Bandit motor donor. : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 11-21-2011, 01:33 AM   #1
Oldschoolfool711
Oldschoolfool711's Avatar
Bandit motor donor.
Whats the latest motor you guys seen in a oil cooled gixxer. I saw a 08 motor and I thought that would be a cool transplant. Anyone done new bandit motor tranplant?
Oldschoolfool711 is offline   Reply With Quote
Old 11-21-2011, 01:36 AM   #2
gixerhp
gixerhp's Avatar
Motorcycle: Hayabusa
Re: Bandit motor donor.
Bandit will work, but you need a GSXR oil pan, and pick up!
gixerhp is offline   Reply With Quote
Old 11-21-2011, 01:37 AM   #3
gixerhp
gixerhp's Avatar
As for transplants, im using a 74 GT750 2 stroke motor as this winter's project!
Old 11-21-2011, 05:27 AM   #4
SVS
Brofessional Viking Super Moderator
SVS's Avatar
Motorcycle: '08 KTM SuperDuke R, '03 GSX-R750, '99 SV650S, '84 XL600R
'08 is fuel injected and water cooled. Wouldn't say it's impossible but a lot of work.
...aaaaand FWIW (I know I risk being driven out of here with torches and pitchforks) the new Bandit actually has a better chassis than the old Oil Coolers so unless said donor Bandit is thoroughly wadded up, that conversion is kinda moot...
SVS is offline   Reply With Quote
Old 11-21-2011, 07:32 AM   #5
bigbike-r
bigbike-r's Avatar
Motorcycle: GsxR 7/12 TT-F1, Kawasaki gpx750r rat fighter
why? the bandit 12 motor sat in my gsxr750 frame has a bandit oil pan and pick up.
as for the latest motor seen in an oilcooled frame - ive seen a K-series squeezed in there but it required a lot of work
bigbike-r is offline   Reply With Quote
Old 11-21-2011, 11:29 AM   #6
Hootguy
Motorcycle: 89gsxr-rk,(2),,86 GSXR LTD,,86 gsxr-750 rd/blk,,85 GSXR 750,, 96 gsxr 750/rf900,,98 gsxr 750,,99yosh 750 superbike..86 RG500 Walter Wolf,,86 RG500 blue/wht,,
stuffing a downdraft motor into a sidedraft frame seems like a pointless thing to do,,,not to mention probably ugly as sin,,LOL...gotta see the cool crabs and nice looking clean motor,,
Hootguy is offline   Reply With Quote
Old 11-21-2011, 01:10 PM   #7
bigbike-r
bigbike-r's Avatar
yeah - one of them - just cos you can doesnt mean you should lol
Old 11-21-2011, 01:43 PM   #8
awasson
awasson's Avatar
Motorcycle: 1985 GSXR 750, 1986 GSXR Limited, 1989 GSXR750 RR (being assembled), 1973 GT-750 (no longer have, looking for another)
Awesome! Must see pictures of that and a video of it in action if you get around to it. I still miss my GT-750 LeMans with the smoothbores and chambers. That was a great bike
awasson is offline   Reply With Quote
Old 11-21-2011, 02:55 PM   #9
daves-cave
daves-cave's Avatar
Motorcycle: 1970 Norton Commando, 1974 Norton "Fastback, , 1986 GSXR 750, 1988 GSXR 750 soon to be RGV 7/12, 1989 Suzuki GSXR 1100, 1999 750 SRAD, 2008 Honda CBR (track bike),2009 Suzuki GSXR 1000
Hoot:
I had crabs once and it was not cool.
daves-cave is offline   Reply With Quote
Old 11-22-2011, 05:05 PM   #10
UK lee
Streetfighting Monster
UK lee's Avatar
Motorcycle: UK lee
Originally Posted by daves-cave View Post
Hoot:
PMSL !
