Pads : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > GSX-R1000 General Forum > 01-02 GSX-R1000
Old 01-09-2011, 03:30 PM   #1
spezer
spezer's Avatar
Motorcycle: Gsxr 1000 K1
Pads
Just incase I can't afford new calipers/MC or new forks what the recommended replacement for the standard 6 pots?
I do high speed road and occasional track days.
spezer is offline   Reply With Quote
Old 01-10-2011, 07:24 AM   #2
gixxereater
gixxereater's Avatar
Motorcycle: 02 GSX-R 1000/02 GSX-R 750
Re: Pads
I've tried OEM......they were ok. Then went to EBC HH and of course they had more bite but less feel. Next up was Ferado Array pads. A tad less bite than EBC but way more feel. Now have a set of Carbone Lorain pads awaiting install with new Galfer rotors. (Got a great price on them from Mummy by the way!!) Will see how this pans out come spring for a track day. Considering one of the factory rotors now has a severe shake when applying the brakes it will no doubt be better than that. Everyone raves about Vesrah but I've also read they are less than stellar at street speeds. Hard to say as I've never tried them.
gixxereater is offline   Reply With Quote
Old 01-10-2011, 09:25 AM   #3
Alfalfa
Consistent, albeit slow
Alfalfa's Avatar
Motorcycle: K1 1K, K6 3/4
Wink Re: Pads
The biggest problem with the six piston calipers is the heat, causing fluid expansion and thus the poor/unpredictable lever at the master. Going to an organic pad and/or some better (higher iron content) rotors may help until your speed increase nullifies that modification.
Still, you´re in a bit of a pickle if you don´t have the funds to upgrade to the radial mounts, mc , etc. tho.
I dealt with the brake fade/lever inconsistency ordeal back when this generation bike was "state of the art". After lines and aftermarket sintered metal pads, I upgraded to this set up which helped with the heat. Iron discs & organic Ferodo pads:
BTW, those forks seemed to work pretty well judging by the lack of the telltale strip on that tyre.
....As You Were....
Riding motorbikes since 1971
There certainly are several arrogant douche bags on this forum
Google dumbass!
Alfalfa is online now   Reply With Quote
Old 01-10-2011, 03:01 PM   #4
spezer
spezer's Avatar
Re: Pads
OK - might look at the iron rotors - pads sound good, but there are a lot of people commenting on the flex and issues with the 6 pots. I like them to clean and fit. 959 calipers sound good as a compromise to cost, but I don't know if my stainless lines bought for the gsxr calipers would fit? Would it be worth changing the MC?
Old 01-10-2011, 03:42 PM   #5
Armi
Superbike Champ
Armi's Avatar
Motorcycle: gsxr 750 srad with a few mods thanks to the members on this site.See signature.
Re: Pads
Have read alot of posts on brakes......Spl seems to now alot about them!
I think iirc he recommended first and for most no air in the system.
A good bleed, ss lines, good pads(i think vesrah were suggested)m/c upgrade, rotors and lastly the calipers....in that order.
I'm sure he'll chime in and correct me if i'm wrong!
Armi is offline   Reply With Quote
Old 01-10-2011, 03:52 PM   #6
Alfalfa
Alfalfa's Avatar
Re: Pads
Cheapest, quick fix would probably be the Honda calipers and some good pads. The lines you already have ought to be long enough, just look at the banjo placement on a CBR caliper of the variety you prefer, to make sure.
The pad surface area on the OE Tokicos is their downfall. As far as flex, I dare say unless you´re running ultra-fast laptimes or near endo braking maneuvers, you most likely won´t have that kinda problem.
Braking, BrakeTech and Galfer, among others, offer stainless steel replacement rotors with higher iron content than the originals.
Old 01-10-2011, 04:09 PM   #7
spezer
spezer's Avatar
Re: Pads
Cheers Alfalfa and everyone whos posted!!
Let you know what decision I take...
Old 01-10-2011, 04:17 PM   #8
Armi
Superbike Champ
Armi's Avatar
Re: Pads
http://www.gixxer.com/forums/showthr...=brake+upgrade
Old 01-10-2011, 04:32 PM   #9
Alfalfa
Alfalfa's Avatar
Talking Re: Pads
The search function DOES work!!
Old 01-11-2011, 06:24 AM   #10
spezer
spezer's Avatar
Re: Pads
I did search... Just thought I'd ask as it is 2011 - some reviews may have differed!!
