Shift w/o Clutch : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > GSX-R600 / GSX-R750 General forum > 08-10 GSX-R600/750
Old 05-12-2011, 08:27 PM   #1
bearbo
bearbo's Avatar
Motorcycle: 2011 GSX-R600 White
Shift w/o Clutch
When I was riding yesterday, I realized I was able to upshift from 5 to 6 without clutch. As I wasn't sure why, I didn't experiment more... Is it because:
1. That was the intended behavior? If so, when can I shift without clutch?
2. It can work, but not good for the bike, and can (but haven't yet) lead to things break?
3. Something broke already?
Can someone let me know which one it is?
Thanks.
bearbo is offline   Reply With Quote
Old 05-12-2011, 08:30 PM   #2
Driving_Miss_Daisy
Moose Knuckle Racing!
Driving_Miss_Daisy's Avatar
Motorcycle: GSXR750k8
Re: Shift w/o Clutch
You can shift any manual without a clutch. It is called rev matching.
Driving_Miss_Daisy is offline   Reply With Quote
Old 05-12-2011, 08:42 PM   #3
a.leopard
Nazi Lustful Faggot - hot for Hermann Göring & Cainyboy
a.leopard's Avatar
Motorcycle: zixxer 1k '06, k7 600
Yep
Everytime you want.
Done properly it won't hurt the bike
Nope
a.leopard is online now   Reply With Quote
Old 05-12-2011, 09:35 PM   #4
K3Gixx
Confuses vag for cock... That would be "cock" as in rooster. Which might be even worse. And takes more duct tape to avoid a damn mess. Has lead to interesting nights.
K3Gixx's Avatar
Search "clutchless upshifting" and you'll see some long running threads on this subject.
Yes it's fine. No it won't hurt the bike. Just be sure to do it right, if there's a load on the transmission, don't try to force a shift... let up on the throttle as you would normally do, and kick it up.
I only use my clutch to engage 1st gear from a stop, shift to 2nd and to downshift.
K3Gixx is offline   Reply With Quote
Old 05-12-2011, 09:38 PM   #5
Ciaran1100
Motorcycle: 1998 GSXR 750, 2001 Aprilia RSV Mille R, 2007 Kawasaki ZX6R
I'm clueless but just started clutchless upshifts on track. I like it, big kick in the arse on a 1000cc bike. Ain't tried it on my SRAD.
Ciaran1100 is offline   Reply With Quote
Old 05-12-2011, 09:50 PM   #6
TattooedAffliction
TattooedAffliction's Avatar
Motorcycle: K9 GSX-R600
I do it every once in a while when I'm riding. It's very simple. Let of throttle just a tiny bit while putting a little pressure on the shifter, and it slides right in smooth and effortlessly.
TattooedAffliction is offline   Reply With Quote
Old 05-12-2011, 09:55 PM   #7
bonnoughj
bonnoughj's Avatar
Motorcycle: GSXR 600
I'll have to try it..
bonnoughj is offline   Reply With Quote
Old 05-12-2011, 10:20 PM   #8
K3Gixx
K3Gixx's Avatar
A member here who is wiser than me suggested that preloading the shifter is a bad idea. Can damage (hope I get this right) the shift forks or dogs, I forget which he said.
Old 05-12-2011, 10:37 PM   #9
a.leopard
a.leopard's Avatar
shift forks. You can damage them if you apply insane amount of the pressure on the gear lever.
Old 05-12-2011, 11:17 PM   #10
TattooedAffliction
Yeah, that makes sense. When I said to put a little pressure on the shifter, I didn't mean to pull hard on it, just a very slight amount to take up the tiny amount of slack so when you let off the throttle it slides in. You certainly don't want to force it, it should be smooth and if you encounter resistance, stop.
Old 05-13-2011, 12:55 AM   #11
mferg-tsr
mferg-tsr's Avatar
Motorcycle: '08 GSX-R 600
do this all the time when i have my left hand resting on my leg which is a lot because of my long commute to work lol
mferg-tsr is offline   Reply With Quote
Old 05-13-2011, 11:32 AM   #12
bearbo
bearbo's Avatar
Just making sure, clutchless DOWNshift is not recommended?
Old 05-13-2011, 11:33 AM   #13
600k2
It's a Jersey thing
600k2's Avatar
Motorcycle: 600k2
not recommended
600k2 is online now   Reply With Quote
Old 05-13-2011, 03:36 PM   #14
mferg-tsr
mferg-tsr's Avatar
you are correct, do not downshift using this method
Old 05-13-2011, 03:48 PM   #15
Edimasta
Edimasta's Avatar
Motorcycle: GSX-R 750 K9
Just get a Quickshifter and do it properly...
Edimasta is offline   Reply With Quote
Old 05-13-2011, 10:29 PM   #16
Mr.Stanley
Touches himself to Disney porn
Mr.Stanley's Avatar
Motorcycle: K9 600
I've done clutchless downshifting and it seems fine. The method I did was, Let off the throttle a tiny bit and at the same time shift but what I notice is that if you downshift w/o the clutch from 2nd to 1st, it doesn't always go into 1st. It tends to stick in neutral and even when you use the clutch to get it out neutral it will grind the gears going into 1st. So I don't really use clutchless downshift. I do shift up w/o the clutch. It should be the same method. Let off the throttle a bit and at the same time shift. I also notice from 1st to 2nd it sometimes jerks a little bit but if done right, it does shifts smooth.
Mr.Stanley is offline   Reply With Quote
Old 05-14-2011, 07:44 AM   #17
TOEJAM
Ditchard the High Maintenance Squirrel
TOEJAM's Avatar
Motorcycle: 06 R1 Raven; '07 Ducati 1098S; '08 Triumph Sprint ST; '09 Triumph 675; '10 Yamaha R6; '13 Aprilia RSV4 APRC
Yes - clutchless upshifting can be done without hurting anything if done properly.
No - there is absolutely no reason to do it on the street other than pure laziness.
Yes - the best way to do it is to get a Quickshifter (if you are racing).
TOEJAM is offline   Reply With Quote
Old 05-15-2011, 11:24 PM   #18
Pleiades
Pleiades's Avatar
Motorcycle: K8 GSX-R 600, NC29 CBR 400 Race Bike
Who needs a quickshifter? :P
Pleiades is offline   Reply With Quote
Old 05-20-2011, 03:22 AM   #19
psyko323
psyko323's Avatar
Motorcycle: White GSX-R 750 K9
How to shift...
psyko323 is offline   Reply With Quote
Old 05-20-2011, 03:28 AM   #20
Ciaran1100
Pleiades, please explain what the hell yer doin to shift so smooth.
