Why a choke on an FI bike? gsxr 750 : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > GSX-R600 / GSX-R750 General forum
Old 08-19-2012, 04:10 PM   #1
mjonesjr8
Sorry if that's a dumb question my last 2 bike were FI and did not have a choke.
This is on my 2000 gsxr 750
mjonesjr8 is offline   Reply With Quote Quick reply to this message
Old 08-19-2012, 07:02 PM   #2
Zlow28
16.8@186.1
Zlow28's Avatar
Motorcycle: 2006 GSXR 600
Re: Why a choke on an FI bike? gsxr 750
i dont know much of your year bike, but im guessing its a less advanced fuel injection system. Might not be computer controled and requires a boost of fuel in cold starts. Does it have O2 sensors?? Maybe someone else can chime in
Free bump for ya
Zlow28 is offline   Reply With Quote Quick reply to this message
Old 08-19-2012, 07:06 PM   #3
600k2
not the powers that be ,not even close
Motorcycle: 600k2
Fast idle switch. The new bikes have an automatic fast idle for cold starts. If you crank our fast idle switches way up it becomes cruise control.
600k2 is online now   Reply With Quote Quick reply to this message
Old 08-19-2012, 08:21 PM   #4
Chugs
Lets go racing!
Chugs's Avatar
+2
Chugs is offline   Reply With Quote Quick reply to this message
Old 08-22-2012, 11:08 PM   #5
TwistedMister
TwistedMister's Avatar
yup, 99/00 busas had em too, this was before they came out with the electronic cold idle system, ferget what suzuki calls it but they have been upgrading that ever since
can be used for cruise control...
TwistedMister is offline   Reply With Quote Quick reply to this message
Old 08-26-2012, 12:44 PM   #6
gsxrfanatic123
thers not an 02 sensor then wich is an open loop system.. closed loop system has 02 sensor and gives that info to the ecu makin it run rich. you have to do it manually therefore a choke is needed
gsxrfanatic123 is offline   Reply With Quote Quick reply to this message
Old 10-17-2012, 04:16 PM   #7
New2thegame
Motorcycle: 01 GSXR 750
Please do explain how to make use of said "cruise control" switch ^_^ Do I need to adjust the cable play at all? hahaha
New2thegame is offline   Reply With Quote Quick reply to this message
Old 10-17-2012, 04:20 PM   #8
Not true at all.
The "choke" lever on an fi bike if so equipped does not change fueling at all. Rather it just opens the throttle plates a tiny bit for a higher idle speed.
Later models are still open loop but use auto high idle servos to do the job based on other engine sensors.
Moto_Joe is offline   Reply With Quote Quick reply to this message
Old 10-17-2012, 04:21 PM   #9
Yup. Adjust the cable at the throttle.bodies so that it raises the idle aot more and it will hold speed on highway if you adjust it right
Old 10-17-2012, 06:10 PM   #10
New2thegame
Sweet I'll have to test and see what speed it will hold me at right now. I assume that it's gear dependent as to what speed you'll hold. Time to ride, adjust, rinse and repeat till I find that sweet spot!
Old 10-17-2012, 09:41 PM   #11
I had mine adjusted so that at 60-65 indicated it would hold wide open. That is about 70-75 real speed and worked fine.
Lower gears each will hold at a given speed, but much less useful
Search this Thread:
Advanced Search
