Adding compression : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Tech Forums > Extreme Performance
Old 09-23-2012, 12:03 AM   #1
Kydan
Adding compression
Hi, I have an 06 600 that im looking to get the most from within reason.
Im a machinist with access to any type of equipment I'd need, and if I wanted to I could bore the cylinders, deck the head for added compression etc. Im not wanting to go that far right now, but what I am interested in is porting the head(if that even needs to be done) and especially using a thinner gasket for higher compression. What I'd like to know is will using a thinner gasket cause interference between valves/piston/head and require further modification?
Will using a TRE with the added compression lead to detonation or will the ECU be able to retard the timing properly regardless of the compression?
If anyone has any suggestions as to other mods I should do while the engine is apart feel free to educate me, Im new here in the gixxer world.
Thanks!
Kydan is offline   Reply With Quote
Old 09-23-2012, 12:31 AM   #2
Re: Adding compression
The ECU wont alter the timing. The bike does not have knock sensors. Bumped compression will almost certainly necessitate race fuel use.
Just bumping up compression by itself will not net much in the way of gains. On a small motor like a 600 the gains are cumulative, meaning no one change nets much at all, but if you do a proper build you can gain a decent percentage of power.
In short... get a proper full supersport/superbike build, or leave it alone and do the normal bolt on stuff (pipe, fuel management, custom tune, filter)
Moto_Joe is offline   Reply With Quote
Old 09-23-2012, 01:24 AM   #3
Travis V
I dont love OG's cack anymore
Travis V's Avatar
Motorcycle: 2005 GSX-R 600 - Future Track Bike
With these bikes, around what compression ratio is the use of race fuel needed?
Most high compression pistons for the 600s is around 13-13.5:1 that I have seen. Will this ping with premium fuel? In a car I know the 12 area is safe but once you get in to the 13 territory you will either have to use higher grade fuels if altering the timing does not do the job.
Travis V is offline   Reply With Quote
Old 09-23-2012, 11:29 AM   #4
Kydan
Thanks for your reply, it opens up some questions for me. I'd read that these bikes would retard timing if they were knocking but then I have done searching in the manual and more online and seem to be finding that there is no knock sensor so if they are retarding timing it would have to be by some other reading in the engine. While were on timing control, what type of timing control does the stock ECU do? Does it take temperature into account?
Now Ill think out loud here about compression and knocking and see if anyone can add in to make this a coherent and usable thought for me:
-The bore and stroke as listed in the manual is 67x42.5 which sweeps a volume of 149.84cc.
-The stock compression ratio is 12.5:1
-To figure the remaining volume at TDC it would be (149.84+Remaining Volume) /Remaining Volume=12.5/1 Do the math and Remaining Volume is equivalent to 13.029cc
The 08+ 600s are running 12.8-12.9:1, Newer R6's are 13.1:1 so we know the higher ratios up to that point will work. To achieve a 12.8:1 ratio from where I am at would need a gasket difference of .0938mm for 13.1:1 would need .1831mm
So, these are VERY minimal differences in gasket thickness effecting a difference in compression from 2.4-4.8%
As far as detonation occurring, correct me if Im wrong, but there is no amount of spark delay that can stop that from happening since its a property of compression ratio, engine temperature, octane and amount of fuel to air mixture, right? Perhaps a spark after a detonation could help complete or accelerate the burn but bottom line arent you either knocking or not knocking?
Does anyone know how much clearance there is stock between the open valves and the piston at TDC?
Old 09-23-2012, 12:28 PM   #5
These are interference motors, meaning there is no clearance. They will hit.
the newer 600s are tuned for premium. Yours is currently tuned for regular gas.
yes, there is an inake air temp sensor that is used for fueling and ignition I am sure.
Old 09-23-2012, 12:37 PM   #6
davidhar
doffle glopagus
davidhar's Avatar
Originally Posted by Kydan View Post
Im a machinist with access to any type of equipment I'd need, and if I wanted to I could bore the cylinders.....
I doubt that. Nikasil bores, not many places can handle that. You may be able to bore the cylinder larger, but I kinda doubt you have the setup to replate and make it actually usable once bored.
Little too much armchair / theoretical machine work going on. What are you going to do If I told you the current piston / valve clearance is 0.22513654 mm? That number is arbitrarily above your numbers, and equally has more pretended accuracy than reality. I mean, down to 0.0001mm? 0.000003"?
