Can someone explain what this means? : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Tech Forums > Riding Tech
Old 06-02-2004, 08:04 AM   #1
yesIcannabis
Hey,
I'm new to riding (with an 03 sixxer) and I see all these phrases like "blip the throttle", "chatter", "clicks in the rebound". what does all this mean? does chatter refer to locking up the rear tire? is blipping throttle gunning it? i'd like to learn more about riding but it's hard when you have no idea what people are talking about.
yesIcannabis is offline   Reply With Quote
Old 06-02-2004, 04:05 PM   #2
Philbie
Philbie's Avatar
Motorcycle: POS 04 GSXR
Re: Can someone explain what this means?
Blipping the throttle is just a very quick twist of the wrist. Normally done to help match engine rpms while downshifting.
This leads to the next one, Chatter. That is when the rear wheel isn't going the same speed as the ground and it will somewhat violently viberate up and down. Several ways to prevent or limit this. The most common is to match revs by "Blipping the throttle". You can also get chatter in the front while under braking.
Clicks of rebound are refering to rebound damping in either the forks or rear shock. My forks don't actually click, some do. I think the general rule is 1/4 turn is equal to a click.
Philbie is offline   Reply With Quote
Old 06-03-2004, 05:05 PM   #3
SkizitGSXR
SkizitGSXR's Avatar
Motorcycle: 2006 GSX-R1000: Z.G. DB Windscreen, HotBodies Undertail Fender Eliminator, Sato Frame Sliders & Spool Sliders, ASV Levers, Yosh TriOval Carbon Dual Tip slip, PCIIIusb, BMC , Driven 45t & 520 chain, Gilles rearsets, Spiegler SS lines
SkizitGSXR is offline   Reply With Quote
