» Site Navigation
» Motorcycle Forums
09-21-2012, 12:52 AM
#1
Bike won't rev past 9k
what's up guys. I'm new to the forum. basically i have just bought myself a 07 gsxr 600 and my problem is that the bike won't go over 9k RPM's. it's like that's the top RPM that the bike can reach. any idea idea what is possibly going on???
thnx
09-21-2012, 01:28 AM
#2
I move away from the mic
Motorcycle: 2006 R1 50th
Re: Bike won't rev past 9k
Mileage?
Check valve clearances, check fuel filters, air filter
09-21-2012, 07:39 AM
#3
Stupid. Who's with me?
Motorcycle: Anniversary Edition 600
Without an FI error being indicated, it's probably a fuel delivery problem. Do the fuel pump tests as described in the manual.
09-21-2012, 09:13 AM
#4
Motorcycle: GSXR 750K6, 2007 Kawasaki Z1000, Aprilia SXV550, DR650
What does it do when you get to 9k? Does it shut on/off, stutter, just smoothly lose power?
Does it lose power on the way to 9k or pull strong right up to 9k?
09-21-2012, 10:02 AM
#5
Let's ride!
Kinked fuel line?
09-21-2012, 01:42 PM
#6
09-21-2012, 05:22 PM
#7
Fuel starvation. Almost positive. Now you just need to figure out why. Too little pressure, intake restriction (filter), or otherwise.
09-21-2012, 05:59 PM
#8
Take the bike out for a ride, get back home, and then open the fuel cap (put your ear next to it when you open it) listen for a "whoosh" of air.
09-21-2012, 06:12 PM
#9
Unstable SuperMod
Motorcycle: 92 GSX-R 750R Liquid
Originally Posted by
Chocolate_Rain
And if you have air "whooshing"
then you need to open / clear the vent so you aren't creating a vacuum in the tank.
09-21-2012, 06:15 PM
#10
09-21-2012, 08:28 PM
#11
TheGeek
Sure sounds like a fuel problem to me also.
09-21-2012, 11:04 PM
#12
anyone else smell poop?
Motorcycle: K6-600 track, K9-750 white/silver street.
clogged line/filter or loose connection in the fp relay.
09-22-2012, 02:27 PM
#13
thnx for the replies guys. I think i figured out the problem. The bike is running on the 4 lower injectors. is that a problem with the ecu??
09-22-2012, 03:23 PM
#14
Is there a powercommander or similar on the bike?
09-22-2012, 04:30 PM
#15
rv6john
no sir. no pc
09-22-2012, 06:37 PM
#16
Dopegixxer
that depends. has it thrown FI codes? is there current at the injectors?
09-23-2012, 07:25 AM
#17
Top injectors don't kick in until the higher RPMs
10-28-2012, 04:54 PM
#18
Motorcycle: 2006 GSXR 600, 1997 GSXR 600 SRAD
Could be the TPS.
11-03-2012, 02:02 AM
#19
Motorcycle: BigGar
Check your oil. If it is massively overfilled it would do that. Easy and with a try.
Gar
11-03-2012, 02:03 AM
#20
Motorcycle: BigGar
"Worth" a try...
Gar
Linear Mode
