Testing the Fuel Petcock : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 06-20-2012, 12:52 AM   #1
ANDRASTA
Motorcycle: 1990 GSXR 1100
Hi guys,
I just want to hear your methods or even get a solid write up(maybe make a sticky) on testing the fuel petcock?? How to test, what to look for? etc.
I'm rebuilding my carbs and everything and would hate to overlook this part of the fuel system.
Much appreciated.
ANDRASTA is online now   Reply With Quote
Old 06-20-2012, 06:13 AM   #2
tas1100g
Motorcycle: 1986 GSX-R1100 & 1979 GS 850GN
Re: Testing the Fuel Petcock
Pretty basic testing. Put the lever on Pri and fuel should flow out. Set the lever on reserve and fuel should not flow out until you suck on the vacuum nipple. Set the lever in the normal on position and again fuel should not flow out until you suck on the vacuum nipple.
I supposed it would depend on which type of pet cock you have too by this is how it works on mine.
tas1100g is offline   Reply With Quote
Old 06-21-2012, 01:51 PM   #3
jtolo3
the brand new (purchased from suzuki) petcock on my 88 gsxr 750 dribbles fuel even when the vacuum is unplugged. when i pulled the tank to adjust valves i had a big puddle of gas in my garage last week after it sat overnite.
next winter i am going to re-do the fuel lines and add two in-line plastic shutoff valves for lawn tractors to assure flow is off. i bought the two little in-line valves for 10 bucks including shipping--which would have saved me over 150$ if i had just put them in and kept the older petcock. oh well, live and learn.
replacing the o-rings on the floats ultimately solved my fuel leakage problem during riding season, i just want the fuel flow to stop entirely to prevent any accidents during winter storage.
jtolo3 is offline   Reply With Quote
Old 06-21-2012, 03:26 PM   #4
javadog
Yoshimura junkie
javadog's Avatar
Motorcycle: 1986 GSX-R750R, 1986 GSX-R1100, 1989 GSX-R750RR, 1997 GSX-R750, 2001 GSX-R1000, 2001 Bandit 1200S, plus a few others.
During winter storage, you should just completely drain the tank and all of the carb float bowls anyway.
JR
javadog is offline   Reply With Quote
Old 06-22-2012, 09:59 AM   #5
Wag
Constantly in trouble now
Wag's Avatar
Motorcycle: '06 Gixxer 1000, Hayabusa
Wag is offline   Reply With Quote
Old 06-23-2012, 01:30 PM   #6
wicked86gsxr
Motorcycle: (2) 1986 GSXR 1100, 2008 Suzuki DRZ SM, 1987 YSR 50, SDG pitbike, kids dirtbikes
For winter storage I add fuel stabilizer and 100% race fuel. The race fuel has no ethanol so you don't get any water in fuel like the ethanol based gas.
wicked86gsxr is offline   Reply With Quote
Old 11-16-2012, 02:00 PM   #7
pontaic
Motorcycle: gsxr 1000 k9,rxv 550
Hi so what carb does the vacuum nipple plug on to?
Sent from my iPhone using MO Free
pontaic is offline   Reply With Quote
Old 11-16-2012, 02:29 PM   #8
Intguy
Intguy's Avatar
Motorcycle: 1989 GSX-R 7/11, 1992 ZX11, 2000 FLHTC
It's usually #3, but they are all the same.
cheers
Intguy is offline   Reply With Quote
Old 11-17-2012, 06:09 AM   #9
rodriguez
Motorcycle: 86 7/11 86 1100 87 1100 89 750 95 xr650l 86 ATC 125m
Originally Posted by Wag View Post
W....T.....F is that?!
rodriguez is offline   Reply With Quote
Old 11-17-2012, 09:38 AM   #10
Wag
Wag's Avatar
Some jokes should not have to be explained..........
--Wag--
