R-1 shock on 86 750? : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 03-29-2011, 11:53 AM   #1
Harrymanback86
Off to New York to get hitched! Toodle-loo!
Harrymanback86's Avatar
Motorcycle: 1987 gsxr 1100/1986 gsxr 750
The best way to do this is find the right shock. Pictured are two R-1 units. the second pic is that of a new works shock. The R-1 one units reqiured modifying the battery box. Any body do it with out butchering the battery box? Easier to buy the correct shock. I bought the right part.
Harrymanback86 is offline   Reply With Quote
Old 03-29-2011, 11:55 AM   #2
Harrymanback86
Re: R-1 shock on 86 750?
Ooops, pics?
Old 03-29-2011, 02:25 PM   #3
BLITZ2R
BLITZ2R's Avatar
Motorcycle: (1)'91 1100 BK/RD, (1)'91 1100 BL/WH, '91 750/888, '04 HD HERITAGE
So no resivoir on the works shock?
BLITZ2R is offline   Reply With Quote
Old 03-30-2011, 01:01 AM   #4
John's truck
I have the shock pictured on the upper left. Pretty sure it would have worked... if I hadn't gone with a 2006 swingarm and linkage... and if my bike had a Suzuki subframe and a battery box. No way to tell now though.
John's truck is offline   Reply With Quote
Old 04-02-2011, 09:14 PM   #5
Screamin
Motorcycle: 85 GSXR 750, RC 51 SP1 Honda, KTM 450 exc
Im looking at replacement options for my original shock on my 85 750. From your postings I am guessing there are several options available other than OEM Suzuki.
I know the 85 had a shorter swingarm than 86. Is the the shock the same ?
I'm keen to here what other members have used or recommend.
Thanks
Richard
Screamin is offline   Reply With Quote
Old 04-03-2011, 12:32 AM   #6
FruitLooPs
Motorcycle: 1986 GSXR750
AFAIK the 85-87 750's all use the same shock. Overheated easily when they were new and these days they're saggy old and unrebuildable.
I went with R1 shock (top left pic) and had the bottom eyelet bush shaved to fit in a lathe for a couple bucks. Tight fit and battery box needs bottom cut (I used next size smaller battery same dimensions except height and spaced it up higher so the shock would clear).
It gives a bit higher ride height at the rear, which helps turn in if you have the 18" factory wheels - I probably need to get my sag and what not setup but it seems alright so far. Someone here went that way with an ohlins spring matched to his weight.
Next to the manky original shock (and yes the yellow I believe is overspray from the person who 'painted' my bike )
FruitLooPs is offline   Reply With Quote
Old 04-03-2011, 01:14 AM   #7
HeJason
HeJason's Avatar
Motorcycle: 02 GSXR turbo 1k, 86 GSXR 750 (92 1216 motor), 89 FZR 1000 (1070 motor), 94 GSXR 750 (95 1146 motor), BigBore 00 Busa
I used an r6 shock, its a bit shorter than the r1 shock so it is closer to the original shocks length. Vast improvement over the screen door plunger they used on the original 86s.
HeJason is online now   Reply With Quote
Old 10-31-2011, 09:48 AM   #8
poindexter888
Motorcycle: 1985 GSXR 750, 1995 Triumph Trident, 1973 850 Norton Commando
These guys claim they have the answer, I'll be contacting them shortly myself - http://www.promecha.com.au/suzuki_gsxr750_85.htm
poindexter888 is offline   Reply With Quote
Old 10-31-2011, 10:19 AM   #9
Tank Slapper
This^
Mine came with a WP with a reservoir but it seems really soft. Not like the Hyperpro on the Ducati.
