How to change the front sprocket? : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > GSX-R1000 General Forum > 07-08 GSX-R1000
Old 03-16-2011, 05:19 PM   #1
jfallon3
jfallon3's Avatar
Motorcycle: K7 Gsxr 1K
I Haven't looked into it too much but I was wondering if someone had any tips or maybe a how to on changing the front sprocket. I know tipicaly its just pull the case that covers it and pull the nut and thats pretty much it.. When I was looking at it, it looked like there were some lines/ or covered wires running that part of the case? Do I have to do anything with those? Any tips on what would make it easier its greatly appricated! Thank you
jfallon3 is offline   Reply With Quote Quick reply to this message
Old 03-16-2011, 05:33 PM   #2
cooper232
cooper232's Avatar
Motorcycle: 2005 GSXR600
Re: How to change the front sprocket?
one is your clutch cable and the other is for the speed sensor. on my 05 i didn't do anything with them just tilted the cover back and up with them still attached. make sure you have a big driver, torque wrench, some blue threadlock for the bolt holding in the speed sensor rotor and some red threadlock for the nut holding the sprocket on. use a 2x4 through the spokes of the back wheel to keep it from spinning when loosening and tightening that big nut. also make sure to turn your chain adjuster bolts all the way so you can slide rear wheel forward and get chain off and on the front sprocket. good luck.
cooper232 is offline   Reply With Quote Quick reply to this message
Old 03-16-2011, 05:54 PM   #3
jfallon3
jfallon3's Avatar
05 isn't a hydraulic clutch correct? any special caution for that?
Old 03-16-2011, 06:00 PM   #4
MAD_ARAB
MAD_ARAB's Avatar
Motorcycle: A revamped K6 liter
05/06 is cable and 07/08 is hydraulic.
MAD_ARAB is offline   Reply With Quote Quick reply to this message
Old 03-16-2011, 06:10 PM   #5
jfallon3
jfallon3's Avatar
I thought so. Does that make it any different changing the sprocket?
Old 03-16-2011, 06:30 PM   #6
iLLiE586
iLLiE586's Avatar
Motorcycle: 08 GSX-R1000
I just changed out my front sprocket a month ago. All I did was undo the case, move it to the side with the cables attached still. Then you just wrench off the speed bolt and then the big nut.
If you take the cables off I'm assuming you would have to bleed the clutch, so I would just leave everything that is attached to the case alone.
iLLiE586 is offline   Reply With Quote Quick reply to this message
Old 03-16-2011, 06:46 PM   #7
jfallon3
jfallon3's Avatar
Ok thanks, I just wanted to check. I hate running into something unexpected.
Old 03-16-2011, 07:28 PM   #8
Buster Hymen
Only Here to LOL & +1....
Buster Hymen's Avatar
Motorcycle: K7 750 Crackbike
Dave's a good teacher............just don't install the sprocket backwards.
Buster Hymen is offline   Reply With Quote Quick reply to this message
Old 04-06-2011, 04:19 PM   #9
jfallon3
jfallon3's Avatar
Can someone tell me what size wrench the big nut that holds the sprocket on it? I have a bunch of smaller wrenches but need to pick up the one to fit that nut. Thanks!!
Old 04-06-2011, 05:27 PM   #10
iLLiE586
iLLiE586's Avatar
32mm
Old 04-06-2011, 05:32 PM   #11
wuzup76020
Supersport Racer
wuzup76020's Avatar
Motorcycle: 2008 GSXR 600
I actually used these exact videos to do my change this last week
I did manage to BREAK 3 6mm allen wrenchs trying to get the speed sensor bolt off though
wuzup76020 is offline   Reply With Quote Quick reply to this message
Search this Thread:
Advanced Search
Yamaha Motorcycles Victory Gunner Forum Honda Vultus Forum HD LiveWire Forum Ninja H2 Forum Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
