HELP needed asap : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 01-21-2012, 10:52 AM   #1
Ger_VXR
HELP needed asap
My 1998 srad 600 is dead.was going down the dual carrigway the other day and my speedometer went off.changed fuse and decided to charge battry.put battry back in next day and nothing happened.put a brand new batrey in this morning and still nothing.no igniton light,no neutral light,no light,absolutely nothing.help needed please.....
Ger_VXR is offline   Reply With Quote
Old 01-21-2012, 10:54 AM   #2
TT750
Motorcycle: 99 750
Re: HELP needed asap
what fuse? did you check the 30 amp main one at the starter relay??
Old 01-21-2012, 10:56 AM   #3
Ger_VXR
Was a 15A.is there one in the starter relay?
Old 01-21-2012, 11:00 AM   #4
TT750
Motorcycle: 99 750
the main fuse... also the green plug under the tank that can cause electrical power loss
Old 01-21-2012, 11:01 AM   #5
Is this thing on?
Is this thing on?'s Avatar
Motorcycle: 2000 gsxr 600 (slightly customed)
That fuse is located next to the rectifier, right? You can check for a ground fault by disconnecting your negative terminal then use a volt meter (one lead to the negative terminal and the other to the main frame of the bike). If you get a voltage reading you have a wire grounding out. Check that fuse first though. Your key will need to be in the On position to test this.
Is this thing on? is offline   Reply With Quote
Old 01-21-2012, 11:05 AM   #6
THE SRADIATOR
Sent Flowers to Algernon
THE SRADIATOR's Avatar
Motorcycle: THE SRADIATOR
It's dead!
Take it out back and bury it!
THE SRADIATOR is online now   Reply With Quote
Old 01-21-2012, 11:05 AM   #7
Is this thing on?
God it must be cold up there right now..... Riding would propably be the last thing I'd be doing if I was in Canada right now.
Old 01-21-2012, 11:06 AM   #8
Is this thing on?
Always the comedian, Sradiator!
Old 01-21-2012, 11:31 AM   #9
Ger_VXR
Cheers TT750.was a 30A fuse blown on the starter relay.never knew about that.Thanx very much
Old 01-21-2012, 11:41 AM   #10
TT750
Motorcycle: 99 750
actually we have had some days hit almost 10 degree c. if i was ward core i would been out lol but work comes first
Old 01-21-2012, 11:54 AM   #11
oshweeken
Yaah I know!
oshweeken's Avatar
Motorcycle: 1999 GSXR 750, 2002 CRF450R, 1974 CZ250, 1996 Yamaha Wavebalster
Hence, why us Canucks are spending so much time on the forum!
oshweeken is offline   Reply With Quote
Old 01-21-2012, 12:35 PM   #12
Is this thing on?
Haha, I hear that! It's like 79 degrees down here today..... I rode the bike to work. Florida is great..... Except when the Quebecians show up. Then its just mass traffic concussion.....
Old 01-21-2012, 12:37 PM   #13
Is this thing on?
Glad to see it was only a blown fuse on Bro's bike. Tracking down wiring problems suck.
Old 01-21-2012, 12:49 PM   #14
hamill12
hamill12's Avatar
Motorcycle: gsxr srad 1000. rd 500 ypvs
There was a chap on the forum last year who has brand new looms for both carbed and injected Srad.
Im sure if you posted in the wanted section 1 would turn up and his price was really good.
A new loom in GB would be way to expensive.. If I were running an srad engine I would have purchased a loom because the day will come and they will be like hens teeth.
hamill12 is offline   Reply With Quote
Old 01-21-2012, 02:05 PM   #15
TT750
Motorcycle: 99 750
my other concern would be why did it pop???? hmmmm
Old 01-21-2012, 02:07 PM   #16
TT750
Motorcycle: 99 750
i think with time i could just about rebuild any loom if it had most the plugs.. actually would love if warren sent me a dead loom or 2 for me to check out..
Old 01-21-2012, 02:22 PM   #17
scooby601
scooby601's Avatar
Motorcycle: Srad 750 + SRAD 600
Would you not want to change the plugs? They are the weak link IMHO
I have a dead ish 750 carb loom that I want to try and re-make but the cost would be huge if I wanted to change the plugs too
scooby601 is offline   Reply With Quote
Old 01-21-2012, 06:34 PM   #18
TT750
Motorcycle: 99 750
hmmm plugs can be re pinned... the pins are the weakest link... i am also a fan of cutting out the extra wire in looms!! why the big manufactures not make engine/ecu as one loom and the lighting loom as a second loom. so racers could just take off the bits they not want... but then again i guess they couldnt sell the factory race looms for heart stopping prices.
Old 01-22-2012, 08:15 AM   #19
Is this thing on?
Yeah, I thought the same thing when homeboy found it was the fuse. They don't blow for no reason. Has to be a short or something drawing to many amps. That 30A fuse would most likely be something to do with the ignition if the bike was running when the fuse blew. Any suggestions? I'm interested in what you think, I'm learning myself.
