ERROR CODE "C46" SHOWN AND HOW TO FIX THE PROBLEM? : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 05-08-2004, 12:42 AM   #1
peddyk3
ERROR CODE \"C46\" SHOWN AND HOW TO FIX THE PROBLEM?
Hi. I had posted a thread recently pertaining to the red light and F1 shown on the display. Found the solution to get into the dealer mode and got the error code displayed as " C46 ". According to a genius member of this forum, the code stands for EXAUST CONTROL VALVE ACTUATOR fault. So, how do I fix this problem? Is the sensor faulty or anything that I need to do? For your info, I had my K3 fitted with bolt on Akra, USBpc3, TRE and K&N filter. Anybody who had come across this, pls give me a hand here. Thanks. Cheers
peddyk3 is offline   Reply With Quote Quick reply to this message
Old 05-08-2004, 09:15 AM   #2
jeffw
jeffw's Avatar
Re: ERROR CODE \"C46\" SHOWN AND HOW TO FIX THE PROBLEM?
Sure, I'll bet when you installed your exhaust that you removed the SET servor motor on the inside of the right frame rail huh????
Did you remove any of the wires on teh ECU, or do anything with the SET servo motor connections?
jeffw is offline   Reply With Quote Quick reply to this message
Old 05-08-2004, 06:24 PM   #3
peddyk3
No I did not. I never knew about the SET servo motor connector, how it looks like and what to do with it. But I had come across one thread, posted by a Gixxer member saying that a K3 with a BOLT ON exaust pipe does not require disconnecting the brown wire in the ECU or something. I am not sure what to do really. Surely need more help from you Jeffw and anybody else out there. Thanks. Cheers
Old 05-09-2004, 06:27 PM   #4
peddyk3
Well...I'll take it as nobody seems to have an solution for me. Or had never come across this problem before. Cheers
Old 05-09-2004, 06:42 PM   #5
Stocky
Stocky's Avatar
Motorcycle: GSXR1000 K2
Well it's out of adjustment, and you should remove it all anyway.
Go to Bugman's site and read up on it. (he hsa his own forum here)
Stocky is offline   Reply With Quote Quick reply to this message
Old 05-10-2004, 05:39 AM   #6
peddyk3
I had found out that the servo motor was faulty and the two cables regulating the butterfly valve jammed. I ended up removing the exaust valve and disconnecting the brown/black wire in the ECU. Problem solved and the bike runs better than ever. Thanks anyways. Cheers
Old 05-10-2004, 06:35 AM   #7
mtmra70
Superbike Champ
Motorcycle: SOLD 2001 Gixxer 1000
You dont need to remove the SET for a bolt-on
mtmra70 is offline   Reply With Quote Quick reply to this message
Old 12-26-2010, 03:22 AM   #8
reesm
Re: ERROR CODE "C46" SHOWN AND HOW TO FIX THE PROBLEM?
what is error code c46 and c93 thanks
reesm is offline   Reply With Quote Quick reply to this message
Old 12-26-2010, 01:01 PM   #9
BillV
Supersport
Motorcycle: Blue 2006 GSX-R1000
It's time for you to get a service manual. It's available for free download.
BillV is offline   Reply With Quote Quick reply to this message
Real Name
What is your real name?
Search this Thread:
Advanced Search
