R/R and/or Stator Issues- AGAIN : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 08-22-2012, 01:16 AM   #1
Aria
Aria's Avatar
Motorcycle: 2007 GSX-R600
Alright so as most of us know, gsxrs have been having issues with the r/r going bad....
Ive replaced my R/R 3 times now, and am also on my 2nd stator.
The first time I replaced my r/r I didnt do the stator as well... hence the 3rd r/r and 2nd stator.
I replaced the r/r and stator at the same time in January this year. Since then, I have had no problems or glitches! Until a week ago...
I was on the freeway, when the bike cut out on me, then turned back on. This time around I thought it was something different because I fixed the r/r issue.
Basically, I took the tank off, and pump out... found my strainer pretty dirty and filled with metal shavings. I replaced it! put it all back together... (since I thought the strainer was the problem this time around)
Took my bike out for a spin, see if everything was ok... NO! turned off, and back on again. This time, it killed my Lo Beam.
Now I havent even begun to look at ANYTHING... but I can almost bet my fuse for my lo beam is blown.
Question is: Since I have replaced my r/r and stator already, that issue should be done and over with now, right?? Is there something that would cause my r/r and or stator to KEEP going out??
I will be testing both of the units soon to see if they're bad... and replacing them since I have a warranty. But I dont want to be doing this again!
I'll also be looking at my coils, as a couple people have suggested, to see if those are good or not.
Any other suggestions guys?
And PLEASE do not tell me to check my damn kickstand sensor!
Bike is coming up on 40k (k7 600)
I know I need a valve adjustment...
Just cleaned out my air filter, and new NGK Iridium spark plugs. Oil change is needed as well.
Aria is online now   Reply With Quote
Old 08-22-2012, 11:44 AM   #2
Occ
Occ's Avatar
Re: R/R and/or Stator Issues- AGAIN
Did you get one of the improved RRs or have you just been getting stock replacements and have you moved the RR away from the headers?
Occ is offline   Reply With Quote
Old 08-23-2012, 03:28 PM   #3
yellowridr
yellowridr's Avatar
Motorcycle: 2007 gsxr 600
Have you relocated your R/R?
yellowridr is offline   Reply With Quote
Old 08-24-2012, 03:03 AM   #4
kwaka10r
Motorcycle: K1 1000, K7 750
^+1qazillion
You will keep burning it out whilst is is in the stock location.
kwaka10r is offline   Reply With Quote
Old 08-24-2012, 04:35 AM   #5
DemonRR
say my name bish
DemonRR's Avatar
Motorcycle: 2007 GSXR 600 track/some street
Originally Posted by kwaka10r View Post
^+1qazillion
and if you keep using the oem rectifier. get a mosfet one.
DemonRR is offline   Reply With Quote
Old 08-24-2012, 11:36 AM   #6
yellowridr
yellowridr's Avatar
move it so you can get more air flow for it.
Super easy. Takes like 20 minutes.
Old 08-24-2012, 03:33 PM   #7
DemonRR
say my name bish
DemonRR's Avatar
heres a better pic
and if your interested, i make the rectifier relocation brackets as seen in my pic.
Old 08-30-2012, 12:33 AM   #8
Aria
Aria's Avatar
YES!!!!
I did NOT replace it with an OEM r/r
and I did NOT put it back in the same place.
I have MOSFET as the new r/r (which is what Suzuki has been replacing the old bad r/r with since they did the recalls)
I mounted it in the same place as DemonRR
Old 08-30-2012, 12:43 AM   #9
Aria
Aria's Avatar
This is where my R/R is now located.
and the site I bought both my R/R and Stator from is:
http://regulatorrectifier.com/catalog/
Old 10-04-2012, 04:56 PM   #10
Aria
Aria's Avatar
Was NOT my r/r or stator this time around....
Thank goodness
much cheaper and easier to fix this time.
Sry guys!
Old 10-05-2012, 02:03 AM   #11
jay24k
Motorcycle: k6 750
what was wrong with it?
jay24k is offline   Reply With Quote
Old 10-12-2012, 12:15 AM   #12
mannyb600
mannyb600's Avatar
Motorcycle: k6 gsxr 600
what ended up being your problem? im on the same boat at the moment.
mannyb600 is offline   Reply With Quote
Old 10-14-2012, 01:05 AM   #13
NEMES1Sx1st
NEMES1Sx1st's Avatar
Location: CALIFORNIA, LOS ANGELES..ktown. 10 minutes from hugo
Motorcycle: K8 GSX-R 600
another thing that can cause battery drain is a short in the wiring somewhere.. or even a bad ground.
NEMES1Sx1st is offline   Reply With Quote
Old 11-16-2012, 08:54 PM   #14
Aria
Aria's Avatar
My kickstand was loose
It wasn't the sensor, but the actual kickstand itself.
The end of the kickstand that attaches to the bracket on the bike, one of the edges had been ground down pretty bad. So when the kickstand was up, it was super loose. So any bumps, changing gears, or nothing at all, while riding it would cause the kickstand to go down just enough to trigger the sensor.
Easy! and rediculous
Old 11-16-2012, 09:06 PM   #15
rv6john
Motorcycle: GSXR 750K6, 2007 Kawasaki Z1000, Aprilia SXV550, DR650
I remember when you first posted this and I thought "sounds like the kickstand sensor" but you said not to tell you about it so I didn't.
I'm not that smart, just have read a number of symptoms like your's and that was the problem. Even just oiling the kickstand pivot can fix things. (and it is amazing how much better it works
Glad you found the solution.
rv6john is offline   Reply With Quote
Old 11-17-2012, 10:54 AM   #16
Brian2006
Wears Girly Gear
I would just remove the kickstand sensor all together
Brian2006 is offline   Reply With Quote
Old 12-03-2012, 01:46 AM   #17
Aria
Aria's Avatar
Yes, because the last time I had all these same problems and it was my R/R and Stator, when everyone kept telling me it was my kickstand...
This time it flipped on me.
I apologize, it was just after my last experience of no one listening to me, I didn't want to be hastled again.
Like I said as well though, it wasn't the sensor... My sensor is fine.
There's no need to remove it.
It was my ACTUAL kickstand. It needed to be replaced because it was getting to be extremely difficult to put down because of how worn the edges were. As well as it being so loose when it was in the upright position it was hitting my chain... which isn't too good for both the stand and the chain