IF all you want is a lot of power, get a turbo, nitrous, or a superbike build.
Originally Posted by SPL170db View Post
Just remember....."respect for the bike" is not what keeps you from crashing. You can have all the respect in the world for the bike, but when you do something accidentally and the bike reacts in a way that your skillset doesn't know how to respond to.......that's what ends you up on your head.
My avatar was the bike in the dining room for winter work. It never occurred to me it looks like I have a streetfighter...
davidhar is offline   Reply With Quote
Old 09-23-2012, 01:38 PM   #7
Travis V
Travis V's Avatar
If a slight retarding of timing does not effectively remove the pinging then you will need race fuel.
Old 09-23-2012, 01:46 PM   #8
Kydan
Nikasil is a just a special name for a pretty average pvd coating. Nothing special. I can get the inside of the cylinders coated with anything I want even more exotic and durable coatings with lower coefficients of friction. I work for a company that makes parts every day to specifications much more strict than any component on any motorcycle. We can control everything from size down to surface finish. Im one of the main production specialists. So in case you had any doubt this is less than garage tinkering to me. Im used to being doubted though since most people dont even know how their food is made.
The reason Im here asking questions is because I have never personally had one of these engines apart, I dont know at what point the ratios will cause pre-ignition, basically anything I asked about I am ignorant to some degree on, at least enough to seek out people who have experience I dont. If I say I can do something I can do it. If I ask a question its because I dont know.
Interference as in there is zero clearance? Meaning literally any carbon buildup or anything in between the piston and valve will cause the mechanical system to have to deflect to make up the difference? Mechanical systems like these dont last long unless there is a spring mechanism designed to absorb the deflection safely. It seems the would be at least a papers thickness of clearance.
So this means if all I run in my bike is premium which is all I run to start with I should be able to run higher compression safely, correct?
I did a little more reading and found that cam timing has a lot to do with compression ratios and being able to avoid pre-ignition, thats probably a little beyond the scope of a general discussion though to understand even though I'd like to learn more about it.
Thanks for the helpful responses.
Old 09-23-2012, 02:00 PM   #9
You asked about open valves. But yes closed and at TDC of compression there is very very little clearence. So little that a blue printed motor will just "kiss" the head with the pistons. That is a tight built race engine though. Stock engine there is a teeny tiny bit of clearence. Carbon buildup can be a problem. yes. In some areas of the head. When there is any buildup on the surface of the valves it usually is in a small recess on the face though which is not as tight.
I honestly feel like you are trying really hard to get in over your head. This isnt a tecumsa or honda lawnmower engine . It is already a high performance engine, that you are trying to squeeze more performance out of.
Leave it to the pros.
Motomummy.com : D&A Cycles of Macon : Livengood Motorsports
us129photos.com : JRI Shocks : M4 Exhaust : Moto D Racing : Dunlop : SFH : SBS : VHS :
www.GoMotoJoe.com
2012 WERA National Challenge 5th place
WERA Expert #20
Old 09-23-2012, 02:18 PM   #10
Kydan
I was born pro Joe No way for me to get in over my head here. All I need is to figure out which way north is and ill be able to use my roadmap.
I think I have all the torque specs and procedures from the service manual. I have all the tools and years of mechanical experience with which to guide them. If you're one of the pros feel free to tell me what I need to know. I've more than put my time in when it comes to learning the ins and outs of tedious, critical mechanical work, I just haven't specifically done it working on bikes. I know its hard to respect a new person on the scene when you've been there for years and years, but I'm here now and I have a lot behind me.
So with that said, anyone who can answer the questions I ask I will be appreciative toward. And Ill let you know how it goes so if I fail and you want to rub it in you can do that too. Remember, I never said I wanted to bore the cylinders or mill the head, I just said that I could. Mainly I just want to polish up the intake and exhaust ports if they arent already and then install a thinner head gasket if thats even possible without causing interference. If it isnt, Ill probably just skip that whole part until the day comes when I want to increase my displacement and compression in the machine shop.
As I said in the first post, I want to get the most out of my 600 within reason, and that means without removing chips from my engine if possible. Anything like a turbo that would affect my fuel economy or decrease the life of the engine is out also. I dont want anything I cant have available all the time either like nitrous.
