front tire size question : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 08-23-2011, 01:18 AM   #1
easter bunny
Superbike Racer
easter bunny's Avatar
Location: littlest biggest city in the west. (is that right?)
Motorcycle: kawazuki CB-R1
A friend just picked up an 03 R6. It has a 180 rear which makes sense compared to my 190. But the front is a 120/60 where mine has a 120/70. The crown is visually identical, the added height is purely in the sidewall (i.e. no difference in contact patch).
Is there an advantage to the larger sidewall on a literbike? What happens if I decide to save rotating mass and go 120/60 assuming I compensate with fork height in the triples?
easter bunny is offline   Reply With Quote Quick reply to this message
Old 08-23-2011, 10:47 AM   #2
Trackstar
Trackstar's Avatar
Motorcycle: 2009 GSXR750, 2012 Yamaha R6, 2011 Ninja 250
Re: front tire size question
The SV's and a few others come with the 120/60 as well. We usually bump them up to a 120/70 when they come in for tires. There arent many sportbikes that come with the 120/60 so going to a 120/70 makes it easier when your tire shopping. The taller sidewall will give you a little breathing room when it comes to running out of tire at lean.
The 120/60 is the same as the 190/50. A stupid tire size that has no real benefit except fender clearance on certain bikes.
Trackstar is offline   Reply With Quote Quick reply to this message
Old 08-23-2011, 11:08 AM   #3
easter bunny
Superbike Racer
Thanks for the info. I just looked up my old GSXR and it had a 120/70. Not sure why yamaha decided to changes sizes on the R6, but I'll probably just swap it out and lower the front end.
Maybe. Seems odd to add the weight if there's not a lot of difference. Doesn't look like the larger sidewall gives any added lean angle.
Old 08-23-2011, 11:42 AM   #4
Trackstar
Trackstar's Avatar
If you look at the 2 tires after a trackday you will see the difference. It's not alot but it's enough.
Old 08-23-2011, 12:29 PM   #5
easter bunny
Superbike Racer
Please elaborate.
I'm 90% convinced I'll change it out, but what's the difference? Trying to figure out why Yamaha wouldn't put the 70 on the second gen. New ones come with a 70, but they also updated to USD forks. My 01 had a 70 and conventional forks so there doesn't seem to be much logic to it.
Old 08-23-2011, 01:30 PM   #6
Trackstar
Trackstar's Avatar
I dont know why they didnt do it. Could be they didnt want an issue with fender clearance. Some bikes when we put the 70 on the front make some nasty noises until the sticky goo from the labels is wore off because the clearance between the fender and tire wont clear gravel thats picked up. My guess is thats their main reasoning but it's just a guess.
Going off Dunlop Q2 specs the 120/70 is 4.83 wide while the 120/60 is 4.63 wide. The height difference is 22.8 vs 23.8 for the 70 series.
From the tires I have worked with you will have slightly more "chicken strip" with the 70 series. That means you have a little more breathing room before you run out of tire. The profile will be slightly different as well. I dont know if sidewall angles are different between the 2 but it could make a difference in profile.
Sorry but I'm not one of those really techy guys when it comes to building or fixing bikes. I look at tires, I feel suspension. I ride the bikes and work on making them feel right. Math is great but math doesnt always feel right. Some Techs work by the numbers and on paper they say things will be right. I'm just not that guy. I'm the guy at the track who starts with what I know works then makes little changes one way or another to make it better regardless of what the numbers tell me to do.
I cant give you a scientific explanation other than it works better.
I did run a 125/80 front the other day.... wow. Amazing.
www.trackstar1.com
PM me for Gixxer.com Member pricing on anything you need!
Old 11-09-2012, 07:33 PM   #7
QRYPTYQ
After 21 years of riding sports bikes? Choose wisely or die trying! Not a squid!
QRYPTYQ is offline   Reply With Quote Quick reply to this message
Old 11-10-2012, 11:52 PM   #8
groundhogday
groundhogday's Avatar
Motorcycle: K1 SV650, L1 GSX-R 750
I've been running 120/70 fronts instead of the original size 120/60 on my SV for years. Just like stated, you'll have a little extra chicken strip with the 70. You'll probably want to raise the forks in the triples to compensate for the taller tire.
groundhogday is offline   Reply With Quote Quick reply to this message
Yamaha Motorcycles Victory Gunner Forum Victory Charger Forum Honda Vultus Forum HD LiveWire Forum Ninja H2 Forum Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
