steering damper fitting : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 08-03-2010, 12:40 PM   #1
luckycon
ive just bought a sprint steering damper for my 1989 gsxr fighter theres no fitting kit available but i cant see how to secure it, any ideas?
luckycon is offline   Reply With Quote
Old 08-03-2010, 12:51 PM   #2
ghostrider.1127
ghostrider.1127's Avatar
Motorcycle: few gsx-r
Re: steering damper fitting
what kind of steering damper ????
picture maybe...........
ghostrider.1127 is offline   Reply With Quote
Old 08-03-2010, 01:23 PM   #3
jdmcb3si
jdmcb3si's Avatar
Motorcycle: 1992 gsxr 750
He stated it's a Sprint damper.
Oh and to The OP good luck getting an answer. II asked the same thing and still have no answer. But you'll probably get a few PMa about whether you'll sell it instead of mounting it.
jdmcb3si is offline   Reply With Quote
Old 08-03-2010, 01:25 PM   #4
jackbird_xx
Supersport Racer
jackbird_xx's Avatar
Motorcycle: '85 GSX-R w/ Limited Dry-clutch, '85, '86 GSX-R750, '87 GSX-R750, '94 CBR600f2, YSR 80cc
Well that sounded absolutely positive.
hehe... j/k
jackbird_xx is offline   Reply With Quote
Old 08-03-2010, 01:33 PM   #5
luckycon
correct the make is sprint, but in the sprint catalogue it doesnt have a fitting kit listed and the kid in hein gericke recogns that it just bolts on the btm yoke somewere but i cant find were,
Old 08-03-2010, 02:07 PM   #6
javadog
Yoshimura junkie
javadog's Avatar
Motorcycle: 1986 GSX-R750R, 1986 GSX-R1100, 1989 GSX-R750RR, 1997 GSX-R750, 2001 GSX-R1000, 2001 Bandit 1200S, plus a few others.
Have a shop install it for you.
I'd suggest doing what Suzuki did for the RK in 1989. Drill a hole in the left lower frame/headstock brace and install a metric Riv-nut. Add a 43mm steering damper clamp to the left fork leg. Dozens of people make these... Then, bolt the damper between the two points and adjust it so the there is no binding between the various components and the damper doesn't bottom out in either direction.
JR
javadog is offline   Reply With Quote
Old 08-03-2010, 02:24 PM   #7
luckycon
thanks for the help jr just having a look on ebay etc at the minuite
Old 08-03-2010, 09:39 PM   #8
ghostrider.1127
aaaaaaaaaaaah sorry it s a sprint damper......
good luck