Old 09-23-2012, 02:37 PM   #11
Wow.
Ill be done with this after this post. You seem to already have all the answers . There are guys with decades of motorcycle specific engine building experience who I assume can learn from the likes of you
Anything you do, short of power adders, race fuel, or a full supersport build will be mostly pissing in the wind. Especially for street use.
You can put a thinner head gasket, but may need race fuel to do so. The gasket by itself MIGHT give you a hp or three... you wont really even notice it.
The money you spend on the other things would see better results spooning in a 750 or 1k motor
For street use, and even for your average racer, the "normal" mods give more than plenty. Like I said, buy a pipe, a fuel management system, and an air filter. Get a cutsom tune, and ride the damn thing. Thinner gasket will likely net you near nothing other than requiring you to run higher octane fuel all the time. You wont really even feel the difference.
So "the most" out of your 600 "within reason" is as I said. Above that the next step really is a full supersport build to be worthwhile. Anything less is mostly half assing it and pissing away money. The results of each piece of a build dont gain much. But all together they become significant.
www.GoMotoJoe.com
WERA Expert #20
Old 09-23-2012, 03:12 PM   #12
Minibull
Viking Foreign Affairs Attaché
Minibull's Avatar
Motorcycle: 1998 GSXR 750
Wouldn't that mean going and doing many trackdays and riding schools, to actually try and hit the limits first and improve as a rider?
Minibull is online now   Reply With Quote
Old 09-23-2012, 03:23 PM   #13
Kydan
Wow is right
I believe someone said something about the necessity for a cumulative effect for building horsepower in these 600s earlier. To me those two simple things I wanted to do were part of that accumulation.
I dont care exactly what horsepower it will give me, I do know it will help. The fuel management, exhaust, and intake mods are an obvious given that Im already working on.
I never said I was going to gain 50hp from a thinner gasket. Maybe I just want a thinner gasket because I like the idea of having a thinner gasket, all I really want to know on that front is will my valves crash into the pistons but apparently nobody can conclusively answer that question here.
I ask a simple question and it turns into this thing of how I cant possibly cut it working on my own engine. I try to reassure everyone that I could build the engine from chunks of raw material if I wanted to just so we could get past that and back onto the first couple questions I asked and its like "whoa crazy man, Im done with you ha-ha-ha-ha...."
Internet professors are just absurd. Thanks at least for trying to help in your own way.
When I say I want to do something and ask will this or that happen if I try and you don't know, then say you don't know if you want to comment because I dont care if you think its a bad idea without having the evidence to support that its a bad idea.
I didnt start this thread to tell people what I know but since I was immediately drawn into question I told you what I did know. Question is still out there: will the valves crash into the pistons with a thinner gasket, or, how much thinner can I go before the valves crash. And Im not so worried about the knocking now but if you actually know what will happen Im all ears to learn.
Old 09-23-2012, 03:26 PM   #14
Kydan
Yes in terms of riding proficiency, but I was talking about the engine only. Im working on becoming a better rider every day which I can do on any bike with any engine.
Im just a motor enthusiast who likes to have efficient equipment. So for instance if my compression ratio is designed for 87 octane and Im running 92 all the time I want to compensate for that just because I like to be that way.
Old 09-23-2012, 03:30 PM   #15
Minibull
Minibull's Avatar
Raah, words!
Old 09-23-2012, 03:32 PM   #16
I already told you. You can run a thinner head gasket. To do so you will likely need higher octane race fuel (not all race fuel is high octane) on the street to do so. So it is rather pointless, especially since other than the addition of race fuel the thinner gasket will net you almost no gains that are noticeable.
If the gains will be almost none from any one given modification... unless you do MANY of them at once (as in a full engine build) then it is pretty pointless to do so.
But do as you wish. You are the guy who thinks he could build a billet engine better than suzuki
One last time. There are basically three levels here. Maybe four. One is normal mods (as I outlined). Two is supersport engine build. Three would be super bike engine build. And four would be power adders (which you said you dont want).
Anything that falls BETWEEN those levels, are mostly wasted time, effort, and money that will net almost no noticeable gains. What they will require is a bunch of wasted money replacing gaskets and such, and time to do things, that net you nothing by themselves but if you do them all at once will gain you what you want.
