7 - 11 Racer problems : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 07-21-2010, 10:18 PM   #1
Kangaland
Kangaland's Avatar
Motorcycle: gsxr 7/1100 racer
Hi all,
I currently race a gsxr in Australia in a post classic road racing series(PCRA of NSW http://www.postclassicracing.com.au/ )Ita a 1989 Gsxr 750 and have just fitted a 1st gen 1100 motor,Yosh exhuast,38mm slingshot carbs with stage 3 dynojet kit and Ul 98 race fuel running on 192 main jets.
Problems im having with it is getting the bike of the line at start as the clutch is just too grabby and wheelies at slightest chance(750 engine shot of the line like a rocket with no such problems)and secondly keeping it cool.
Ppl have said i should use a braided clutch line others said change plates even told to fit a 2 stage clutch,but ppl in aus know stuff all about early gsxr's here so thought id ask the guys in the know.
Also has anyone ran a second smaller cooler behind front fairing like the F1 racers of there time (see attached pic)and had any issues with oil pumps ect.
Any help or advice will be appretiated on this or anything else.
Thanking you.
P.s see my blunder starts on you tube
Kangaland is offline   Reply With Quote
Old 07-21-2010, 11:31 PM   #2
LSC86
LSC86's Avatar
Motorcycle: '86 GSXR-750
Re: 7 - 11 Racer problems
If you're running the cable clutch conversion, you should be able to run heavy duty springs and good plates and slip the heck out of it to keep the front end down- just have to launch just beyond the torque curve, probably in the 6000 range. But with the 5-speed trans, keep the oil changed after every race to avoid clutch fibers plugging the oil pickup and burning up the engine. 6-speed setups can launch in 2nd gear with no problems.
Longer '90 1100 swingarm helps too, but then you negate the better handling of the 750 chassis. Playing with shock springs and settings can help too. Practice really is the key in my experience. Motul or other high quality full synthetic oil will help. Also, running the curved oil cooler from the '90 750 will help as well.
Got Oil?
LSC86 is offline   Reply With Quote
Old 07-22-2010, 12:06 PM   #3
bsully1850
bsully1850's Avatar
Motorcycle: VTX1800, Building a 1990 GSXR 750 with Lots of Goodies.
Off Topic, but any chance you know where to get a tank that will work with that cold air kit pictured? Or someone that can modify a tank?
bsully1850 is offline   Reply With Quote
Old 07-22-2010, 02:54 PM   #4
86gixxxer
86gixxxer's Avatar
Motorcycle: first gen 750's & a '99 750
welcome and thanks for posting the video!
can't help you with 1052 clutch grabbiness, but on my mostly stock 749 trackbikes, i found out that the stock suzuki plates and springs worked better and lasted longer than aftermarket. what plates/springs are you running?
seems like you have good top-end. i am going to tryout some stock 90-92 750s 38mm carbs on my mildly built 749 with 1mm high compression pistons and such. what do you think of the 38's? what air filters are you running?
post some fotos of your bike.
86gixxxer is offline   Reply With Quote
Old 07-22-2010, 05:56 PM   #5
Kangaland
Kangaland's Avatar
I ran the 38mm carbs on the 90 model 750 as they were standard for it,i put a dyno jet kit through it with a significant gain through the rev range but noticably top end.I was concidering flat slides but with standard motor didnt think it would be of value yet.But yes i would recomend them as my 750 held even with fzr1000's doen the straight.
After fitting the kit i was up to 137 mains up from 117,we put the standard springs back in the slides(as the dyno kit ones were too soft and touchy on throttle)rasised the needle 2 slots and got 106 rwhp with a nice smooth curve.Im running the 150mm long uni filters as i think it creates more air reserve air then the shorter pods and also advanced timing 5 degrees.
Im running the 90 model curved radiator with the 1100 and fitted a cooler behind fairing.
Also what oil viscosity do yous run,was told by shop to run 10w 50 but with the way the oil system works may not be letting full flow thru cooler with oil being to thick,could this be possible?
Im running stock plates,hydraulic line with motual 10w 50 in clutch with 14 /46 gearing(just hit redline at end of eastern creek straight)
The 1100 currently has 126 rw hp with 65pd torque not great but happy being standard but the power curve is just awesome over the 750.
P.s 86 gixxer ill get some pics up for you soon,cheers.
