gsxr 600 not charging the battery?? : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > GSX-R600 / GSX-R750 General forum > 08-10 GSX-R600/750
Old 06-25-2011, 08:15 PM   #1
maks630
I just bought my first Street bike. a 2009 GSXR600 and it died on me twice already. First it showed a "SD" or "5d" error. I replaced the battery with a new one and that error went away. I took out a electrical checker and put it to the new battery. It read that at first it had a 12.8 v charge which is good but it then kept losing the charge as i reved the bike turned on the lights and turned on the blinkers! This is my first bike so I'm stumped. Can the fuse for the generator have blown out? If so where is it? Is it something else?
If you can be a little specific with answers id greatly appreciate it
THANK YOU GUYS
maks630 is offline   Reply With Quote Quick reply to this message
Old 06-25-2011, 08:24 PM   #2
Pro-Lux-Racing
Pro-Lux-Racing's Avatar
Motorcycle: A Gixxah!
Re: gsxr 600 not charging the battery??
You need to do further checks on the charging system. You should be getting like 14.5 off the battery while revving bike.
Do a search here, you can download the service manual. It will tell you how to check the stator and regulator/rectifier.
Usually it is one or the other.
Here, try this,
http://www.servicemanualsgsxr.com/
Pro-Lux-Racing is offline   Reply With Quote Quick reply to this message
Old 06-25-2011, 08:30 PM   #3
squale147
no rest for the wicked
squale147's Avatar
Motorcycle: 2011 GSXR-1000((sold)),2008 GSXR-750,((sold)) 2009 GSX-1300R Hayabusa 1992 CBR-600F2
theres a recall going on....check for it..
squale147 is offline   Reply With Quote Quick reply to this message
Old 06-25-2011, 10:07 PM   #4
poproxmimo3
poproxmimo3's Avatar
Motorcycle: K8-600
The sd or 5d error you got is because the Steering Damper is disconnected. Also put your battery on the charger for 10 hours.
There is a rectifier recall that needs to be done too.
poproxmimo3 is offline   Reply With Quote Quick reply to this message
Old 06-26-2011, 02:46 PM   #5
CARL13
CARL13's Avatar
Motorcycle: K8 GSX-R 600, CCM R30 SM
Hi,
There is a similar thread/s on the go at the moment.
From what you are saying: your battery charging rate on the bike is too low, the battery is discharging as the bike runs Ie nothing going back into it.
The ECU is probably shutting down the steering damper to conserve power or there is not enough power to operate it.
You need to investigate further.
The uk Suzuki site lets you input bike reg and vin number to check if any recalls are due/overdue, WARRANTY section of the site. Dont know if the U.S. site has this.
Carl
CARL13 is offline   Reply With Quote Quick reply to this message
Search this Thread:
Advanced Search