What you are wanting to do falls between the normal mods, and a supersport build. They will gain you almost nothing.
If you still dont get what I am saying, so be it.
Your bike. Do as you wish.
www.GoMotoJoe.com
WERA Expert #20
Old 09-23-2012, 04:04 PM   #17
davidhar
doffle glopagus
davidhar's Avatar
I can get the inside of the cylinders coated with anything I want even more exotic and durable coatings with lower coefficients of friction. I work for a company that makes parts every day.....
You just said "machinist", like any other regular grease monkey. Nothing special.
I can send a cylinder or block out to Millennium Technologies or any other coating company too. You said you had the machinery to do it, turns out not so much.
Where you work means nothing, really. I work at a company that makes high precision parts every day as well. So what? Are you trying to say you can waltz into work and shut down the production lines so you can do your private little garage projects? Management is not going to like the OEE after that.
Once you have either seen zero gains, or have trashed the motor with ill guided work, you can ship your motor here. They know what they are doing, and actually do complete builds rather than just a gasket. Along with that gasket, they also CNC port the head, upgrade cams and valve springs. Or lighter pistons, bore, etc on top of that.
Old 09-23-2012, 05:27 PM   #18
Kydan
Thats what Im saying. What kind of "precision" parts do you have anything to do with? What are your tolerances?
I never said or suggested I did coatings, you inferred that.
Actually I dont have to think about that, I know I can but its more work to me than its worth to do that. Its not more work than its worth to do the two things I asked about though which might take me one evening to port/polish(if needed) and one evening for putting it back together. I'd be out the cost of a head gasket and an oil/coolant change, maybe some loctite or some sealant if either is necessary which I have already.
What I've learned from this is when I try to make things simpler in the beginning to save people from going on tangents it actually forces them to go on tangents since nobody can answer the specific questions I ask. They have to say something though even though they dont know how to answer my question. Just cant help it.
Well I have to get you to clarify for me then. First these were supposed to be interference engines, then they were engines with near-zero clearance. What you have said is very very far from conclusive. Unless you can tell me what the minimum allowable operating clearance is and then tell me what the difference is between that and the clearance at stock, you dont know if you can run a thinner gasket without additional mods or not unless you have seen it done somewhere already and you know every step of their process and what parts they used.
Old 09-23-2012, 06:07 PM   #19
It is a common mod, and Yoshimura even sells the damned gasket
Fuck engineers make things far more difficult than they need to be.
When I said it was an interference engine was when you were asking about OPEN valves and timing changes iirc. . Your fault if you spoke incorrectly.
When I said near zero, I mentioned blueprinted engines as well. Stock they are damn close, but not so close as to not be able to use a thinner gasket. But AGAIN I say it will almost certainly require high octane fuel (not just premium) if you get one. For street use it is a ridiculous mod to make on its own since it will gain nearly nothing honestly.
Dude. You are one dense motherfucker.
Let me guess. Engineer? Some of the most dense fuckers I have ever dealt with are almost always engineers. Dumbest smart people on the planet.
That is not to say all engineers are dumb. Just most of the people I deal with who THINK they are smart, but really arent, turn out to be engineers.
I dont claim to be an engineer, a machinest, or a master mechanic
what I am is a guy who has a bunch of years working on them, riding them, tuning them, and being involved in them.
I know what people do, what can be done, what it takes to do it for the most mart, what is worth the money and time to do so, and what is not.
Do I know the finer points of high end engine building? Nope. That is what I pay Livengood Motorsports to do.
But I DO know that the shit you want to do is pointless unless you do it in conjunction with a heap of other things to be able to realize any gains, and not mostly loses in other ways
Have fun.
www.GoMotoJoe.com
WERA Expert #20
Old 09-23-2012, 06:15 PM   #20
Interference engine definition for you ..... so you know what I am talking about when you ask about when the valves are OPEN
An interference engine is a type of 4-stroke internal combustion piston engine. Depending on the design of an engine, piston and valve paths may "interfere" with one another as a result of incorrect timing in their movements. (Such designs are also called "interference head" or "non-freewheeling", and include virtually all diesel engines. Conversely, non-interfering engines, such as the Mazda B engine or Fiat F.I.R.E. engine, are called "free-wheeling" or "non-interference" engines.)
www.GoMotoJoe.com
WERA Expert #20
