Chafing on my inner thighs/balls : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > General Discussion > Non-Motorcycle Forums > Health & Fitness
Old 04-14-2004, 09:59 PM   #1
bmacd
Superbike Racer
bmacd's Avatar
Motorcycle: '02 GSXR 600
i run/walk a combo of at least 4 miles every day now, sometimes 8-10 (mostly walking). I wear briefs style underwear and have tried thin and thick pants, but both still cause my thighs and balls to rub. I wouldn't post about this if it didn't cause me discomfort and i know other people have had to of gone through this. All joking aside, what do you suggest?
-=bmacd=-
bmacd is offline   Reply With Quote Quick reply to this message
Old 04-14-2004, 10:12 PM   #2
wtchtwr
Motorcycle: wtchtwr
Re: Chafing on my inner thighs/balls
OUCH....i would say some kind of powder....keep things sliding....i dont have this problem so i am not much help
wtchtwr is offline   Reply With Quote Quick reply to this message
Old 04-14-2004, 10:52 PM   #3
NABIT
Superbike Champ
Motorcycle: NABIT
boxer briefs or just cut them off to stop the Darwin cycle.......
J/K!!!!!!
NABIT is offline   Reply With Quote Quick reply to this message
Old 04-14-2004, 11:15 PM   #4
SVS
drunk texts OG and Oldfart
SVS's Avatar
Motorcycle: '08 KTM SuperDuke R, '99 SV650S, '84 XL600R
Petroleum jelly (Vaseline), a good layer of it on your balls and inner thighs - that'll help for sure. Yeah, I know - sounds gay, but it works
SVS is offline   Reply With Quote Quick reply to this message
Old 04-14-2004, 11:48 PM   #5
Jer
ΜΟΛΩΝ ΛΑΒΕ
Jer's Avatar
Motorcycle: K7 GSX-R1000 B/W (the fastest color)
I also get this. I even get it on my lats during the week from wearing tank tops while I lift. I can't just schmeer Vasaline on my sides... that would look slightly odd. What do you suggest for me?
Jer is offline   Reply With Quote Quick reply to this message
Old 04-15-2004, 11:16 AM   #6
Moss
Superbike Racer
Moss's Avatar
Motorcycle: Sold
A good Set of Boxer Briefs will help to stop it from happening when you work out. try out the Spandex kind. Baby powder or even Corn Starch helps with the pain once you have it (I use to be a mover, walking ALL day on hot days, and having to work the next day was no picnic!!)
Other than this, like SVS said Some Vaseline will help as well
Moss is offline   Reply With Quote Quick reply to this message
Old 04-15-2004, 11:53 AM   #7
affirefighter
Motorcycle: Mike D
Vaseline is very uncomfortable I would think. I used to get this, then I switched to boxers all the time, as far as the guy with the lats problem- Don't wear a tank top...
affirefighter is offline   Reply With Quote Quick reply to this message
Old 04-15-2004, 12:28 PM   #8
Griff
Griff's Avatar
Motorcycle: 2007 750
Buy a pair of compression shorts. Under Armour makes some, so does Nike. That will help too. Just make sure you wear some shorts OVER the compression shorts and not only the compression shorts
Griff is offline   Reply With Quote Quick reply to this message
Old 04-15-2004, 12:36 PM   #9
Spidey
Spidey's Avatar
Motorcycle: 1989 Huffy, pink, with a basket!
haahaHAHAHAHAH!!!!
The under armor shorts should help... I've never had this problem myself, but a guy I know uses "Gold Bond" and swears by it. It's kinda like baby powder I think. Made specifically for chafing.
Spidey is offline   Reply With Quote Quick reply to this message
Old 04-15-2004, 02:41 PM   #10
GixieChick
Motorcycle: redhot_gixiechick
Not that I didn't enjoy reading this But my boyfriend walks a million and one miles a day at work, in long pants, in heat, and gets it. He uses gold bond, and swears by it.
GixieChick is offline   Reply With Quote Quick reply to this message
Old 04-15-2004, 03:50 PM   #11
SicShift
Superbike Champ
SicShift's Avatar
Motorcycle: SicShift
wrap some ace bandages around them!
SicShift is offline   Reply With Quote Quick reply to this message
Old 04-15-2004, 04:56 PM   #12
Fiddy_Ryder
Cock Thumb, or Thumb Cock? You decide.
Fiddy_Ryder's Avatar
or you could use that liquid bandage called new skin, and coat your nuts with it
Fiddy_Ryder is offline   Reply With Quote Quick reply to this message
Old 04-15-2004, 07:35 PM   #13
gixboy600
Motorcycle: Bryan
gotta rock the spandex, if im playing sports or doing anything phsyically active i always wear then. your problems will be nonexistent
gixboy600 is offline   Reply With Quote Quick reply to this message
Old 04-19-2004, 10:30 AM   #14
ryu750
ryu750's Avatar
Motorcycle: Your Girl
GET A JOCK STRAP AND SOME BIKING SHORTS!!!
ryu750 is offline   Reply With Quote Quick reply to this message
Old 04-19-2004, 11:51 AM   #15
Jer
ΜΟΛΩΝ ΛΑΒΕ
Jer's Avatar
Okay, but those will look kind of silly under my arm pits!
Old 04-20-2004, 02:21 AM   #16
Suzuki Duke
PM me for Brotection
Suzuki Duke's Avatar
Motorcycle: 01 996 & DRZ400 Motard
As far as the chafing in your crotch, some compression shorts or shorts with a built in liner like running short style will help with the ball chafing. The thighs will still rub, so vaseline, or better yet, bodyglide to stop the friction. I used to use vaseline, but now I use bodyglide for my long runs. It comes in a stick and goes on like deoderant. www.bodyglide.com Your local running store should have it.
Suzuki Duke is offline   Reply With Quote Quick reply to this message
Old 04-20-2004, 05:40 AM   #17
RepulsioN
Supersport Racer
RepulsioN's Avatar
Motorcycle: k6 1k
I use vaseline like others have said on long runs.
I find that tracksters rub my bollocks something chronic after long periods - a decent fitting pair of lined football (soccer) shorts or running shorts with nothing under them seem to be the best bet for not rubbing - but if Im out for more than 20 miles I will still use a bit of vaseline.
vaseline can be good at stoping your nipples rubbing against your tshirt to on long runs to.
apparantly lycra cycling shorts dont rub at all, but they look gayer than gay and there is no way I would wear a pair of those things whilst running.
It can be very embarrassing buying big jars of vaseline though it has to be said.
RepulsioN is offline   Reply With Quote Quick reply to this message
Yamaha Motorcycles Victory Gunner Forum Victory Charger Forum Honda Vultus Forum HD LiveWire Forum Ninja H2 Forum Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
