Bike cuts out at high RPM, Injector Signal C32-C35 FI Codes. HELP : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > GSX-R600 / GSX-R750 General forum
Old 07-29-2010, 01:51 AM   #1
Junkyard600
Junkyard600's Avatar
First of My bike is an 04 GSX-R 600.
Modifications that may be valid- Power Commander, Yoshimura stage R Cams, K&N filter, stock headers, and HotBodies under-tail exhaust.
As far as Wiring Harness- Kickstand cutoff has been disabled, front blinkers are not on the bike, Hot Bodies under-tail blinkers are spliced in, as well as an aftermarket license plate light. Usually have to move handle bars back and forth while holding starter button to get the bike to start.
What is happening- It started by me going through town then I hit the highway where my rpm's got higher then my bike cut off and a red light came on along with FI on my dash. I popped the clutch and gassed it a few times in order to get down the road and this would crank the engine and allow me to drive for a few seconds before shutting off. While all this is happening I the kill switch was still on and key still turned. It also fluctuated between shutting off and showing an FI and shutting off with a loss of all power (no dash display or lights). Seems to only do it when I'm driving because I stopped and revved it in neutral and it did not cut out but I may have just not tried hard enough. Also it decides when it wants to start because sometimes I will turn the key and there is no power and other times ill turn the key, get power then when I try and start it it will pop and cut out. It will also sometimes turn on, start and run fine and drive fine till I really get on it and any one of the many things I listed above may happen.
What I have done so far- I put my bike in dealer mode and retrieved FI codes C32 C33 C34 & C35 which all are Injector Signal errors for injectors #1-#4. If I turn my bike on it will not display these until I drive it and force it to cut out. I have looked through my wiring but have not found any melted, cut, or stripped wires. I also have checked my connections and everything seems tight. Tip Sensor is secure. Battery seems to have a good charge and is relatively new and fuses are all good.
What I think it could be- PowerCommander is having issues, my bike was dyno tuned and the map I pulled from the commander was on a computer that crashed but I may be able to recover the hard drive. I'm thinking I might need to re-load that map or get it tuned again. Also having this shitty HotBodies undertail exhaust right by my electrical components I am worried something may have failed.
If you guys know what this issue is, have had this issue, or have any ideas please post them. I need to get this bike up soon because I use it daily.
Below is a picture of what it looks like under my seat, and I pulled up some of the sensors and connections encase anyone knows if any of these need to be mounted any particular way
Next is a video of me trying to start the bike
Last is a video of the bike running after I took it out and forced it to stall then I popped the clutch started it again and drove it home.
Hope yall can help.
Thanks
Ryan
Junkyard600 is offline   Reply With Quote
Old 08-02-2010, 10:31 PM   #2
Junkyard600
Re: Bike cuts out at high RPM, Injector Signal C32-C35 FI Codes. HELP
No Ideas from anyone?
Old 08-02-2010, 10:44 PM   #3
Samantha750
Scandinavian Mod with PMS
Samantha750's Avatar
Motorcycle: Two wheels and goes VROOM, VROOM
I would try posting this in here: http://www.gixxer.com/forums/forumdisplay.php?f=66
Perhaps the heat generated from the under tail exhaust damaged your power commander and/or your ECU as I would imagine it gets hot under there.
Samantha750 is offline   Reply With Quote
Old 08-18-2010, 01:24 AM   #4
speedytom545
speedytom545's Avatar
Motorcycle: 04 GSXR 600
did you check your batt terminals? also did you disconnect power commander and just hook your injectors up to run how it was stock? i would look at those two things. all fuses good? screws tight on your batt. and starter relay?
speedytom545 is offline   Reply With Quote
Old 11-08-2010, 04:14 PM   #5
JaySXR6
Motorcycle: 2005 GSX-R600
don't know if you figured it out but i was having the same issue and found out that my HotBodies Exhaust was over heating the ECU had to have it replaced and reheat shield the area.... I am looking to get rid of the exhaust though... it is burning through my seats and fairings
JaySXR6 is offline   Reply With Quote
Old 11-08-2010, 07:44 PM   #6
Junkyard600
Nope that was not a problem it was actually a main power wire grounding out on the front of my frame. That in conjunction with a bad battery that went bad because of this problem.
Old 11-12-2010, 09:56 PM   #7
I'm-a-punk
I'm-a-punk's Avatar
Motorcycle: 03 GSXR 600 - 05 GSXR 600 - 03 Honda Ruckus
you couldnt post in the 04/05 forum.. this is why you got a Tard, cause your bike runs like shit and you cant fixed it, so you sell it to someone else..
I'm-a-punk is offline   Reply With Quote
