Will an 08 motor fit an 07 frame : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 07-10-2012, 12:53 PM   #1
rp94pj
rp94pj's Avatar
Motorcycle: 2007 GSXR-750
I have a K7 750 and was wondering if a K8 750 motor will fit and what I would need to make it work.
Sent from my Galaxy Nexus using Motorcycle.com Free App
rp94pj is online now   Reply With Quote
Old 07-10-2012, 02:11 PM   #2
tomzilla
tomzilla's Avatar
Motorcycle: 06 gsxr 600, 01 hd fxdl, 03 buell blast(for funzies)
I think it fits, but for sure, the ecu connections are different.
sent from toaster. yeah, toaster
tomzilla is online now   Reply With Quote
Old 08-22-2012, 04:44 PM   #3
4BTS12
Motorcycle: 2007 GSXR750
Re: Will an 08 motor fit an 07 frame
It will fit, they are identical motors but there are parts internally that are different. Teh 08 gsxr is the same as an 06 07 minus the subframe is different and fairings. You can transplant the 06-07 fairings on the 08 frame if you swap subframes and vice versa
4BTS12 is offline   Reply With Quote
Old 11-12-2012, 12:50 PM   #4
devin601
I was wondering the same thing. I have an 08 gsxr but cracked my frame. I purchased an 07 frame from my friend and want to make sure everything will fit on it before I start the swapping process. Can you please just verify it will fit before I actually start. Thanks!
devin601 is offline   Reply With Quote
Old 11-19-2012, 02:00 PM   #5
Gobert
I fitted a K8 750 motor into my K6 750 chassis last winter - all you need from the K6 motor are the throttle body rubbers and temperature sender.
Gobert is offline   Reply With Quote
Old 11-22-2012, 01:58 AM   #6
Lozbiker
Motorcycle: GSXR750K7
I am UK based I have a 750 K7. Chain snapped went thru the casings and smashed 1st conrod so replaced engine with an L10 2010 750 slotted straight in. Even using original (07) ECU with a PCM 5 engine better than original! Was told from 06 to 10 all interchangeable.
Lozbiker is offline   Reply With Quote
Old 11-22-2012, 06:49 AM   #7
Roeland.Vlok
Motorcycle: GSXR 750 k6
The Hayens Manual for Gixxer 600 & 750 goes from K6 to K9. Not sure about the later models but the motor should fit the frame.
Roeland.Vlok is offline   Reply With Quote