Old 07-22-2010, 09:08 PM   #6
shmokica
Save water, ride an oiler
shmokica's Avatar
Motorcycle: Gixxers
Gees, alot of people were stepping off their bikes, looks like they take it pretty seriously. Braided line will help with feel and control of clutch. Maybe it's just a case of getting use to the extra torque and clutch operation... I know I can thrash my 750 without too much fear of the front coming up high, whereas the 1100 really wants to rotate, and in the 750 package I imagine it's even more prone to this. Running an extra radiator is not a problem, just watch oil pressure and temperatures.
shmokica is offline   Reply With Quote
Old 07-22-2010, 10:12 PM   #7
nightmare596
Motorcycle: 90 GSXR 750 91 GSXR 1100
I've seen a oilcooler race bike with an extra cooler mounted above the rear tire in the tail section.
nightmare596 is offline   Reply With Quote
Old 07-23-2010, 04:10 AM   #8
old gsxr
Superbike Racer
old gsxr's Avatar
good one, kanga good to hear oiler's racing
old gsxr is offline   Reply With Quote
Old 07-23-2010, 07:19 PM   #9
LSC86
LSC86's Avatar
OEM Suzuki clutch parts are hard to beat overall, but I'd run Vesrah products just as well and have good luck with mixing Barnett springs with OEM/Vesrah stuff as well to get just the right feel.
Bottom line is practice and don't be afraid to abuse it off the line, use the clutch to control our wheelie, ride it like you stole it...
Old 07-23-2010, 07:28 PM   #10
Kangaland
Kangaland's Avatar
Here's some pics of it.
And yes they are starting to take this class seriously and as long as i can hand it to the fzr 1000's ill be happy as class ranges from 1982 to 1990 and them fz's are fast.
Think ill try the braided clutch line and try keep it out of the torque range,grow some balls and yeah ride it like i stole it lol.
P.s have you had problems with clutch slipping till bike warms up?could that be the 10w50 im running?
Old 07-24-2010, 06:47 PM   #11
Niels750
Motorcycle: 91' GSXR750(M) just 12000mls, 87' Slabby 750 just 10000mls, 95' Bimota SB6 just 3000mls!
Very nice seeiing these bikes being raced The last pic shows more of an oil burner instead of an oil cooler
Have you tried 10W40 already during races? I personally would stick to the 10W40 unless the oil pressure lights up during race temperatures.
Niels750 is offline   Reply With Quote
Old 07-24-2010, 07:31 PM   #12
FruitLooPs
Motorcycle: 1986 GSXR750
I'd imagine a decent 10-40 would be ok? And I agree with Niels - thats quite a smoke screen dude??
I've never noticed my clutch slipping from cold, but then I don't ride it hard until it's warm
FruitLooPs is offline   Reply With Quote
Old 07-25-2010, 10:47 AM   #13
OLDSKOOLDOILKOOLD
OLDSKOOLDOILKOOLD's Avatar
Motorcycle: oil koold gixxers
we run 10w40 in the 1216 drag bike with no problems! And NO synthetic!! it good for the motor but BAD for the clutches!! In the 1402 bike we run 15w40 rotella....yes diesel oil!!IMHO i would shit can the hydraulic and go with cable run factory clutches and steels you will get much more "feel' of the clutches engaging! and launch the baby at peak horse power at watch the rear tire blaze!!! and be sure to be layin down on the tank!
OLDSKOOLDOILKOOLD is offline   Reply With Quote
Old 07-27-2010, 01:48 AM   #14
86gixxxer
86gixxxer's Avatar
thanks for the fotos. one of my bikes also smokes on downshifts as well. i used to get black flagged, but they know me now. need to get the engine a rebuild, but still runs great.
thanks for the 38mm carb comments; i am going to try them out. fwiw: factory pro runs 147.5 mikuni main jets without the airbox for the 749.
i highly recommend mikuni RS carbs! i have a set of RS 36mm with 130 main jets and they ROCK! instant throttle response!
i also run synthetic rotella diesel oil with good results. i forgot the weight, but 15/40 or 15/50 sounds about right.
good to see these bikes on the track!
Old 07-27-2010, 10:46 AM   #15
LSC86
LSC86's Avatar
"And yes they are starting to take this class seriously and as long as i can hand it to the fzr 1000's ill be happy as class ranges from 1982 to 1990 and them fz's are fast."
FRZ-1000 and fast brings one name to mind for sure here in the midwest USA, Fritz Kling- wicked fast rider and ballz fast bike. Some of the best local racing for sure pitted him against Steve Patterson and his big GSXR-1100 at Grattan & IRP in the early 1990s....
We ran 20w50 Kendal in our modded oil pumper race bikes, have used Rotella in many HD builds too.
