bike runs rough at low rpm (not herky jerkies) : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 04-21-2012, 10:51 PM   #1
trentongixxer
trentongixxer's Avatar
Motorcycle: k6 600 BnW
Started noticing the bike running rough around idle at lights today. As my ride progressed it got so bad that I stalled out at a light, which I haven't done since my squid days. I noticed that it s sounded really throaty and choppy at low rpm cruising, almost like continuous back firing.. It a would act up a around 3500 rpm in 1st, 4500 rpm in 2ND, but clear up at higher rpm. I got gas from a different station last ride, so bad gas? I put it into dealer mode and got no codes, and tps is perfect. It has slip-on, TRE, and SET valve mod Any ideas?
trentongixxer is offline   Reply With Quote Quick reply to this message
Old 04-22-2012, 01:48 AM   #2
Ironhead401
Team CGR Captain
Ironhead401's Avatar
Re: bike runs rough at low rpm (not herky jerkies)
Spark plugs fouled?
Ironhead401 is offline   Reply With Quote Quick reply to this message
Old 04-22-2012, 09:23 AM   #3
bueas
Les lions Indomptables !
bueas's Avatar
Motorcycle: 2001 GSX-R 1000
Originally Posted by Ironhead401 View Post
Spark plugs fouled?
What he said ...
bueas is offline   Reply With Quote Quick reply to this message
Old 04-22-2012, 12:33 PM   #4
trentongixxer
The plugs are the originals, so I'm probably due. Should I drain the gas as well to eliminate that from the equation? Any good plug recommendations?
Old 04-22-2012, 08:09 PM   #5
Zippysport
Any new brand will do fine. Iridiums, if you want them to last.
Zippysport is offline   Reply With Quote Quick reply to this message
Old 04-23-2012, 01:06 AM   #6
Ironhead401
Team CGR Captain
You could drain the gas out for piece of mind, but I doubt your problem is just bad gas. Hell, I've never gotten bad gas in my 20 years on the road whether in my truck or on my motorcycle.
Old 04-23-2012, 04:00 AM   #7
DemonRR
say my name bish
DemonRR's Avatar
Motorcycle: 2007 GSXR 600 track/some street
bad gas can happen. mor so water in the gas holding tanks after a GOOD rain t the gas station.
an x100 on NGK iridiums. gonnareplace mine this weekend. just need to search for the exact model number so i can order the.
DemonRR is offline   Reply With Quote Quick reply to this message
Old 04-23-2012, 04:56 PM   #8
trentongixxer
Thumbs up Re: bike runs rough at low rpm (not herky jerkies)
Thanks for all of the input. I'm going to order some plugs and hopefully resurrect the beast.
Old 04-28-2012, 03:21 PM   #9
trentongixxer
Well I just put in new plugs and it sounds as bad as it did before. Any other ideas?
Old 04-28-2012, 04:19 PM   #10
Ironhead401
Team CGR Captain
Clogged fuel filter or lines?
Old 04-28-2012, 04:34 PM   #11
jjwassel
jjwassel's Avatar
Motorcycle: 2007 Gsx-r600 & 2007 Gsx-r1000
Definitely check your fuel filter. Also run some injector cleaner just in case your getting bad injection at those specific RPMs. Let us know what you find out.
jjwassel is offline   Reply With Quote Quick reply to this message
Old 04-28-2012, 09:18 PM   #12
trentongixxer
So I pulled my fuel pump apart. The mesh filter was dirty and my bottom collection area had some debris in it. I cleaned both out and reinstalled. Problem remains. I have a sound clip and pics but not sure how to share. Are injectors next logical area? I put my hand on the exhaust and could feel the choppy airleaving it when revving
Old 04-28-2012, 09:25 PM   #13
rv6john
Motorcycle: GSXR 750K6, 2007 Kawasaki Z1000, Aprilia SXV550, DR650
Going by your first post that says the bike does not idle well but performs OK at higher power my first guess would be an intake leak. You might want to check the throttle body syncronization.
Second guess might be an injector that is not closing properly. (not able to meter the really small amount of fuel at idle)
rv6john is offline   Reply With Quote Quick reply to this message
Old 05-04-2012, 05:49 PM   #14
trentongixxer
All day between sales calls I saw guys riding in south Jersey, so I got home from work and decided to get my bike figured out. I drained the rest of my fuel and let my bike burn the miniscule amount left in my pump. I then added 2 cups of gas from my gas can and rode to the gas station. My bike was running well the whole trip. I added injector cleaner and topped off. Ride home was smooth. I guess I know where NOT to get gas now. All that hassle because of bad gas.
Old 05-05-2012, 08:27 AM   #15
rv6john
Glad you got it fixed. I thought someone had suggested bad gas earlier by was mistaken. It is always good to do the simple things first.
Old 05-08-2012, 01:18 PM   #16
motopsycho231
motopsycho231's Avatar
that happened to me recently too. I had bad gas and the plugs went out because of it. Gave me a sputter and random misfire. New plugs, injector cleaner and new gas, good as new. Glad that's all it was. I wondered if my TRE was responsible so I took it off at the same time. never needed it back on and havnt really noticed a difference other then knowing what gear I am in again is nice
motopsycho231 is offline   Reply With Quote Quick reply to this message
Old 05-09-2012, 08:09 PM   #17
trentongixxer
I thought my TRE was the problem so I yanked the fuse but it still acted up. I wonder how much of a difference the TRE makes. I do notice a lot more backfiring while its on.
Search this Thread:
Advanced Search
