Hey.. I am on Wera mostly just figured Id see if anyone needed anything on here. Im not a dealer but Ive come across a few good deals on bikes and have some for parts. Pickup welcomed in Tampa at my home or I accept paypal and ship same day always with tracking.
Call/Text me at 813 357 9268. I use the same name on Wera and Ebay for reference. PLEASE TELL ME WHAT BIKE as I have a few as you can see. I dont buy bikes to part them all the time so do not call to ask if I will be getting anything else in soon.
I have-
06 gsxr600 (06-07 600-750)
07 gsxr600 (06-07 600-750)
04 gsxr600 (04-05 600-750)
05 gsxr600 (04-05 600-750)
06 gsxr1000 (05-06 1000)
03 gsxr1000 (03-04 1000)
If its not listed its sold no question about it so please READ THE LIST PLEASE!! A lot of parts are already sold as I have had the bikes for a little while now.
Pictures-
2006 GSXR600-
http://s932.photobucket.com/albums/a...%20GSXR%20600/
2007 GSXR600-
http://s932.photobucket.com/albums/a...%20Part%20Out/
2006 GSXR1000-
http://s932.photobucket.com/albums/a...20GSXR%201000/
2005 GSXR600-
2004 GSXR600-
2004 & 2005 GSXR 600 (04-05)
Red Frame Sliders (tiny hideable scuff)- $10
TRE Mod- $10
Dented Flat Black Tank- $25
Front Fender (back right tab broke)- $10
Exhaust Header- $35
Front Seat- $20
Aftermarket Undertail w/ Blinkers- $20
AirBox- $10
2) Coolant Reservoir- $5
Front Calipers- $50
\Steering Dampner- $15
2) Kickstand Switch
Chain Gaurd- $10
Gas Tank Side Plastics- $20
2) Rear Caliper- $25
2) Rear Caliper Bracket- $15
Rear Brake Line - $5
45T Rear Sprocket- $10
2) Cush Drive- $10
Left Side ClipOn- $35
Front Axle- $10
Rear Axle- $10
2) Swingarm Bolt
2) Starter Relay- $5
Rear Brake Reservoir- $10
2) Trunk Lock Cable- $5
Swingarm Spools (small scuff on one)- $15
Trunk Latch- $15
2) Horn- $5
Bar End (edge needs paint)- $5
Bolt Kit- $35
Engine Inner Fairing- $5
Middle & Left Inner Fairings- $15
Lower Triple Tree Inner Fairing= $5
2) Throttle Cables- $5
Front Reservoir Bracket- $10
Front Reservoir Cap- $5
Wheel Spacer- $5
Shifter Linkage- $5
Clutch Adjustment Wheel- $5
OEM DogBones- $5
Headlight Bulb Rubber Boots- $5
OEM Grip- $5
2006 2007 GSXR600 GSXR750
1) Clutch Safety Switch- $10
1) Set Aftermarket Clear Blue Grips- $10
1) Left Electrical Switch Headlights Horn- $35
1) Bar End- $5
1) Complete Bolt Kit- $40
1) Right Fairing slight scuffs Blk/Gry (tiny crack nothing broken) $40
1) Left BOTTOM Side Fairing (black piece) $20
1) Right Tail Section Grey- $40
2) Rear Fender- $15
2) Steering Damper- $15
1) Rear Caliper Good Pads- $25
1) Rear Caliper Bracket- $10
2) Rear Rotor- $25
2) Rear Brake Fluid Reservoir- $10
1) Taillight- $20
1) Kickstand- $10
2) Cooling Fan- $20
1) Wire Harness- $40
2) Air Intake Box- $15
2) Rear Sprocket- $15
1) Rear Axle Bolt- $5
1) Trunk Latch- $10
1) Starter Relay- $10
1) Throttle Cables- $5
1) Bolt Kit- $40
2006 SUZUKI GSXR 1000 (05-06)-
Right Mid Fairing Only (grey part w/GSXR logo)- $75
Side Tail Fairing Right- $45
Right Clip On Handlebar- $25
Brake Lever- $10
Clutch Lever- $10
Grips- $10
Clutch Perch & Safety Switch- $15
Servo Motor- $25
Exhaust Servo Cables- $5
Upper Fairing NO DAMAGE $90
Rear Fender- $15
Right Pass Foot Peg & Bracket- $25
Stock Front Seat- $15
Kickstand- $15
Throttle Cables- $5
Votex Rear Sprocket- $15
Axel Bolts Front & Rear- $5 each
Starter Relay- $5
2003 2004 GSXR1000
-1) Front Rotor $25
-Rear Rotor- $25
-Trunk Latch- $10
-ClipOn Handle Bars- $35ea
-Vortex ClipOn Handle Bars- $35
-Kickstand- $10
-Kickstand Switch- $5
-Clutch Lever- $10
-Inner Fairing Right Side- $10
-Horn- $5
-Exhaust Servo & Cables- $25
-Bolt Kit- $30
-Throttle Tube- $5
