Right start button problems help please :( : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > GSX-R1000 General Forum > 05-06 GSX-R1000
Old 09-01-2010, 02:05 PM   #1
islandking1000
Ok so i was driving home lastnight and my headlight started flashing on and off then all the sudden they just went out, once i got home i turned the bike off and tryed to start it up the button isnt work and my headlights arent on.
do i need a new kill/start switch or is it something else?
islandking1000 is offline   Reply With Quote
Old 09-01-2010, 02:10 PM   #2
Lean With It
Superbike Champ
Lean With It's Avatar
Motorcycle: 1999 GSXR 750 F.I.(modded - street/track) - 1997 GSXR 600 race bike (modded)
Re: Right start button problems help please :(
did you turn the key?
check fuses and connectors in the wiring harness.
If those check out ok - check to make sure power is getting to the fuses and connectors and the start switch. You will need a multimeter, simple tools, and about 15 minutes.
then post up.
Lean With It is offline   Reply With Quote
Old 09-01-2010, 02:24 PM   #3
islandking1000
key is turned fuses are good the kill/start switch is getting power cause the fuel pump still kicks on. the button use to cause my headlights to flicker on and off and finaly it has just gone out all together no lights and the button wont work
Old 09-01-2010, 03:45 PM   #4
Lean With It
Superbike Champ
had no idea the headlights were connected to the kill switch or start button...on any bike.
if the switch housing that has our hi/lo beam selector on it is not working, take it apart and inspect it. You may find you have to clean the copper plate inside or a solder point has come loose.
Old 09-01-2010, 03:55 PM   #5
svendorrian
svendorrian's Avatar
Motorcycle: 2005 Suzuki GSX-R1000
Whenever I have seen this in the past it was due to the charging system going bad. When this happened the bike would run straight off the battery until the battery went dead. Before the headlight went out, with many bikes you could tell because if the charging system was working (if you look closely) you could see the jump in power in the light when you would rev the throttle from idle. When the charging system fail you would not see this at all, just a fading out, then no light, then the bike stops.
If your bike's charging system is running, once it is started, you could disengage the battery and the bike's charging system will close the loop, as if the battery was still connected.
Once it is started and running, if you dis connect the battery and the bike stops, your bike's charging system may need to be replaced.
I have used a car battery (car engine off or disconnected) to jump start a bike and give a little "oomph" to the bike's battery, if it is not completely drained with no problems.... I am NOT telling anyone to do this, however.
I am not telling you what to do, just my thoughts on it.
I don't know if this helps, but that's my idea.
2005 Jared/Sewell Suzuki GSXR 1000. K&N, Power Commander, TRE, High Performance Spark Plugs and Wires, Valve Work, Adverse Weather blue tinted headlight, Avon Viper Supersports, Fairing Protectors, Modified Titanium Exhaust Full System, MSF and shop decals, safety wired, steel braided lines. "Street legal" Circuit Bike.
svendorrian is offline   Reply With Quote
Old 09-01-2010, 04:31 PM   #6
islandking1000
the high-low beam switch works fine its the right side start button when i press it nothing happens. the button and my headlights both went out at the same time, use to start button would cause my lights to flicker not due to powerloss when i press the button in to start it the lights go out for a split second untill i let off the button and the bike starts. now when i try and start it the button does nothing and my lights are still out do i need to get a new right switch to fix this? also the bike did not stop or die i still have power the fuel pump works blinkers tail lights etc. just not my start button or headlights
Old 09-01-2010, 09:39 PM   #7
svendorrian
The terminals in the switch may be dirty.
You can try disassembly and cleaning or replace the switch.
Old 09-01-2010, 09:41 PM   #8
svendorrian
The switch may have dirt in it.
Old 09-01-2010, 09:42 PM   #9
svendorrian
Old 09-01-2010, 09:43 PM   #10
svendorrian
Old 09-01-2010, 09:56 PM   #11
oldfart01
Dope With A Rope
oldfart01's Avatar
Motorcycle: Dromaius Novaehollandiae
I think he got it the first time! Freaking wacky site, I think Moto Bro fucked it all up. Either try to clean the contacts, check for loose wires in switch, or replace it.
oldfart01 is offline   Reply With Quote
Old 09-01-2010, 11:23 PM   #12
BillV
Motorcycle: Blue 2006 GSX-R1000
You seemed to say that both the high and low beam started flashing on/off and them went out. What about the console backlight? If it was flashing too, the B/W ground at the connector in the left cowl might be bad. If only both headlights were flashing, the problem is probably in the power to the lights. Turn the ignition on and measure the voltage at the Horn/Brake and Ignition fuses. If the voltage is zero (or low) either the ignition switch is bad or it's not getting power. If it's +12, measure the voltage at the headlamp fuses. If it's zero, there's a problem with the Start switch or the associated wiring.
BillV is offline   Reply With Quote
Old 09-08-2010, 08:49 PM   #13
2bad4u
Motorcycle: 2005 gsxr 1000
DUde its your kill switch take off the red cover and clean the connection I had the same problem. the connection just needs a little sand paper and make sure you gently pry the connection point.
2bad4u is offline   Reply With Quote
Old 09-09-2010, 11:54 PM   #14
MAD_ARAB
MAD_ARAB's Avatar
Motorcycle: A revamped K6 liter
My bike is doing the same thing. I've traced it to the starter switch as well. I'll probably try cleaning it this weekend. Right now I have a jumper wire in the fusebox so I have lights.
MAD_ARAB is offline   Reply With Quote
Old 09-10-2010, 12:30 PM   #15
BillV
What NOS says makes sense as the starter switch cuts power to all of the various lights while the bike is cranking. A jumper from the top (I think) of either the Horn/Brake or Ignition fuse to the top (I again think) of either headlight switch will bypass the switch but the bike will probably crank a bit weaker as the lights will stay on. The real solution is to take the switch apart and clean the contacts but cycling the switch a bunch of times with the ignition switch off may be enough to get it to work for a while.
Old 09-10-2010, 12:35 PM   #16
MAD_ARAB
MAD_ARAB's Avatar
Yeah Bill right now my lights don't turn off when I start the bike but it doesn't crank any slower than normal as far as I can tell. I still have the original battery in my bike as well.
Old 09-10-2010, 12:57 PM   #17
Lean With It
Superbike Champ
I was scrolling down and read his first post...then the next...and the next hahaha i was like damn wtf
Old 09-11-2010, 05:34 PM   #18
MAD_ARAB
MAD_ARAB's Avatar
I tore mine all apart today. The starter switch assembly is ok. The issue is with the plug on the end of it. It sits right on top of the valve cover and because I ride my bike in the rain water gets up there and corrodes the connection. Suzuki doesn't use a sealed plug so water is able to get into it from the backside. Cleaned the connection and it works for now. I left the small jumperwire loose in the fusebox so I can hotwire it in an emergency if I need to.
