Bushing in steering damper... : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 07-10-2012, 09:01 PM   #1
InThEtHiCkEt
Motorcycle: K7 GSXR600
Anyone have this go bad on them? Recently the bars on my k7 600 have been turning very easily in low speed corners so I started checking the steering and forks. I found quite a bit of vertical play on the body of my damper so I attempted to tighten the retaining bolt and found it to be tight. It appears that the bushing that sits inside the mounting flange is shot and is allowing the damper to move quite a bit (1.5" or so). Just wondering if this is a common issue with these?
Thanks.
InThEtHiCkEt is offline   Reply With Quote
Old 07-10-2012, 09:27 PM   #2
Wogger
Douche Nozzle
Wogger's Avatar
Motorcycle: 09 GSX-R 600, 09 DR-Z434SM, 82 CB750F, 05 CRF50F
Re: Bushing in steering damper...
How could the bushing even have 1.5" of free play? That's bigger than the bushing.
The damper is loose on the mount right from the factory.
Wogger is offline   Reply With Quote
Old 07-10-2012, 09:34 PM   #3
InThEtHiCkEt
Apologies for not being clear, the damper body has roughly 1.5" of vertical play with the bolt tight. I believe the cause of the play is the bearing/bushing that the bolt passes through on the mounting flange that connects the damper assembly to the frame.
Old 11-05-2012, 11:08 PM   #4
Rogerdodger007
Rogerdodger007's Avatar
Motorcycle: 2007 GSXR 600
hey man let me know what you found out about this. mine has the same B.S. going on and the rod is now rubbing the air intake when i turn right
Rogerdodger007 is offline   Reply With Quote
Old 11-06-2012, 08:34 AM   #5
rv6john
Motorcycle: GSXR 750K6, 2007 Kawasaki Z1000, Aprilia SXV550, DR650
The bearing in the center of the damper assy. is a heim (self-aligning) type bearing which allows quite a bit of up and down movement but prevents binding when the handlebars are moved side to side. There should be two plastic washers (SEAL,PILLOWBALL 64339-14101) on the top and bottom of the bearing. If those are missing or worn out the play will increase quite a bit.
Look that part number up on any of the online parts fiche sites and it will show you a parts diagram. It is listed under "Steering Stem".
rv6john is offline   Reply With Quote
Old 11-06-2012, 12:38 PM   #6
2movethesoul
2movethesoul's Avatar
I just had replace mine, they were completely gone...
Helped with the play quite a bit!
2movethesoul is offline   Reply With Quote
