i need help : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 08-18-2010, 11:09 PM   #1
bigmattmacky
bigmattmacky's Avatar
Motorcycle: 97 gsxr 750 srad
i need help
i have a 97 gsxr 750 and when i start the bike it runs for about 7 seconds then floods out. what i noticed is that carbs 3 and 4 both seem to be getting a lot of fuel spraying out the carbs and it seems like the bike floods. also i noticed when i turn the key on and it primes gas comes out og the tube that goes to the air box between 3 and 4 while the stem at 1 and 2 is clear. i pulled the plug on the fuel pump and started the bike and there was no excess gas spitting out of and 3 and 4 and the bike ran way better. if you have any ideas of what could be causing this let me know.. if you need more info just ask ..... petcock? carbs?
bigmattmacky is offline   Reply With Quote
Old 08-19-2010, 12:08 AM   #2
GSXR-Freak
Superbike Champ
GSXR-Freak's Avatar
Motorcycle: 99 GSXR 750
Re: i need help
Stuck floats on #3 and 4
GSXR-Freak is offline   Reply With Quote
Old 08-19-2010, 07:18 AM   #3
eagling0716
eagling0716's Avatar
Motorcycle: 2004 GSXR 600
Re: i need help
i have the same bike and someone had fucked up two of the pilot jets, and two cylinders would flood just the same. Just check the size of the bottom hole on the pilot, make sure its right.
eagling0716 is offline   Reply With Quote
Old 08-19-2010, 07:24 AM   #4
ccmhunt
Carb Ninja
ccmhunt's Avatar
Motorcycle: 96 GSXR750, 07 CBR1000RR
Re: i need help
a too large pilot jet won't make it overflow, just fowl plugs....a stuck float will send fuel out the overflow tubes
ccmhunt is online now   Reply With Quote
Old 08-19-2010, 07:25 AM   #5
eagling0716
Re: i need help
thanks god for you guys, sorry!
Old 08-19-2010, 07:12 PM   #6
bigmattmacky
Re: i need help
so thats what i should do is rebuild the carbs right? this is my first bike and i dont know much about carbs but i do know mechanics pretty well i just never worked on carbs do u think i can do it my self any advice/
Old 08-19-2010, 07:54 PM   #7
bigmattmacky
Re: i need help
where can i get the parts?
Old 08-19-2010, 09:55 PM   #8
nykuryu
nykuryu's Avatar
Motorcycle: 07 600
Re: i need help
if its just the pilots you dont need to reuild. just pull carbs off, take off bottom cover plate, unscrew pilots jets, install new pilot jets, reinstall. most bike stores will carry them. some will even trade jets.
nykuryu is offline   Reply With Quote
Old 08-19-2010, 10:27 PM   #9
ccmhunt
Carb Ninja
ccmhunt's Avatar
Re: i need help