Nice to see 'em still being ridden in anger!
Got Oil?
Old 07-27-2010, 04:32 PM   #16
Kangaland
Kangaland's Avatar
Sorry guys the smoke from the bike is from a previuosly blown motor useing that same pipe filled of brocken piston and oil from a valve dropping.
Is a cable set up for the clutch easy to get?
Ive been told to go a 4 into 2 into 1 exhaust system to use the great torque these have instead of 4 into 1<im unsure as Yoshi woulda made one if so.
Sorry about the poor pics as im getting ready for a race this weekend,ill get some pics up later this week with all the little shrouds and peaces i have made and fitted,I.e carby shroud,headstem shroud for cooling under tank ect..
Thanks guys your help has been appreciated as we are currently the fastest racing oil cooled gixxer in Oz and just need that little bit more to hand it to them other smelly bikes of the late 80's, espeacilly the yamahahahaha FZ1000.
Old 07-27-2010, 05:30 PM   #17
LSC86
LSC86's Avatar
Cable conversion is straight forward, believe it is in the 'sticky' files and also on the oldskoolsuzuki site. Well worth the effort, especially on a race bike.
From my 7/11 experience, the newer (probably post 1995) Yosh systems outperformed the early build Yosh stuff both in feel and on the dyno. Had good luck with Hindle/Sudco as well. Probably depends more on the tracks you race as I'd imagine peak power would be just as good as some midrange from a 4/2/1 setup, although the 4/2/1 generally tucks under the engine better for additional clearance.
Got Oil?
Old 07-27-2010, 05:44 PM   #18
Mat123
Mat123's Avatar
Motorcycle: GSX-R 7/11 90'
Hey.. Talking about racing on the old oilcooled machines, i just wanted to show some pics of my brother and me, racing the old bikes on a track, they seemed to take the "abuse" allright. But it's hard work to throw these old machines around the track, also the fairings seemes to hit the pavement a lot if one don't hangout a bit..
Knutstorp and Anderstorp in Sweden last year. It's me on the red/white and custom paint(neither of the plastic is for the road), and my brother on the Blue/white..
Edit: Sorry, but i cant help you with the problems you have..
GSX-R 7/11...
Mat123 is offline   Reply With Quote
Old 07-28-2010, 11:28 AM   #19
frasermanx
frasermanx's Avatar
Motorcycle: BMW R80st, GSXR 1990 1100, 1986 750
Now preparing my bike for Vintage racing Mosport Aug 13-15. Unfortunately they want me to take off lots of road stuff ... I prefer "clubman" racing.. i.e. riding to the track, racing and riding home. However I guess my times would improve if I had a race fairing, new Ohlins, race goodies -- but spending a lot of $$$ is contrary to my nature. In the 60's I raced a '62 Manx that was new. This GSXR reminds me on the strength of that racing package. We didn't realize in those days how cheap we could race those Manx .. just tires, oil, gas, transport, a motor rebuild every few years !! So I am looking to race the GSXR like the Manx with minimum changes to the stock package. I find that careful preparation goes a long way to good results at racetrack, moreso than racer bits that eat up the budget.
Thanks for the tips on this forum
Rotella oil sounds good
frasermanx is offline   Reply With Quote
Old 07-28-2010, 01:11 PM   #20
Outsider V6,V7
Motorcycle: 1986 GSXR Limited, 1986 GSXR 7/11, 1986 GSXR 7/12, 1987 AHRMA 750, 1994 CBR 900RR, 1976 XT 500, 1998 WR 400, 2002, 2002 XR 100,1989 GSXR1100
I race WERA vintage 6 and 7 in the states on 7/11's. I have two 86 750 framed 1100's and run the hydraulic clutch. The only time I've experienced any symptoms of what you described is when I used a barnett clutch and springs. I've found that the stock clutch plates and springs provide the best feel and last the longest so I quit trying to save a couple of bucks and only use these. My smaller 1100 is a 1052 base with 1127 crank and slingshot cams it makes 135 hp on the dyno. My big motor is an 1127 bored 1216 ported with web cams and heavy springs. Stock compression and runs on pump 93 octane and puts out 158 at the rear with 89.2 ft/lbs of torque from 5800-9200 rpm. I raced in 100 degree weather last weekend and when I got back to my pits I shot the motor with a heat gun and it was at 288 degrees F. I also run the curved radiator and only use Klotz 10w40 as this was recommended by the cam manufacturer. What temperatures are you getting when you get in the pits and has the additional radiator dropped the temp.
Outsider V6,V7 is offline   Reply With Quote
