all of the major parts and got the iron to make the frame, all I will need is the wheels.
212cc gas motor, 2 @ 1" bore pillow blocks, kart race slick and rim, 1" live keyed cart axel. 1" cart hub, 41 pitch chain, 5/8" drive sprockets, 1" final drive sprockets, collars, bicycle cable and brake lever for throttle.
The hub didnt fit the rim so I had a machinist buddy turn down the hub boss to fit the inside and drilled new holes for the hubs.
Here is what I'm going for.
The Blackout, Driven 520 Kit & Bits, Spiegler, Yosh RS3, 04 GSXR 1000 Tail, BMC Filter, Paioli stabilizer, Silicon Hoses, FP shorty levers, Shorai
Carbs Officially 1.7RK CCMerated
Destructo is offline   Reply With Quote Quick reply to this message
Old 09-23-2012, 09:57 PM   #2
Chocolate_Rain
I move away from the mic
Chocolate_Rain's Avatar
Motorcycle: 2006 R1 50th
Re: Bumpin rubber uglies
This will be cool to see, post away!
Chocolate_Rain is offline   Reply With Quote Quick reply to this message
Old 09-23-2012, 10:33 PM   #3
ccmhunt
Superbike Champ
ccmhunt's Avatar
Motorcycle: 96 GSXR750 (parts), ZX7/9RR F-USA AMA SBK, 96 ZX7RR STREET, 96 WSBK ECKL ZX7RR
Yay, something for ME!
I never get anything, just for others.
Will follow this eagerly, although it may be awhile before I get to try it on the srad race bike, as i first have to drop the motor on the new bike and go through it.
Will test on the CBR1KRR.
Awaiting your carbs in trade sir...
ccmhunt is online now   Reply With Quote Quick reply to this message
Old 09-23-2012, 10:41 PM   #4
Destructo
Destructo's Avatar
Yes sir was hoping I wasn't going to have any major carb problems so I could test it out on my bike. Might be able to get a friend to bring his bike over to test it before I ship out to make sure there are no problems. This is gonna be pretty cool, I like figuring out how to make stuff.
Old 09-23-2012, 11:29 PM   #5
Destructo
Destructo's Avatar
So I laid out the final drive, hub and block locations, got a baseline in and out for the final drive shaft from the motor and most importantly got the center to center for the frame. Tomorrow I can start on the frame and motor plate and figure out a way to have the pillow blocks adjustable like a swingarm to adjust the chain tension and make a chain guard. This is gonna be a lot more work than I originally thought but I think its gonna turn out tits.
Old 09-23-2012, 11:53 PM   #6
THE SRADIATOR
THE SRADIATOR's Avatar
Motorcycle: THE SRADIATOR
Why not go with a centrifugal clutch on the motor for safety's sake or is there an internal clutch on that motor?
You could also use a swing arm for the drive wheel that may allow for the adjustments you seek while also prefabbing a major part of this whole project?
To take it a step further...you could use the original swing arm pivot as a jack shaft if need be?
THE SRADIATOR is offline   Reply With Quote Quick reply to this message
Old 09-24-2012, 12:03 AM   #7
Destructo
Destructo's Avatar
Because I'm $400 deep into this not counting any of my time and we are trading, I probably would have been better off just paying for the carb job. A centrifugal clutch is another $100, which can be added at a later time if he would like. Thats why I'm going to make a chain guard and test it before I send it out and the thing is only going to operate for maybe 20 sec a pop ?
Old 09-24-2012, 12:15 AM   #8
THE SRADIATOR
One of several under $40.00: http://www.ebay.com/itm/Comet-centri...item257364765e
Old 09-24-2012, 12:26 AM   #9
Destructo
Destructo's Avatar
1" shaft 41 chain 10 teeth http://www.gokartsupply.com/clutches.htm
Old 09-24-2012, 12:33 AM   #10
THE SRADIATOR
The motors shaft is 1 inch?
Old 09-24-2012, 12:48 AM   #11
THE SRADIATOR
Send Chris this:
Old 09-24-2012, 12:55 AM   #12
Destructo
Destructo's Avatar
motor shaft is 5/8" you are correct sir but I can't find the diameter of a a 5/8" clutch to drive off of the motor like it should be so the clutch would hit the motor mount plate the way I have it drawn up. Plus the motor maxes out at 3500 rpm and the clutch only engages at 2300 rpm. I guess I should ask Chris how far he wants to go with this. A clutch would be preferred though as you are saying.
Old 09-24-2012, 12:55 AM   #13
Destructo
Destructo's Avatar
Originally Posted by THE SRADIATOR View Post
Send Chris this:
Now that shit is funny
Old 09-24-2012, 12:58 AM   #14
Destructo
Destructo's Avatar
Aw screw it whats another $40 on a one off bump starter, I just wait to cut the motor mount until I get a clutch.
Old 09-24-2012, 01:05 AM   #15
THE SRADIATOR
I was thinking...
Take an unbraced swing arm, weld a plate on top for the motor, mount it on pillow blocks via the pivot shaft, use the stock adjusters to keep the chain tight, make a screw type adjuster to raise/lower the rear and affix it all to a platform for a low cost, fairly simple bump starter.
You can work out the details but that basic configuration just came to mind.
I'm also wondering if a chain saw motor, with it's internal clutch & compact design, would be the ideal power plant?
Old 09-24-2012, 01:11 AM   #16
THE SRADIATOR
I'm also wondering why you don't use that welding picture as your avatar as its ultra cool and ultra you!
Old 09-24-2012, 01:15 AM   #17
Destructo
Destructo's Avatar
Ya that ship has already sailed, haha. The motor and all the pillow blocks and sprockets and stuff ain't cheap though. I was gonna try to go cheapo and just get a shaft coupling and 1 pillow block and just mount the tire right off the shaft with a pillow block right next to the shaft to take the wobble and load out of it but decided not to.
Old 09-24-2012, 01:16 AM   #18
Destructo
Destructo's Avatar
Cause its bigger as a sig. Im a Union Ironworker so the avatar is me too.
Old 09-24-2012, 01:17 AM   #19
THE SRADIATOR
Go drag bike and cut a hole in the sprocket cover and use a remote starter!
Old 09-24-2012, 01:22 AM   #20
THE SRADIATOR
Well...No matter how I look at it, you got mad skills!
Search this Thread:
Advanced Search
