Maintenance... : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > GSX-R600 / GSX-R750 General forum > 08-10 GSX-R600/750
Old 03-24-2011, 02:42 PM   #1
Twistx
Maintenance...
Hello all,
I had some questions that I couldn't really find answers for (or maybe not clear ones). I bought a 2008 GSXR 750 with about 100 miles on it during the summer of 2009. Because of certain life events and situations I wasn't really able to ride it to the fullest until this past summer (2010). The bike now has 1600 miles on it. The only maintenance I've done on it is the first service (done at dealer), change the oil, and lube the chain. My questions are the following:
1. Do I change the spark plugs? Manual says that it should be done after 12 months and it has technically been 3 years.
2. Brake fluid is recommended to be replaced every 2 years but is this necessary?
3. Do I change the oil once I start riding again? Been in storage for about 3-4 months now.
As a side note, bike has been riding fine and has technically been in storage for the winter. Thank you all in advance for your help!
-JC
Twistx is offline   Reply With Quote
Old 03-24-2011, 03:19 PM   #2
Lean With It
Superbike Champ
Lean With It's Avatar
Motorcycle: 1999 GSXR 750 F.I.(modded - street/track) - 1997 GSXR 600 race bike (modded)
Re: Maintenance...
changing the plugs would make sense if the bike was ridden - perhaps the same goes for the brake fluid, unless the bike has been sitting for a very long time. IF the brake fluid has a good color to it (clearish) and not leaking or anything, you are probably fine.
good practice to change the oil after the bike has been sitting for a while.
- just what I do...others may do things differently.
Lean With It is offline   Reply With Quote
Old 03-24-2011, 03:22 PM   #3
Twistx
Re: Maintenance...
The bike sat the whole year of 2009 up until the summer of 2010. Then was put away in November. I'll change the oil, should I change the filter too?
Old 03-24-2011, 03:26 PM   #4
Lean With It
Superbike Champ
Re: Maintenance...
just do a visual inspection of it...same for the plugs. If the plugs are showing normal signs of wear, you can clean the carbon off them with a brush or shop rag and continue to use them. Change it if necessary. I don't change mine after Winter storage.
Old 03-24-2011, 04:34 PM   #5
Buster Hymen
Only Here to LOL & +1....
Buster Hymen's Avatar
Motorcycle: K7 750 Crackbike
Re: Maintenance...
Was the battery still good?
Buster Hymen is offline   Reply With Quote
Old 03-24-2011, 06:12 PM   #6
Driving_Miss_Daisy
Moose Knuckle Racing!
Driving_Miss_Daisy's Avatar
Motorcycle: GSXR750k8
Re: Maintenance...
I would say plugs are probably still good. Oil should be changed. Brake fluid probably since it has been sitting there a long time.
Driving_Miss_Daisy is offline   Reply With Quote
Old 03-24-2011, 08:45 PM   #7
rraiderr
Buys OG's Depends
rraiderr's Avatar
Motorcycle: 2012 1000
Re: Maintenance...
IMO
Change the oil and filter, charge the battery, clean and lube the chain, verify there are no mice living under the tank, check the air filter, check the radiator fluid level, check tire pressures and ride.
rraiderr is offline   Reply With Quote
Old 03-24-2011, 09:36 PM   #8
MotoMummy
Parts Bitch
MotoMummy's Avatar
Motorcycle: Mummy Bike
Re: Maintenance...
If it's sitting that long and you want it to run like mint again and want to keep riding it then I would do the battery, plugs, tires, and ALL fluids. then inspect the brake pads pretty well also. As others said, and it may seem funny, but check for anything living in the ram air, airbox, or under the tank. It happens more then you would think.
MotoMummy is offline   Reply With Quote
Old 03-24-2011, 10:03 PM   #9
mferg-tsr
mferg-tsr's Avatar
Motorcycle: '08 GSX-R 600
Re: Maintenance...
yea plus one on the fluid changes...way better to be safe than sorry
mferg-tsr is offline   Reply With Quote
Old 03-25-2011, 01:21 AM   #10
Bengtern
Bengtern's Avatar
Motorcycle: Gsxr 600 k8
Re: Maintenance...
no point changing the brake fluid unless it dont have a high enough boiling point. just use a:
same goes with the radiator fluid just use a
Bengtern is offline   Reply With Quote
Old 03-25-2011, 01:44 AM   #11
psyko323
psyko323's Avatar
Motorcycle: White GSX-R 750 K9
Re: Maintenance...
daaamn! all futuristic and shit. i've never seen one of those before.
psyko323 is offline   Reply With Quote
Old 03-25-2011, 06:25 AM   #12
Bengtern
Bengtern's Avatar
Re: Maintenance...
hehe i would not call it futuristic, all mechanics use it good thing to have at home to
Old 03-25-2011, 09:08 AM   #13
Twistx
Re: Maintenance...
Actually the battery died but I got it up and running again with a tender.
I just rode it in November but I went to check to make sure nothing made my bike a rental home and it seems clean. I'll do a an inspection of everything I guess to make sure nothing needs replacement. Tire pressure and tread is good, same goes with air filter.
Bengtern,
How much do those devices usually run?
Old 03-25-2011, 09:41 AM   #14
Buster Hymen
Re: Maintenance...
Good idea Bengtern...........
Around $500 for the fluid meter and another $150 for the refractometer.........or you could just take the cap off and see if the brake fluid is light(good) or dark(bad).
Old 03-27-2011, 12:21 PM   #15
Bengtern
Bengtern's Avatar
Re: Maintenance...
lol?? the pics was only a example, u can buy cheaper stuff that works just as fine for around 150-200$ for both or even cheaper
Old 03-27-2011, 12:26 PM   #16
Buster Hymen
Re: Maintenance...
I'll stick with my method...............no batteries required!!!!
Old 03-29-2011, 02:57 PM   #17
Twistx
Re: Maintenance...
Does the brake fluid still need to be changed even if it LOOKS clear?... I know brake fluid absorbs moisture and that degrades the efficiency of it however is that what causes the brake fluid to turn dark?