UK lee is offline   Reply With Quote
Old 11-22-2011, 07:48 PM   #11
Hootguy
wahahahahaha,,,i missed that typo,,,but i'll leave it,,,it should be good for a few laughs,,,did you ever get rid of those crabs Dave..LOL
Old 11-22-2011, 10:16 PM   #12
jpnjim
jpnjim's Avatar
Motorcycle: GSXR1100J in progress, neglected GSXR1100H & ex-racer GSXR750F in pieces
x2
1972 GT750 was my first bike,
I had expansion chambers as well,
then I bought a basket case to get the 3 into 4 stock exhaust.
Sounded soooooo sweet,
would love to see one swapped into a Gixxer frame
jpnjim is offline   Reply With Quote
Old 11-23-2011, 12:18 AM   #13
gixerhp
gixerhp's Avatar
The exhaust is the problem, if you have a GSXR header!
Old 11-23-2011, 09:06 AM   #14
bigbike-r
bigbike-r's Avatar
not all gsxr headers - some work better with the b12 oil pan
a guy asked a couple weeks ago about a yoshi system designed for the gsxr that was causing trouble with access to the sump drain bolt and the solution there was to fit the b12 oil pan to the gsxr engine.
Old 11-23-2011, 04:21 PM   #15
EviLKarL
EviLKarL's Avatar
Motorcycle: GSXR750RG
Yep, I put a 2001 B12 in my Slabby, Used the Bandit oil pan and pick up because the B12 has good depth and ensures there is plenty of pol to pick up. No worries clearing the exhaust, I used a the V&H slabby and it fits nicely.
EviLKarL is offline   Reply With Quote
Old 11-08-2012, 10:48 AM   #16
daves-cave
daves-cave's Avatar
Just put a 2001 B12 motor in a GSXR 750K frame. Fairly straight forward with the exception of; drilling the lower rear engine mounts on the frame to 12mm to accommodate the B12's 12mm mounting bolt, and using a longer 12mm bolt.
I am using Dale Walker's B12 full exhaust and it bolted right up. I am currently installing/fabbing a Earl's cooler and will update with pictures.
Old 11-08-2012, 11:00 AM   #17
Apok
Motorcycle: '03 GSXR1000, '88 GSX 1100F, '92 GSX 1100F
Which is better for a swap, the 1127 or b12?
Didn't the 1127 have higher compression and a few more ponies?
Apok is online now   Reply With Quote
Old 11-08-2012, 11:59 AM   #18
ghostrider.1127
ghostrider.1127's Avatar
Motorcycle: few gsx-r
1mm more bore 1157 to gsxr 1127
diff (smooth)camshaft
lower compression
yes different clutch basket too
(b12 crappy ally, gsxr stainless)
diff oilpan (without thermo valve)
it s also possible swap all this parts on b12 engine
and change pistons ,work head for get back c.r.
ghostrider.1127 is offline   Reply With Quote
Old 11-08-2012, 12:30 PM   #19
gotgixers
Superbike Racer
gotgixers's Avatar
Motorcycle: 1986 GSXR 7/12
If you want to swap in a B-12 engine, the BEST ones to use are the '01-'05 models. '06 and up don't really fit in a 1st gen all that well. The '01-'05 B-12's have dbl row output shaft brg, a heavier clutch spring, a speedo pickup on the CS sprocket cover(So you can run a digital dash with that upgraded front end that doesn't have a speedo drive), TPS feedback 36mm carbs (tuned right, these run smoother than FI) And the full wire harness fits right into the GSXR frame no problem, I just grafted my 86 headlight and tail light harness into it, and run the '04 B-12 ECU. Swap in a 88-89 gsxr 750 intake cam, a 5* ign advancer, carb jet kit, pods, a GOOD full exhaust, and drop 1 tooth on the CS sprocket. You will have around 130 rwhp, 72-lb ft torque and get around 40+mpg, and NEVER even get hot.(I run the B-12 oil cooler as well) And this combo makes power wheelie style torque from around 3200rpm up ....
Life always gets better after a few gears and a shot of nitrous....
gotgixers is offline   Reply With Quote
