Penske vs. Stock : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Tech Forums > Chassis, Suspension & Tire Setup
Old 05-29-2012, 05:53 PM   #1
93goatfucker04
Sphincter Pincher
93goatfucker04's Avatar
Motorcycle: 04 GSX-R 600
Penske vs. Stock
Ok guys, Im doing research so that I can get my forks revalved and all to be set of my weight. The shop Im going to said they can do the stock ones for 325 but they recommend the Penske 20mm kit. They say its the best "bang for your buck". What Im wondering is, what are the real advantages of the Penske over stock. I am doing two trackdays this year(first time on the track) and ride briskly, but no knee dragging or anything on the street. Would I really benefit from the Penske kit over redone stock forks Any and all input is welcome. Keep in mind, I know literally jack shit about suspension
Never rip ass in bibs or racesuits
93goatfucker04 is offline   Reply With Quote
Old 10-04-2012, 08:41 AM   #2
JodyDaniela
JodyDaniela's Avatar
Motorcycle: Street: K4 & K1 600 Track: K4 1000
Re: Penske vs. Stock
Unless you have submitted your weight to Guiness book of world records, I'd set the suspension as is or spend a couple hundred bucks for the right springs front and rear and set the suspension. That's all I'd do for now unless you really want to spend you money.
JodyDaniela is online now   Reply With Quote
Old 10-04-2012, 10:19 AM   #3
Rigid1
Motorcycle: Gsxr 600
Speaking for myself. Just my 2c.
Stock suspension is too restrictive in correct travel comparing to penske/ohlins kits/shocks.
I run 2 identical '07 GSXR600's. one is track bike another dedicated to treet.
I never thought of dragging knees on track or testing the limits of streetbike in ways I do now. What gives me the confidence after 2near-death crashes is knowing that I have a lot in reserve! When it comes ti brakes, tires suspension -I get the best for few reasons. 1- It always changes the feel of a bike for better. 2- It keeps it's value even when you want to sell the bike!
I run Pirellis, Brembo/Accossato M/C 's, stainless lines, HH pads, Ohlins, and never regred it!
Rigid1 is offline   Reply With Quote
Old 10-04-2012, 04:01 PM   #4
DemonRR
say my name bish
DemonRR's Avatar
Motorcycle: 2007 GSXR 600 track/some street
if you do 1 td a yr, dont bother with an aftermarket rear shock. its a waste.
if you ride track, then by all means, score an aftermrket rear shock.
i have an elka tripple clicker w/remote res +high/low speed adjustments and LOVE IT!!!!!!!!!!
DemonRR is offline   Reply With Quote
Old 10-04-2012, 07:07 PM   #5
Chugs
Let's ride!
Chugs's Avatar
+3 ride what you got and get the suspension dialed in.
Chugs is offline   Reply With Quote
Old 10-04-2012, 07:14 PM   #6
Penske 20mm kit?
never even heard of it. AK and GPsuspension 20mm kits I have heard of though. They are basically a stock upgrade. NOt sure what they would be doing to the stock stuff (other than reshimming maybe) but that is not worth the money at all really.
What you probably need if anything is just springs. $200... $100 for front two, and $100 for rear spring, plus money to have them installed, then money to have it all bench dialed so it is balanced for you and ride the damn thing.
Moto_Joe is offline   Reply With Quote
Old 10-05-2012, 12:15 AM   #7
-JK750-
-JK750-'s Avatar
Motorcycle: 01 GSX-R 750
A guy who builds race bikes said, that with stock parts and reshimming you can get pretty good results. I had my front forks reshimmed and new gp-susp comp needles and there is a night and day difference, I already had springs for my weight. So if you are not on the top level of racing and want value for your money, then reshimming is the way to go. Doing it right requires knowledge, so take it to a professional.
-JK750- is online now   Reply With Quote
Old 10-05-2012, 06:10 AM   #8
You can get GPsusp or AK 20mm inserts and needles for the same or less usually, and they work as good or better
Old 10-05-2012, 06:25 AM   #9
-JK750-
-JK750-'s Avatar
Yeah, if you can get them installed for $300 then it's a good deal, but I didn't find any.
Old 10-05-2012, 06:56 AM   #10
I think I paid $350 for my gpsusp kits then whatever I paid for cap extensions
Old 10-05-2012, 03:54 PM   #11
macka
macka's Avatar
Motorcycle: 600race 1000 road
on the money dude revalving stock stuff is a good upgrage there is a significant gain its a must if starting out on a stock suspension. it doesnt matter if you have spent a couple of grand or a couple hundy bucks tires wont last long if its not adjusted right so its comes down to the guy adjusting the suspension on the bike.
dont waste money and tires on fidling around yourself if your having tire problems get the pro's to set it up
macka is offline   Reply With Quote
Old 12-07-2012, 10:46 PM   #12
SV650R
SV650R's Avatar
Motorcycle: 05 SV650R - 06 SV650 - 06 GSXR750
Money spent on Suspension is money well spent...
