srad 600 sprocket selection? : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 06-22-2012, 08:07 PM   #1
TwistedMister
TwistedMister's Avatar
AFAM, Driven, or Renthal rear Alloys, select one...
RK or EK, select one...
gear ratio experiences, best combo, stock is 16/46, a semi tired engine maybe lookin to give it a break,15/47? 14-15/45? just dunno how dramatic one tooth down in the front is going to be? I want the tire as forward in the swing-arm as I can get it to start
best ratio for easy starts but still save whatever top end there is?
my experience is with Vortex alloys and AFAMs, the old Vortex sprockets were junk, they did strengthen them as of late but I still think the AFAM is stronger, never used a Renthal or Driven with the exception of a Renthal on my marchesini/busa never a problem but only did about 4k miles, all steel 530 setup, need some SRAD input for normal to elevated street riding.. thanks
TwistedMister is offline   Reply With Quote Quick reply to this message
Old 06-22-2012, 09:19 PM   #2
THE SRADIATOR
THE SRADIATOR's Avatar
Motorcycle: THE SRADIATOR
Re: srad 600 sprocket selection?
How about a nice RK warranty kit with all steel sprockets?
THE SRADIATOR is offline   Reply With Quote Quick reply to this message
Old 06-22-2012, 11:01 PM   #3
Chocolate_Rain
I move away from the mic
Chocolate_Rain's Avatar
Motorcycle: 2006 R1 50th
15/46 with EK MVXZ Gold chain in 520 pitch, steel front, Driven Alum rear
Chain slack set on the looser side.
It gives the 600 a little more pep down low, but sits higher in the rev's when cruising on the interstate.
Chocolate_Rain is offline   Reply With Quote Quick reply to this message
Old 06-23-2012, 03:44 AM   #4
yourname2221
yourname2221's Avatar
Motorcycle: 2000 600 (motors out 750 going in)
Im swaping my 600 to 750, I have stock set up 16/46. From what I believe its 16/44 on the stock 750? So off the bat Im at +2 out the back, while at it should i replace the front sprocket with a 15 to have -1/+2. I have about 500-600 miles on my current chain and sprockets and they are still in great condition. Also someone mentioned that having two even # sprockets that the chain hits the same spots and can cause uneven wear, is this true? If so it will make more sense for me to get a 15 for the front then.
yourname2221 is offline   Reply With Quote Quick reply to this message
Old 06-24-2012, 04:55 AM   #5
SMOKEU
Motorcycle: 1997 GSXR600
I went from a 16 tooth front to a 15 tooth with a stock rear and it made a small difference. It was worth doing. Bike sits at 6,000RPM at 100kmh (GPS) in 6th gear.
SMOKEU is offline   Reply With Quote Quick reply to this message
Old 06-24-2012, 10:48 AM   #6
TwistedMister
think I'll go 15/44
15/46 = +6.3% torque and -6.3% speed
15/45 = +4.1% torque and -4.1% speed 106 links vs 109,
should bump the stops all the way forward for a minute and drop the needle somewhere around 5.5 @ 100kph/62mph
that way my speedo's off only round 10% plus I'm a lil' stingier when it comes time to buy gas
http://www.sprocketcalculator.com/
did you install a speedo healer or something to correct the speedo?
Old 06-24-2012, 01:44 PM   #7
Armi
Armi's Avatar
Motorcycle: gsxr 750 srad with a few mods thanks to the members on this site.See signature.
I went from standard to a -1+2 on the 600......then changed engines to a 750....what gearing does that equate to on a 750? sorry for stupid question.
Fwiw i have a speedo healer fitted.
Armi is offline   Reply With Quote Quick reply to this message
Old 06-25-2012, 01:20 AM   #8
yourname2221
i believe thats -1 +4 lol
Old 06-25-2012, 02:31 AM   #9
TwistedMister
are you saying when you swapped to the 750 you used the same 15/48 sprocket setup you had on the 600?
or are you saying you now have the stock 750 final drive ratio?
600 16/46
750 16//44
I have heard the transmission ratios for the 750 are different, a 2001 600 has a taller ratio than a 98 750, it appears the 01 600 compensates the internal ratio in the final drive, a taller output with a lower final drive
someone correct me if I'm wrong as I dunno what the correct transmission ratios for a 96-00 600 is..
if you went from a stock 750 16/44 setup and went to a 15/48 you have increased torque by 14.1% and decreased speed by 14.1%
if you used the stock final drive ratios on the 750 I don't think you are very far off the stock 600 final drive as the use of a smaller rear sprocket is compensated by a shorter primary output, however I would assume the 750 does have a slight higher overall final drive gear ratio in terms of wheel revolution simply by considering the 750 has a slightly higher top end speed and red line of 1000rpms less
this is all speculation I don't really know the reality as I don't have a 750, the 750 may have a higher top end speed because it will actually reach red line i 6th gear as my 600 will not, therefore actual speed is like 145 TOPS on my 600
Old 06-25-2012, 02:40 AM   #10
TwistedMister
while were on it I have been considering on my engine build if I can squeek 25 more HP from the build I really would like to alter the transmission ratios
if the 750 has a shorter gearbox and the gears will swap it makes sense to me if I wanted a taller 5th and 6th gear i would use the first 4 gears from the 750 then the 5th and 6th off the 600..
I know what your thinking, that would just give me 4 shorter gears in the beginning and a stock 5th and 6th.. it would
but if I manipulate the final drive ratios to get 1st through 4th the same as a stock 600 (prolly up 1 in front or down 2) that would make 5th and 6th taller than stock and 1 thru 4 about the same as stock
it could also be done on the 750, swap out 5th and 6th from a 600 for an overdrive 5th and 6th, or even just 6th
anyone use this setup?
Old 01-14-2015, 11:39 PM   #11
gixxer600srad
I just recently bought a 97 srad 600 track bike that I am now gonna ride on the street and I am running 8000rpms at 80mph what sprocket sizes could I go with to tune that down quite a bit maybe 4000 to 5000 or so to where it's not straining the engine all the time as much that is in 6th gear by the way before someone says up shift haha
gixxer600srad is offline   Reply With Quote Quick reply to this message
Old 01-15-2015, 08:25 AM   #12
Monolith
"Burn Baby Burn!"
Monolith's Avatar
Motorcycle: 1996 GSX-R750, 2000 GSX-R600
You bumped a 2.5~3 yr old thread....
That being said, this is what you are looking for. Play with the stuff there.
http://www.gearingcommander.com/
Monolith is online now   Reply With Quote Quick reply to this message
Search this Thread:
Advanced Search
