96-97 engine in a 98-99 frame question : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 01-15-2012, 03:47 PM   #1
LoneStranger1969
Motorcycle: 1998 srad,2000 gsxr 600(sold),1986 gsxr 750,1999 sportster sport,1998 gsxr(in bits)
Bought a frame(98) frame and a 96 or 97 engine with coil packs,I have bought both seperate and I am wondering what I need to do to mount the coil pac(NOn stick type) to the frame and where I should place them.I have downloaded the manual but was hoping for some pointers for what I need todo.Thanks in advanced John
LoneStranger1969 is online now   Reply With Quote
Old 01-15-2012, 04:29 PM   #2
ccmhunt
Carb Ninja
ccmhunt's Avatar
Motorcycle: 96 GSXR750, 07 CBR1KRR, ZX7/9RR F-USA AMA
Re: 96-97 engine in a 98-99 frame question
You could drill frame, install riv nuts, and position them where they go.... I am assuming you have a 750?
ccmhunt is online now   Reply With Quote
Old 01-15-2012, 04:34 PM   #3
ccmhunt
Carb Ninja
ccmhunt's Avatar
Put them here:
Old 01-15-2012, 05:25 PM   #4
LoneStranger1969
Thanks for the pic.I had no idea were they mounted.So they just stack over one another?thanks yes 750.Need to put your caps to use(ccm).When I connect (pacs)them to the wire loom do they have any order for the connetors?
Looked at frame and there are threading holes there already.Sweetness.My 86 pacs are mounted toward neck.
Old 01-15-2012, 05:57 PM   #5
ccmhunt
Carb Ninja
ccmhunt's Avatar
There is no polarity with regards to the two coil connectors, so you can connect to either pole. It does, however, matter which coil each pair of wires goes to.
Old 01-15-2012, 06:40 PM   #6
LoneStranger1969
I haven't looked at the loom(mainharness) but I assume it won't be to hard to figure out?
