Squeaking noise coming from front wheel : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 05-11-2012, 07:26 PM   #1
rp94pj
rp94pj's Avatar
Motorcycle: 2007 GSXR-750
I have an 07 750 with almost 13000 miles and I keep hearing a squeaking noise coming from my front wheel. I only hear it when I'm pulling up to park or driving at slow speeds less than 5 MPH. It sounds like brakes but I'm not using my brakes when I hear it. Any ideas what it might be. Could my bearings be going out on me. Any suggestions or help is greatly appreciated
Sent from my Galaxy Nexus using Motorcycle.com Free App
rp94pj is offline   Reply With Quote Quick reply to this message
Old 05-11-2012, 08:23 PM   #2
drhawkinz
drhawkinz's Avatar
Motorcycle: k6 600 Black/Silver
Re: Squeaking noise coming from front wheel
maybe warped rotors? does it feel like it the front wheel wobbles any at all when you try to brake?
drhawkinz is offline   Reply With Quote Quick reply to this message
Old 05-11-2012, 08:53 PM   #3
rp94pj
rp94pj's Avatar
No there is no wobble at anytime and brakes work fine at all speeds
Old 05-11-2012, 09:04 PM   #4
jjwassel
jjwassel's Avatar
Motorcycle: 2007 Gsx-r600 & 2007 Gsx-r1000
Sounds like bearings. Just grease em up to see.
jjwassel is offline   Reply With Quote Quick reply to this message
Old 05-11-2012, 09:32 PM   #5
rv6john
Motorcycle: GSXR 750K6, 2007 Kawasaki Z1000, Aprilia SXV550, DR650
Does the squeaking noise stop when you apply the front brakes?
rv6john is offline   Reply With Quote Quick reply to this message
Old 05-11-2012, 09:34 PM   #6
MikeDVB
Expert Novice
MikeDVB's Avatar
Motorcycle: '07 GSX-R 600 in Blue/Black
Is it a squeek while you roll, when you go over an uneven surface, when you apply the brakes? There are a lot of things that can squeek but if it's quiet (i.e. you have to listen for it) then I wouldn't particularly worry about it.
If you are concerned, pulling the front wheel isn't that hard assuming you have the right equipment (stand for the front of the bike being the primary).
I know when I replaced my tires I lubed up the axle and front bearings again as they seemed to be getting a bit "dry" and I only had 8k on the clock when I did it.
Mike
Play stupid games, win stupid prizes.
MikeDVB is offline   Reply With Quote Quick reply to this message
Old 12-08-2012, 07:25 PM   #7
JPjp
My bike is doing the same thing. Came home from riding today and was pushing the bike into the garage and it squeals from the front as soon as i stop pushing it the squeal stops.
JPjp is offline   Reply With Quote Quick reply to this message
Old 12-08-2012, 08:14 PM   #8
the front wheel bearings are sealed bearings. They are not designed to be regreased. You cant access the inside of the bearings to do so.
If the wheel bearings are what is causing it, replace them.
It can be brake related though. Even if you arent using them. Clean the calipers, clean the pistons, and make sure the backing plates and judder springs are in place properly. Squeal greese on the pads doesnt hurt either.
Pads can also cause it if they are glazzed and scrubbing on the rotor.
Moto_Joe is offline   Reply With Quote Quick reply to this message
Search this Thread:
Advanced Search
Yamaha Motorcycles Victory Gunner Forum Honda Vultus Forum HD LiveWire Forum Ninja H2 Forum Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
