hey, where does this hose go? : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 06-07-2001, 08:22 AM   #1
mcgsxr
Motorcycle: mcgsxr
I have a 91 GSXR750, and recently installed a 90 750 motor. I notice that the far right (when sitting on the bike) carb boot has a hose that comes out of the top of it, about 12 inches long.
Yes, I should have remembered to check this when I pulled the motor, but I did not.
Where is this supposed to go? Is it some kind of overflow? Attach to the petcock?
Thanks in advance, mark
1990 GSXR750, reasonably modded
mcgsxr is offline   Reply With Quote
Old 06-07-2001, 10:32 AM   #2
mcgsxr
Motorcycle: mcgsxr
Re: hey, where does this hose go?
I should add that I think it goes to the airbox, but now I am using K&N pods, so should I just dangle it down with the battery overflow or something?
Old 06-07-2001, 11:34 AM   #3
imported_jeff
Superbike Champ
Motorcycle: jeff
if the hose is going to the intake boot, it's likely for the vacuum operated petcock. if you have a non-vacuum petcock on the tank, you can just remove the hose and cap off the opening on the intake boot.
imported_jeff is offline   Reply With Quote
Old 06-07-2001, 11:40 AM   #4
mcgsxr
Motorcycle: mcgsxr
Beauty, you come through again. I have a stock petcock with the 3 spigots on it, so I will apply that one to the correct one on the petcock, and I should be in business.
Thanks for your continued excellent input.
Mark
