cbr front calipers on 04-05 gxsr rotors : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > GSX-R600 / GSX-R750 General forum > 04-05 GSX-R600/750
Old 08-16-2012, 03:49 PM   #1
che
Motorcycle: Last 2: '00 GSX-R750 (raced, sold), ZX-7R (track, sold)
Has anyone tried a set of cbr front calipers on their 04-05 front end? I'd like to know if they are a direct swap without spacers. The cbr calipers look as though they would fit directly onto the 04-05 300mm rotors without spacers. Can anyone confirm this?
che is offline   Reply With Quote
Old 08-16-2012, 04:30 PM   #2
fastboatster
Motorcycle: 2004 GSX-R 600(sold), 2003 GSXR600 beater bike
Re: cbr front calipers on 04-05 gxsr rotors
you can be a guinea pig and tell us if they fit. they might fit, it's not entirely impossible since most japanese oems receive their parts from the same vendors. not sure about the benefits of the swap, people are saying that suzuki's nissin master cylinders are the weakest link in braking system.
fastboatster is offline   Reply With Quote
Old 08-16-2012, 06:44 PM   #3
d207gp
d207gp's Avatar
Motorcycle: '06 G1K, '08 CBR1000RR
Why would you want to do it? FOLKS THERE IS NOTHING WRONG WITH THE STANDARD TOKICO CALIPERS! If anything, if you experience problems, either clean the caliper pistons, or the MC is at fault.
d207gp is offline   Reply With Quote
Old 08-16-2012, 06:47 PM   #4
wisegunner
wisegunner's Avatar
Motorcycle: CBR1000rr '06(sold), GSXR600 K7
My CBR had the same Tokico calipers and my GSX-R...
wisegunner is offline   Reply With Quote
Old 08-16-2012, 06:57 PM   #5
fastboatster
btw, before 2006 (for 600 and 750) or 05 (for the 1000), front calipers came without brake pad shims, and pistons were and still are aluminum, which probably causes easy brake fluid overheat. but i've heard that m/c is worse and it's quality really varies. just wondering what's the reason for that - i.e., low bore machining tolerances or else, and is it possible to tell if that'd a good m/c or not (when you bought it from the ebay) before wasting time on brake bleeding and and what not.
Old 08-17-2012, 03:53 AM   #6
DemonRR
say my name bish
DemonRR's Avatar
Motorcycle: 2007 GSXR 600 track/some street
i have a set of 04-07 cbr 1000rr calipers if someone needs them. and the brakes on my old bike were freakishly awesome!!!!
DemonRR is offline   Reply With Quote
Old 08-17-2012, 04:47 PM   #7
che
I agree, but I'm building a new front end on a zx7r and I already have a set of 06-07 750 forks. I'm thinking of putting on a set of 300mm rotors on a rim and using the smaller, lighter cbr calipers, which I think will go on without spacers, looking at the short bolt holes on those calipers.
Old 08-17-2012, 05:43 PM   #8
d207gp
d207gp's Avatar
If you're going to switch out calipers, I would personally get the lighter, slightly smaller Sumitomo monoblocks from any late-model R1/R6 with 4-pot radials. I had them for awhile and while they work, keep in mind that the pistons are a little smaller than those originally on the Suzuki.
Old 08-18-2012, 07:00 AM   #9
DemonRR
say my name bish
DemonRR's Avatar
iirc, the 04-05 cbr 1000rr rotors were 310mm
the 06-07 cbr 1000rr rotors are 320mm with spacers. i might be wrong. if i am, the 04/05 rotors are 300. and the 06/07 are 310. i dot remember exactly.
to use 06/07 rotors on the 04/05 bikes, you need to source the spacers. but the calipers are the same.
also, back in the day, the cbr 1000rr brakes were rated as the BEST brakes on any sportbike.
Old 08-18-2012, 08:00 AM   #10
che
I think your first set of numbers are correct: 310mm rotors for the 04-05 and 320mm for the 06-07.
Regarding monoblocks being better than two piece calipers, someone posted a link to a technical discussion. Here it is again:
http://www.stoptech.com/technical-su...s-2pc-calipers
Old 11-04-2012, 01:23 AM   #11
simone.campo
Put 2008 1k cbr on those are monoblock and the inner pistons are larger then sumitomo.
The 04 original calipers have few problems in the inner oil passages JUST open ONE and you Will see Why everybody changes the se calipers.
If you like to keep it need to open the calipers clean and enlarge the oil passages and rebuild the pistons (may be' with race titanium pistons) change the seals and Now you CAN say that the calipers are really working.
Sent from my iPhone using Motorcycle.com Free App
simone.campo is offline   Reply With Quote
