Brake feel on 2011 GSXR 750... : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Tech Forums > Chassis, Suspension & Tire Setup
Old 06-18-2012, 10:05 AM   #1
robw_39
Motorcycle: 2011 GSXR 750, 2007 YZF-R6
Ok so I just bought a new 2011 GSXR 750… and so far I love the bike… feels good turns good etc… the one thing I hate is the brake feel… I am specifically taking about the lever feel. I pretty much have to pull the lever almost to the throttle before it really starts to break.
Now I have owned a 2010 R1 and currently have a 2007 R6 as my dedicated track bike and the brake lever feel on both of those bikes was amazing… I did upgrade pads and went with steel braided lines but even before doing that the brakes still felt very good.
The only thing I can think that is causing the issue is the master cylinder both the R1 and R6 come stock with a Brembo master… The GSXR has a Nissin and I’m not very familiar with their brake components… this is my first GSXR since my 1994 model lol….
So I guess the question here is do you think swapping the master out will fix the brake level feel issue I am having… I also do plan on getting steel braided lines so would do those at the same time.
Any thoughts… any other 2011 750 owners have the same issue??
Also anyone know if I can just get an R6 used brembo master cylinder and use it on GSXR? If that is possible would probably be the most cost effective way to go…
Thanks
robw_39 is offline   Reply With Quote
Old 06-19-2012, 09:14 AM   #2
robw_39
Re: Brake feel on 2011 GSXR 750...
Well I decided to take a closer look at the front brake issue and figure for the hell of it I would bleed the brakes...
After changing the fluid and bleeding them ensuring that all the air was purged from the lines the brakes feel 90% better can't say they feel as good as my old R1 of R6 but close for sure... good enough for street use anyway.
Next on the list is changing all the fluids and checking all bolts lol... I don't trust the dealership at all… not after leaving with the bike only having about 20lbs of front tire pressure “wouldn’t turn for crap” and now the brakes bleeding issue, I will be going over the bike with a fine tooth comb.
Old 06-19-2012, 12:46 PM   #3
wherewuat
Motorcycle: 2008 Gsxr750
I know your brakes feel better and all, but look into some aftermarket levers. I have ASV levers for my 08 gsxr 750 and they changed the feel of the whole bike. Now it feels just crispy.. even the lever made the brake pulling distance less if that's what ur worried about
wherewuat is offline   Reply With Quote
Old 06-19-2012, 12:50 PM   #4
EAPS
EAPS's Avatar
Motorcycle: L1 GSX-R750
i agree with you on the brake feel, i replaced the levers and did the same as you(bled the brakes) it seems to feel alot better with the new levers
EAPS is offline   Reply With Quote
Old 06-19-2012, 01:06 PM   #5
robw_39
Yeah new levers are on the aftermarket parts menu for sure... That is always something I do. now I can live with they brakes as they sit until I get new levers.
Old 09-25-2012, 10:36 AM   #6
Withoutequal
Withoutequal's Avatar
Motorcycle: 2011 Gsxr 600
I have a 2011 600 and my buddy has a 2012 750, and both of us were disappointed with the lever feel and braking power.... at first. You MUST bed the pads in before you can expect full feel and braking power. The manual states 600 miles before they are bedded. It took me a couple of track days to really feel the difference. Now they are amazing, and I regularly stab people in the corners.
Withoutequal is offline   Reply With Quote
Old 11-02-2012, 09:14 AM   #7
mds2rz
mds2rz's Avatar
Motorcycle: gsxr 750 2011
My stock levers have about a quarter inch of pull before they touch the pads, but it's a really solid comfortable bite once the pads hit the rotors. I love them.
mds2rz is online now   Reply With Quote
Old 11-02-2012, 09:53 AM   #8
Some lever free play is normal and needed.
Using my how to on bleeding brakes the best way I have found (just because you think they are bled right the old school way they likely aren't) has helped a lot of people. It us stickied in the miss and how to section of the site.
Moto_Joe is offline   Reply With Quote
Old 11-02-2012, 12:03 PM   #9
BrandDC
BrandDC's Avatar
Motorcycle: 2010 R1, 2011 GSXR750
Why did you sell the 2010 R1? I have one along with a 2005 R1 and a 2011 GSX-R 750.
BrandDC is offline   Reply With Quote
Old 11-02-2012, 02:41 PM   #10
Motionelco
Motionelco's Avatar
Motorcycle: 2011 gsxr750
I dont have that brake feel you are describing . However I purchased asv levers and I installed stainless Steele brake lines and I absolutely love the brake feel. I recommended going that route.
Sent from my iPhone using Motorcycle.com App
Motionelco is offline   Reply With Quote
Old 12-07-2012, 11:19 PM   #11
SV650R
SV650R's Avatar
Motorcycle: 05 SV650R - 06 SV650 - 06 GSXR750
You need one of these...
Beringer 20.6 x 14 Billet
SV650R is offline   Reply With Quote
Old 05-04-2013, 07:46 AM   #12
douglasjre
He's right about replacing the master cylinder. Some master cylinders on some years of gsx-r's were known for this problem. The piston allows a small amount of air to leak in over time. The longer the bike sits, the more it happens. Some had success with a rebuild kit. I did like by buddy who raced a HP BMW and put a zip tie on the lever with it partially squeezed whenever stored. I knew that if I were going to race WERA I couldn't change out the master with a Brembo. CCS allows this and with my limited racing and problem getting worse I bought a used r6 (Brembo) master off Ebay. There are two different ratios to choose from if you buy new. IIRC the preferred one was a 16x18 but you'd better check on that before you take my word for it. Yes, bleeding the brakes will fix it, for now, but eventually you will grow tired of this as I did. So you may want to use this time wisely to shop around for a good used master cylinder....
douglasjre is offline   Reply With Quote