You can ad 10 horse power on the engine, and that does not do much if you have stock suspension... On the other hand a bike with good suspension can run circles around a bike with 10 more horse power...
Suspension gives you confidence to open the throttle and go faster than you thought you could... Even going on a straight line stock suspension makes your rear tire slip... Goods suspension and sorted geometry is going to make that rear tire bite!!! You crank the throttle and the bike goes...
Going from bone stock suspension to Traxxion AK20 and a Penske Shock, the bike on the streets felt a bit harsh... But, when you open the throttle is like you are riding on glass... You point and the bike goes there no questions asked...
All I can tell you from Personal Experience, If I ever buy a brand new sport bike, I am going to trailer the bike to a race shop, and have them do complete suspension, geometry and tires, BEFORE I RIDE IT!!! (I would also break in the engine on a dyno, replace the stock master cylinder and brake pads.)
Luis
SV650R is offline   Reply With Quote
Old 12-10-2012, 12:51 PM   #13
remusr
remusr's Avatar
Motorcycle: GSXR1K5's street & track, GSXR1100G
For most the best money is usually spent on rider(gear & training, tracktime, practice) then bike(tires then suspension then brakes then engine/trans). Even if you only ride on the street you will massively appreciate suspension work - most important is right springs for your weight and use (smooth track vs road with passenger, oem is typically designed for 140lb rider, no passenger), then rear shock (Ohlins $800-1200, get deals on EBay), then front fork internals(TraxxionDynamics, RaceTech, Ohlins for $1000-1200 installed w/ springs). And get it setup right - sag, preload, fork travel indicator to detect bottoming. Then brakes - first front mastercylinder(Brembo $300+/-), then front calipers&pads(Brembo $1200), then front rotors($600+), lastly rear (stock rear is usually fine unless you use it aggressively for wheelie control).
remusr is offline   Reply With Quote
Old 12-10-2012, 12:57 PM   #14
Originally Posted by remusr View Post
Even if you only ride on the street you will massively appreciate suspension work - most important is right springs for your weight and use (smooth track vs road with passenger, oem is typically designed for 140lb rider, no passenger), then rear shock (Ohlins $800-1200), then front fork internals(TraxxionDynamics, RaceTech, Ohlins for $1000-1200 installed w/ springs). And get it setup right - sags, preload w/ fork travel indicator to ensure you don't bottom out.
Your weight number is way off on modern bikes.
And few people will appreciate full suspension changes on a street bike.
Don't confuse it feeling different with it being better.
The average stock suspension is more than capable of perfectly handling the tiny amount of performance asked of it by an average rider on the track even... let alone the street
Old 12-10-2012, 02:17 PM   #15
remusr
remusr's Avatar
Moto Joe - just checked RaceTech, who list stock spring rates, and you are correct for 2005+ GSXR's, most are 0.9-.98 kg/mm front - ok for 160-180lb rider - much better than the old days; rear are 9-11 so seem in the ballpark. Regarding noticeable, I definitely definitely noticed AK-20 & SU503 vs OEM maintained & setup suspension on GSXR1k5. Definitely. Hugely smoother bump absorption, better feel of road and brakes and tire traction, especially leaned over. Road and especially track. I think almost anyone would.
Old 12-10-2012, 02:20 PM   #16
wisegunner
wisegunner's Avatar
Motorcycle: CBR1000rr '06(sold), GSXR600 K7
Setting suspension yourself is not that hard. My bike felt like crap when I rode it home from the dealer. It was obvious that the previous owner couldn't corner well and really wanted the bike to ride like a 1974 Buick Regal. It probably took me 20 minutes to change the bike completely.
I am lucky that I have set up dirtbikes before and that I have a twin brother that weighs the same amount I do. With his help, I can set up my bike quite well in a short amount of time. There are all kinds of how to videos and articles as well. Of course, You will need a basic understanding of how it works first, for sure.
wisegunner is offline   Reply With Quote
Old 12-21-2012, 01:47 AM   #17
DontLetOff
Just get a neon light kit, an anodized bolt kit and some pointed chrome bar ends. That's all you really need to make it ride great. Don't forget the red helmet mohawk.
If it were me ( and I'm a cheap bastard) I'd get a couple lighter springs for your weight and have them installed. Then pay $40 for a good tuner to set you up with the stock suspension. You'll be amazed. If you start tracking a lot then look into the high dollar stuff. It's a diminishing returns philosophy at this point. It's hard to out ride stock stuff on the street now days ( if set right). I'm running low A/ high B group pace on track with a 100% stock new model GSXR and street tires...and loving it.
I'd listen to Moto Joe.
DontLetOff is offline   Reply With Quote
