03 gsxr 600 alstare : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > GSX-R600 / GSX-R750 General forum
Old 06-12-2011, 05:48 PM   #1
camarolover98
03 gsxr 600 alstare
i have recently bought a wrecked 03 gsxr 600 alstare i have everything working but the fuel pump i bought a "working" fuel pump off ebay and i have hooked it up and i have not fuel pressure i un pulged the pump and check the electrical current at the plug for the ecu and i am getting 12.85 volts but i hard wire the y/r and b/w wire and i get nothing should i hear it spool up or anything? might i have been sold a faulty pump or am i doing something WRONG?
i would appreciate help i geel dumb founded right now
camarolover98 is offline   Reply With Quote Quick reply to this message
Old 06-12-2011, 06:10 PM   #2
coopgt1
Rectum Rupticus
coopgt1's Avatar
Motorcycle: 2003 GSXR 750
Re: 03 gsxr 600 alstare
Did you check the clutch and side stand safety switches ? Are you in neutral ?
coopgt1 is online now   Reply With Quote Quick reply to this message
Old 06-12-2011, 06:32 PM   #3
camarolover98
yeah every thing is in working order clutch is pulled kickstand side switch is functioning and in neutral starter will tun engine is turn over but no gas flow i have it disconected from the fuel rail i have power to the fuel pump harness but i cant even get the fuel pump to spool up when i hot wire it :/
Old 06-13-2011, 01:18 AM   #4
Chugs
Lets go racing!
Chugs's Avatar
check tip over sensor?
Chugs is offline   Reply With Quote Quick reply to this message
Old 06-13-2011, 04:53 AM   #5
camarolover98
i did that as well i had a check engine F1 light and put it into dealer mode and i had it upside down once i took care oif that the pump still not working i have checked fuses every thing possible that i could think of
should i just go out and buy another fuel pump?
Old 06-13-2011, 06:13 PM   #6
coopgt1
Rectum Rupticus
coopgt1's Avatar
Dumb question time . Do the GSXR's have a fuel pump relay ? If they do you may want to check that also .
Real Name
What is your real name?
Search this Thread:
Advanced Search
