turn signal will not blink : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > Water Cooled Gixxers
Old 08-05-2010, 07:08 AM   #1
kev2004
I just installed bar end turn signals on my 93' 1100. When I hit the turn signal button the signal will light up and stay on but will not blink. Is this a relay issue? I know some led signals will flash really fast if you do not have resistors but never heard of them not blinking. I do not have any resistors or anything yet.
kev2004 is offline   Reply With Quote Quick reply to this message
Old 08-05-2010, 07:29 AM   #2
600k2
Motorcycle: 600k2
Re: turn signal will not blink
you need resistors in the circuit, wired in parallel. you may also need an electronic flasher if you are running led turn signals in the rear too. try replacing the LED turn signals with a test light and see if the test light blinks.
600k2 is online now   Reply With Quote Quick reply to this message
Old 08-05-2010, 07:29 AM   #3
RoamingBison
Fortunae Nihil
RoamingBison's Avatar
Motorcycle: 1994 GSXR-1100W(R)
Mechanical flasher relay - likely doesn't like the LED set-up. You need the resistors in place before you can properly diagnose this one. Alternatively, wire them to the rear flashers temporarily and see if you get the same result.
RoamingBison is offline   Reply With Quote Quick reply to this message
Old 08-05-2010, 07:59 AM   #4
fireforeffect49
fireforeffect49's Avatar
Motorcycle: '98 GSX-R1117, '92 FXSTC
LEDs aren't drawing enough current to trigger the flasher unit.
fireforeffect49 is offline   Reply With Quote Quick reply to this message
Old 08-05-2010, 10:24 AM   #5
mdillon
Superbike Racer
mdillon's Avatar
Motorcycle: 94 750
most led signals come with resistors for this problem, did you see any in the packaging?
mdillon is offline   Reply With Quote Quick reply to this message
Old 08-05-2010, 12:35 PM   #6
kev2004
there weren't any with the lights. I am not going to run rear signals, so would the resistors cure this? I have heard some older bikes will stop flashing if one of the 4 bulbs are out and since I am only running two??? Would this cause this?
Old 08-05-2010, 12:37 PM   #7
mdillon
Superbike Racer
mdillon's Avatar
Motorcycle: 94 750
maybe. why no rear signals?
Old 08-05-2010, 12:37 PM   #8
600k2
Motorcycle: 600k2
if you only want to run 2 led turn signals and no regular bulbs you need resistors and an electronic flasher. you are not drawing enough amps for the flasher to work
Search this Thread:
Advanced Search