Old 07-12-2011, 06:37 AM   #11
sushigxsr
Re: Pads
has anyone tried Galfer?
any feedback comparing the EBC HH would be nice.
thanks!
sushigxsr is offline   Reply With Quote
Old 07-12-2011, 07:44 AM   #12
HardRacing
Site Sponsor
HardRacing's Avatar
Motorcycle: 07 GSX-R1000, . OHLINS_MASTER_DEALER
Re: Pads
thanks!
Galfer offers Black Carbon Organic & HH Sintered Metal Pads.
Pad selection depends on what you use the bike, for....Street, Track or both.
Black Carbon Organic are closer to your OEM pads and usually give you better braking & feel over OEM. They are also easier on your rotors vs. the HH Pads.
HH Pads are made of a Sintered Metal that require a higher amount of heat to work effectively. So, for track days, aggressive street or race they work awesome once they are HOT! They are also a bit more aggressive to the rotors but last a bit longer than the Black Organic pads as well.
EBC HH pads are a great all around pad used by tons of guys. Cant really go wrong with either brand.
Hope that helps and ride safe..
. HardRacing.com - 704-799-2192
OHLINS_Premier_Dealer_Great_Prices, Tech_Support, Full_Staff_of_Sales Reps, Fast_Shipping, Large_Inventory and Excellent_Customer_service.
Become a FAN & And get Exclusive SMOKIN' Deals....
Celebrating our 14th year in business.
HardRacing is offline   Reply With Quote
Old 07-12-2011, 09:06 PM   #13
JustmyGixer
Motorcycle: GSXR 1000K2, GSV 250, GSXR 750 85
Re: Pads
If you are getting a lot of heat you must be on the track ??? if not then you are doing some serious street riding.
I was going to go the full hog on my K2 thousand with cast iron rotors and maybe Brimbo calipers, but after fitting a Brembo master cyl and putting on braided brake lines. This was a serious upgrade on the standard setup and for street riding was more than good enough.
Have done some track days and have not had problems with over heating. I think racing would prob show up some flex or heat problems and maybe warrant calipers and rotors, but ! i dont race and my current setup with the 6 pots works fairly well
Born to ride gixxers
JustmyGixer is offline   Reply With Quote
Old 07-14-2011, 08:30 AM   #14
REARSPROCKET
REARSPROCKET's Avatar
Motorcycle: K2 1K, 98 SRAD 750 Both B/W
Re: Pads
These work amazing--> http://www.streetandcomp.com/store/i...28%2D95&eq=&Tp= Along with a good set of lines.
REARSPROCKET is offline   Reply With Quote
Old 07-14-2011, 09:28 AM   #15
kwaka10r
Motorcycle: K1 1000, K7 750
Re: Pads
You're wasting your time with rotors and MCs and pads.
The trick calipers as Alfafa said are the 929 or 954 Nissans. They were used on CBR600Rs as well I believe.
Trust me, put those calipers on and you will be grinning in your helmet for days, they are really that good. I did the swap and they are better that the GSX-R radials by a noticeable amount.
You'll need to dremel the trailing edge 3mm or so where the caliper halves meet so the discs don't rub.
kwaka10r is offline   Reply With Quote
Old 07-15-2011, 03:35 AM   #16
kwaka10r
Re: Pads
Sorry meant to say leading edge or lower part of caliper.
Old 07-27-2011, 11:38 AM   #17
sushigxsr
Re: Pads
thanks! that helps alot HardRacing!!!
i'm going with Galfer, just because its a better the OEM...and i'm satisfied with OEM
Old 07-27-2011, 11:51 AM   #18
sushigxsr
Re: Pads
shoot...last minute change up...end up going with Ferodo HH Front brake pad set....
thinking i might do more track days then i'd expected...i guess...
Old 08-02-2011, 11:09 PM   #19
sushigxsr
Re: Pads
quick update on the installation today, the pads grabs alot on the street!!
Will test out on the track this weekend, hoping to get more read once the brakes gets heat up!
Old 08-03-2011, 12:06 AM   #20
Re: Pads
+1
And I've always been an advocate of Vesrah SJRL17's. Try as I might I could not get my setup to fade even a smidge last I was at VIR, and that was probably the hardest braking it's had to deal with yet.
In regards to caliper flex, it takes some seriously hard braking to induce the kind of flex that could be noticeable to someone who is not making podiums at the club level on a regular basis.
SPL170db is offline   Reply With Quote