Tank Slapper is offline   Reply With Quote
Old 10-31-2011, 05:32 PM   #10
ozboy
ozboy's Avatar
Motorcycle: GSXR750,1100
Fruitloops is on the ball with this one. The only thing I will add is that the R1 shock with the hydraulic preload adjuster is slightly shorter than the one pictured and closer to the 295mm the original shock is. (Pics to follow)
ozboy is offline   Reply With Quote
Old 11-01-2011, 04:11 AM   #11
ozboy
ozboy's Avatar
Here's the pic of the two R1 units:
Mechanical pre-load - 300mm
Hydraulic pre-load - 295mm
Old 11-01-2011, 11:34 PM   #12
Richie Rich
Richie Rich's Avatar
I can vouch for pro-mecha as a viable alternative - I can't recall the owners name but he's a nice bloke and has worked on 3 of my bikes. About a year ago did the forks on my '83 RZ350 - gutted them and used their cartridge emulators in the rebuild. The difference was unbelievable and my '85 GSXR750 forks will be going to them too when I get to that stage of the rebuild.
Regarding rear shocks - keep your eyes peeled for 2nd hand aftermarket units - they do come up on this forum and ebay as well. I managed to pick up a rebuilt fully adjustable White Power shock for mine for about $180.
Penske also a shock for an '85 GSXR - cheaper than an ohlins etc. and worth considering while the AUD is high against the USD. I bought one of those for the RZ and it's a quality piece of kit.
The Flying Kiwi!
1985 Suzuki GSXR750F
1983 Yamaha RZ350K
1989 Yamaha TZR250 3MA Reverse Cylinder
2008 Triumph 675 Street Triple RR
Richie Rich is offline   Reply With Quote
Old 11-02-2011, 12:41 AM   #13
T8KC
T8KC's Avatar
Motorcycle: 1986 Cagiva Alazzurra 650SS, 1986 Suzuki GSX-R750 track bike, 1978 Suzuki GS1000, Honda XL70
On my 1986 GSX-R750 track bike, I used a 2005 R1 shock with a few modifications.
1) the lower mount was narrowed 1mm to fit the stock rocker clevis.
2) the spring was replaced with an Eibach 650 lbs/in (I weigh about 225).
3) a Race Tech threaded preload adjuster was used in place of the stock unit.
4) Race Tech revalved with their Gold Valve to suit the new spring rate and the GSX-R rocker geometry.
5) the extended length was shortened 5mm.
6) I had to clearance the rocker slightly to clear the lower collar/spring.
7) the battery box was modified to clear.
Total cost including shock (ebay) was $385.
Old&Slow
T8KC is offline   Reply With Quote
Old 11-02-2011, 06:36 AM   #14
Niels750
Motorcycle: 91' GSXR750(M) just 12000mls, 87' Slabby 750 just 10000mls, 95' Bimota SB6 just 3000mls!
'04 R1 shock with Ohlins spring:
Niels750 is offline   Reply With Quote
Old 03-28-2012, 03:54 PM   #15
micron boy
Motorcycle: micron boy
My 06 R1 shock with 87 spring fitted
micron boy is offline   Reply With Quote
Old 03-29-2012, 06:41 AM   #16
atc250r
Motorcycle: 1986 GSXR 750
Looking to do an 09 R1 shock soon and I'd love to see one installed. Anyone have any advice for someone doing this swap? I've read all the posts I could find on here and think I've got it covered.
atc250r is offline   Reply With Quote
Old 03-29-2012, 08:01 AM   #17
1216N
1216N's Avatar
Motorcycle: 92 7/1216 gixxer
Why the R1 instead of Gsxr1000. Mods look to be the same, but gsxr fits the clevice.
1216N is offline   Reply With Quote
Old 03-29-2012, 08:43 AM   #18
atc250r
You talking about the lower mount when you say clevis? I would go with whichever one is closer to the original shock in length. If the consensus is that the 1K shock is a better match in rate, length, and valving then its kind of a no brainer.
Old 03-30-2012, 12:14 AM   #19
Sharkax
so what kind of works shock is that? i am interested in a shock that wont require battery box trimming, just a plain old swap.. any ideas? so far i've heard of the 2009-2011 1k shock, and r1'/6's which all seem to need a battery fabrication
Sharkax is offline   Reply With Quote
Old 11-16-2012, 11:43 PM   #20
pontaic
Motorcycle: gsxr 1000 k9,rxv 550
Hey woud this r1 shock work on a gsxr1100 1986 as well?
Sent from my iPhone using MO Free
pontaic is offline   Reply With Quote
