Srad k1/k2/k3 conversion. : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 09-05-2012, 01:19 PM   #1
Thebikedoctor_
Thebikedoctor_'s Avatar
I'm building srad from scratch but do not want to keep the rear section. I've seen one with the k1 rear. Just wanted to know if there is any adjustments that need to be made or if it bolts right on.
Sent from my iPhone using MO Free
Thebikedoctor_ is offline   Reply With Quote
Old 09-05-2012, 01:22 PM   #2
AdrenalineJunkie559
AdrenalineJunkie559's Avatar
Motorcycle: k1 gsxr 600
If you search in the srad forum I'm pretty you will find a thread already on this topic
Sent from my HTC One X using Motorcycle.com Free App
AdrenalineJunkie559 is offline   Reply With Quote
Old 09-05-2012, 01:32 PM   #3
kbarrow07
Motorcycle: 1999 GSXR 750, K3 750, '09 Hayabusa
Re: Srad k1/k2/k3 conversion.
does not bolt right on it is however quite easy to do, there is cutting and welding of the subframe that is the hardest part freind of mine is doing one and has his all ready to bolt on except for paint, you will need to get a complete subframe, battery tray, plastics and rear sets from the K1-K3 body style, modification of the tank bracket is required as well so it wouldnt be a bad idea to pick one up if you can find it cheap also you will need a riv-nut tool
kbarrow07 is offline   Reply With Quote
Old 09-05-2012, 04:44 PM   #4
Thebikedoctor_
Thank you. So your saying pick up the tank bracket ASAP too? I want it to look like this yeah.
File Type: jpg ImageUploadedByMO Free1346881448.645725.jpg (28.1 KB, 144 views)
Old 09-05-2012, 04:45 PM   #5
Thebikedoctor_
Where's the srad forum? On here? Or another web?
Old 09-05-2012, 04:47 PM   #6
Armi
Superbike Champ
Armi's Avatar
Motorcycle: gsxr 750 srad with a few mods thanks to the members on this site.See signature.
You're in it
Armi is offline   Reply With Quote
Old 09-05-2012, 05:54 PM   #7
cobramadness
Parts Junkie
cobramadness's Avatar
Motorcycle: 07 GSXR 1000
And I've got most these parts. PM me if interested.
Kyle, why does he need new rear sets?
cobramadness is offline   Reply With Quote
Old 09-06-2012, 02:36 AM   #8
Armi
Superbike Champ
Armi's Avatar
For some inspiration....
Old 09-06-2012, 05:47 AM   #9
Thebikedoctor_
I want it to look like this.
File Type: jpg ImageUploadedByMO Free1346928397.661457.jpg (28.1 KB, 118 views)
Old 09-06-2012, 06:14 AM   #10
oshweeken
Yaah I know!
oshweeken's Avatar
Motorcycle: 1999 GSXR 750, 2002 CRF450R, 1974 CZ250, 1996 Yamaha Wavebalster
Why dont you jusy pick up an K1, K2, or K3 instead of tring to fit something that don`t belong! Fix the SRAD sell it and buy whay you want.
oshweeken is offline   Reply With Quote
Old 09-06-2012, 06:32 AM   #11
Minibull
Viking Foreign Affairs Attaché
Minibull's Avatar
Motorcycle: 1998 GSXR 750
I agree, especially when sticking just the new style tail on the bike. Round front, round sides, pointy butt...
But the pic that Armi posted (I seem to recall Hamil posting some up too), it actually looks ok as the newer front matches a bit better plus having the sides the same looks great too...ignoring all the trick bits that are just
Minibull is online now   Reply With Quote
Old 09-06-2012, 10:08 AM   #12
Thebikedoctor_
I'm not a fan of them models however I have a srad in the garden lying about so wanted some fun. I saw one with the rear conversion and thought why not.
Old 09-06-2012, 10:31 AM   #13
hamill12
hamill12's Avatar
Motorcycle: gsxr srad 1000. rd 500 ypvs
If it was me I'd have to go k1 front also to complement the seat unit. Just saying.
hamill12 is offline   Reply With Quote
Old 09-06-2012, 03:33 PM   #14
kbarrow07
i know when i put the k1 rear set on my bike it bolted up but the undertail needed a little bit of trim work for it to mount flush with the rest of the plastic. The srad ones might not angle back as far as the newer ones and be just fine good call i forgot about that
you dont have to have another tank bracket but you have to cut quite a bit off of it and if you ever decide to go back to the factory tail you cant reuse it thats y i said if you can pick one up pretty cheap its not a bad idea in case you get cut happy on yours lol ill try to post some pics of what everything looks like when ready to assemble
also if you read the sticky about the conv there are some things you can do different: depending on how much you cut off the bottom depends how high the tail angles if you wanna go for the moto GP look cut less, and on the top brackets it says to file them down but you can cut them off rotate them 180 degrees so the tabs are on the inside instead of the outside and weld them back on, i will double check everything this weekend and make sure what i am saying is correct and post pics
If it has tits or tires it will give you problems
Old 09-06-2012, 03:36 PM   #15
kbarrow07
i have that front clip conversion kit
Old 09-06-2012, 04:18 PM   #16
cobramadness
Parts Junkie
Ohhh, you are talking about the rear pegs... I'm thinking about the front pegs... couldn't figure that one out, haha
Old 09-09-2012, 08:38 PM   #17
kbarrow07
follow this link the guy who did this is a structural engineer and shows the best way to do it with the subframe still being structurally sound and if you use a hayabusa shock you dont have to cut as much out of the battery tray hope this helps
http://homepage.ntlworld.com/david.n...-tail-swap.htm
Old 09-10-2012, 12:57 AM   #18
TwistedMister
TwistedMister's Avatar
You're in it
lol, why you always gotta kid the new guy?
TwistedMister is online now   Reply With Quote
