New gen gauge swap info/instructions - Page 3 : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 11-29-2005, 02:15 PM   #41
bigguido
Motorcycle: Dwayne
Re: New gen gauge swap info/instructions
I need to fab a bracket to house my 03/04 gauge housing. Anyone got any pics of their install?
Just zip tie it to the srad bracket you can't see it when the fairing is installed and if you bolt it on if you need to remove it you have take the front of the bike apart you seen mine it's just zip tied in there i have no problems reading it if you make sure it's tight.....
bigguido is offline   Reply With Quote
Old 12-26-2005, 05:51 AM   #42
OddJob_585
So wait...are u guys hooking up newer gauges to an older motor and ecu/electronics? or will someone swapping in a newer motor (is:1000 swap) and gauge also be throwing warning lights too.
OddJob_585 is offline   Reply With Quote
Old 12-26-2005, 06:12 AM   #43
gsxrcraven
gsxrcraven's Avatar
Motorcycle: GSX-R 750 1997
what about getting it straight you got round that bit yet??
gsxrcraven is offline   Reply With Quote
Old 01-09-2006, 04:19 PM   #44
kYE
kYE's Avatar
Motorcycle: SRAD 6/10
i'm putting an 02 1k in my 97 600 complete with wiring loom. does anyone know if an 05 guage will work?
kYE is offline   Reply With Quote
Old 01-15-2006, 08:00 PM   #45
monsterfiveo
monsterfiveo's Avatar
Motorcycle: 04 GSXR 600
hmm... why can't you just get the gauge and plug it into the socket? i mean like is it okay to just buy a 01 600 gauge and then just plug it into the new one? my 98 gsxr 600 doesnt have f.i. that's ok right?
monsterfiveo is offline   Reply With Quote
Old 01-15-2006, 10:22 PM   #46
jassing
jassing's Avatar
Motorcycle: 98 GSXR 750
because the pinouts are different.
becuase two of the wires appear to send different signals.
becuase you need an "always hot" lead to power the clock.
jassing is offline   Reply With Quote
Old 01-16-2006, 05:49 PM   #47
kYE
kYE's Avatar
yeah, ive read that the wiring to the plugs is different. i havent got the gauges yet, they're on their way. but even if the plugs are the same, the wiring is not... i think?
i know that the gear change indicator and the shift light wont work, i'm not worried about that. as long as the tach, speed, temp and warning lights work, i'll be happy. it sounds like no-one has tried it?
Old 01-20-2006, 03:10 PM   #48
jassing
jassing's Avatar
I have tried it.
for the most part it works.
the FI light stays on tho....
Old 01-25-2006, 01:15 PM   #49
kaker123
Motorcycle: christopher kaker
i have a 97 750 that i put 03 guages on, the fuel injection light blinks when i kill it, but does not stay on, however the "CHEC" always appears and the low fuel light also always appear. i am almost to the point of putting an analog temp guage on it. the guages are nice thought, between them, the 92 yamaha headlights and the shark skinz, it really throws people off.
kaker123 is offline   Reply With Quote
Old 01-25-2006, 01:49 PM   #50
Thruan
Thruan's Avatar
Motorcycle: 96 srad "750", worked
hey, has anyone figured this out yet??
Thruan is offline   Reply With Quote
Old 01-25-2006, 01:57 PM   #51
jassing
jassing's Avatar
No I don't think so.
I was hopeful that it was a case of something like:
OLD Style: Close the loop to alert
NEW style: Open the loop to alert
and it'd be a simple relay or transister would "fix" the problem -- but looks like it's not that simple.
Someone touting "electrical engineer" skills said they'd solve it -- haven't heard from them.
I'm getting ready to sell my 2001 750 guage (complete with "blue guage"s)
Old 02-06-2006, 11:41 AM   #52
Thruan
Thruan's Avatar
well i would buy ya gauges but ur abit far and i want to do the conversion with 0 probs...
Old 02-06-2006, 09:56 PM   #53
srad750-eire
srad750-eire's Avatar
Motorcycle: 1999 GSXR 750 SRAD with a Y engine, Blue Flame exhuast, TRE, PCII, undertray and tidy tail.
How much would you be willing to let the gauges go for?
J.
srad750-eire is offline   Reply With Quote
Old 02-08-2006, 07:14 AM   #54
RADikal
Motorcycle: 99 -750, 06 Busa, 96 Vulcan Classic
not sure, but these may help...got this from the "other" site
http://www.black-hole.co.uk/secure/books/gsxr600/
user name gsxr600
pasword h54Sg83d
RADikal is offline   Reply With Quote
Old 02-08-2006, 03:44 PM   #55
RADikal
here is the pin matchup again...note, on the old side, 16 & 13 are blank, so, you could match them kinda like i've matched them here. For right now, i've just matched the wiring, haven't really connected anything just yet...
New - Old
1 - 12 ignition
2 - 13 + 12v constant
3 - 1 High Beam
4 - 9 R-Turn
5 - 10 L-Turn
6 - 6 Oil
7 - 7 Temp (sensor)
8 - 11 Tacho
9 - 3 Illumination
10 - 8 Temp
11 - 2 Neutral
12 - 15 Speed Sensor
13 - 16 empty
14 - 4 Fuel A
15 - 5 Fuel B
16 - 14 Speed Plus
Old 02-12-2006, 02:48 AM   #56
jassing
jassing's Avatar
I forget what I"m into it for; I think about 250; but I wouldn't expect that much.
I haven't given up all hope yet; just most of it... <G>
Old 02-12-2006, 08:25 PM   #57
srad750-eire
No bother,
I come from a physics / computers / electronics background. I have sourced a load of a set of clocks from a K1 from a friend that is race preping a bike. I'll have a look using some of the equipment I have and see what I can suss out.
Old 02-16-2006, 02:43 AM   #58
johnie_nolaw
I have a speedo off a '02 GSXR1000 and I'm going to mod to my 1997 GSXR11000. My question is what year harnesses will plug into this speedo...From reading this post a speedo harness from the following work?
'97 - '00 GSXR600
'96 - '99 GSXR750
'01 - '03 GSXR600
'00 - 03 GSXR750
'01 - '02 GSXR1000
Just want to make sure before I go eBay shopping.
Thankx for the help
jnl
johnie_nolaw is offline   Reply With Quote
Old 02-28-2006, 05:53 AM   #59
DRAGON
Motorcycle: 87 1100 00 600 02 r1
so no ones figured out the temp thing yet? warning lights arent bad but i dont want to over heat and not know it
DRAGON is offline   Reply With Quote
Old 02-28-2006, 12:34 PM   #60
turbomustang
turbomustang's Avatar
Motorcycle: 06 GSX-R 1K, 06 ZX-6R 636
If someone donates a gauge set to me, I could probably figure it out. I actually am an electrical engineer.
turbomustang is offline   Reply With Quote
