Re: problem with 97 gsxr 600
First, STOP TRYING TO CRANK IT WHEN IT DOES NOT WANT TO CRANK!
Chances are if it is only over night that you have this problem, you have a carb/petcock that is not sealing shut and allowing fuel to pass into the motor. When you try to crank it, your forcing the fuel to compress and pass the rings. Then it will fire and run.
If this is the case and you keep trying, you will find yourself with a bent rod at some point.
Best to let it sit over night, then pull the air box and look in the carbs. see if you have extra fuel in the intake.
99 GSXR750, yosh full race pipe, TRE, Tail light int., 180 rear tire, Almost Illegal Racing suspension, -1 front +3 rear sprocket, flush mount turn siganls, cut fender, 55,000+ miles!!!, Brembo Radial master, 4 pot brakes, balanced crank
