Re: Interchanging between 07 and 08 GSXR 750
For anyone wondering the same... I had a friend bring his 08 GSXR 600 over. Everything will work. Front axles are exactly the same, both axles swapped between bikes perfectly. Wheels fit perfect. Only issue was the .5mm thinner rotors on the 08+ makes you spread the pads a little further open to get them over the 06/07 rotors.
the 08+ front wheel is made with a slight outward angle to the lip so it leaves just a fair more room to get the calipers in place.
