Gearbox woes : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 05-07-2002, 04:45 AM   #1
NotoriousREV
Superbike Racer
Motorcycle: Tizzle Lizzle Rizzle
Gearbox woes
My 97 600 has done about 5000 miles, but my gearbox is becoming troublesome. The last few rides out 1st-->2nd ends up in neutral a lot of the time (usually with a big clunk) and occasionally 2nd-->1st ends up the same. It improved after an oil change, but it still isn't 100% right. All other gears engage OK, but there's some nasty clunks now and then.
The clutch isn't dragging at all and I've adjusted the shift lever around. I've tried fast shufts, slow deliberate shifts, clutching, not clutching and it makes no difference. Any ideas on possible causes? Will it last till winter without a strip down?
NotoriousREV is offline   Reply With Quote
Old 05-07-2002, 08:27 AM   #2
Kennedy
Superbike Racer
Kennedy's Avatar
Motorcycle: 01 1k, 97 Superglide
Re: Gearbox woes
Did you adjust the clutch throw out rod or just the lever?
Sounds like things inside the tranny might be a little bent.
Kennedy is offline   Reply With Quote
Old 05-07-2002, 09:38 AM   #3
imported_jeff
Superbike Champ
Motorcycle: jeff
Re: Gearbox woes
pull the clutch and inspect the shift drum plate...could be the bolt backing out (it's an issue on current generation gsxr's although it can happen on any bike and cause the same problems). other than that, there's not much else you can do short of splitting the cases to inspect the tranny. could be worn detents on the shift drum, or a bent shift fork....
imported_jeff is offline   Reply With Quote
Old 05-07-2002, 10:23 AM   #4
GSXR-Freak
Superbike Champ
GSXR-Freak's Avatar
Motorcycle: 99 GSXR 750
Re: Gearbox woes
I agree with Jeff... [img]images/icons/grin.gif[/img] Check the bolts on the shift drum...
[ 05-07-2002, 08:24 AM: Message edited by: GSXR-Freak ]
GSXR-Freak is offline   Reply With Quote
