gsxr 1000 09 chain slack : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > GSX-R1000 General Forum > 09-11 GSX-R1000
Old 05-02-2011, 06:41 AM   #1
gsxr@uae
Motorcycle: gsxr 1000 2009
hi guys,
i've been reading in gixxer web site about some people having problems with the chain adjuster on gsxr 1000 09 and above,
i have this issue as well, i had my gsxr 1000 09 for 1 year and half, 25 k on the odometer, every time the chain slack out, even i adjusted and just ride for 10 mins, the axle nut is at the right torque
now is it better to fit the gilles adjuster, or just replace my OEM ones
thanks in advance for replying
gsxr@uae is offline   Reply With Quote Quick reply to this message
Old 05-02-2011, 08:11 AM   #2
jZampage
Jesus-On-Skates
jZampage's Avatar
Motorcycle: 2014 Aprilia RSV4 Factory
Re: gsxr 1000 09 chain slack
Um... are you tightening BOTH bolts and nuts on the swing arm axle assembly, and not just the axle nut? I torque my axle nut even slightly more than what is in the manual - it came that way out of the crate and I have matched it straight from the factory every time. I hand tighten is as much as I can with the tool they provide and then use a ballpeen hammer to go 2 more rotations pretty much. I don't get any slack and no friction on mine. I just did it again this weekend and re-attached the rear.
- jZampage
jZampage is offline   Reply With Quote Quick reply to this message
Old 05-02-2011, 09:47 AM   #3
Grumpy 427
Grumpy 427's Avatar
Motorcycle: 2009 GSXR-1000
I have been adjusting mine with no problems. You need a buddy to help to do this correctly. You need a guy your weight to be sitting on the bike when you adjust the chain.
Grumpy 427 is offline   Reply With Quote Quick reply to this message
Old 05-02-2011, 10:07 AM   #4
FlWolverine
FlWolverine's Avatar
Motorcycle: 2011 1198SP, 2011 848EVO
Put the axle in opposite way, placing the nut on the brake side. You have to swap the axle blocks too btw....... That way, when you torque it down, the axle will stay solidly against the adjuster bolts. When its on the sprocket side, it tends to "roll away" from the adjusters when torquing down. Hope this helps.
gary
FlWolverine is offline   Reply With Quote Quick reply to this message
Old 05-02-2011, 12:40 PM   #5
Mike Edwards
Put a spanner or large screwdriver between chain and sprocket and pull wheel back. The extra tension will pull the axle forward while you tighten the nut.
Also, as already suggested, have the axle in the other way around so the nut is on the brake side.
Mike Edwards is offline   Reply With Quote Quick reply to this message
Old 05-02-2011, 01:38 PM   #6
rraiderr
rraiderr's Avatar
Motorcycle: Stretched and slammed Busa
gary
+ 1
rraiderr is offline   Reply With Quote Quick reply to this message
Old 05-08-2011, 01:45 PM   #7
Midnightgsxr1g
Midnightgsxr1g's Avatar
Motorcycle: STOLEN k7 600/1970s Yamaha gt80/ K9 1XXX
Originally Posted by gsxr@uae View Post
hi guys,
I never had a problem!
even if you do have this problem im sure the chain is not getting super loose by maybe moving a hair.
Midnightgsxr1g is offline   Reply With Quote Quick reply to this message
Old 05-10-2011, 05:11 PM   #8
gsxr@uae
thanks for all u reply,
its all good now, i follow your advice by moving the axle nut to the brake side and then ask my friend to sit on the bike, then i tight the nut to max
thanks for your help
Old 05-12-2011, 09:41 AM   #9
iuhutch
iuhutch's Avatar
Motorcycle: 2009 Suzuki GSXR 1000
But it will throw the chain alignment off which will cause other issues.
iuhutch is offline   Reply With Quote Quick reply to this message
Old 05-12-2011, 07:30 PM   #10
Rickpatbrown
Motorcycle: K9 GSX-R 1000
I'm not really following. The manual says to do it on the side stand. Are you saying that it should be done with the back shock compressed slightly?
After I get a friend to do this once, can't I just measure the chain slack on the side stand right after I adjust it. This will be MY weight specific chain slack target.
Rickpatbrown is offline   Reply With Quote Quick reply to this message
Old 05-12-2011, 11:04 PM   #11
rraiderr
rraiderr's Avatar
Yes you can adjust it while on the side stand.
Just follow the step in the manual and you will be ok.
The chain should smile a bit when it is right.
Old 05-13-2011, 12:12 AM   #12
K6 Blizzard
Guest
Posts: n/a
yes youre supposed to adjust the chain while the bike is on the side stand
Search this Thread:
Advanced Search
Yamaha Motorcycles Victory Gunner Forum Honda Vultus Forum HD LiveWire Forum Ninja H2 Forum Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
