my 99 gsxr-750 has charging problems : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > GSX-R600 / GSX-R750 General forum
Old 06-15-2010, 07:25 PM   #1
cketcham
Basically what happened is that I tried starting my bike and it acted like the battery was dead. I decided to try to jump start it by connecting it to a car (the car was off). it started ok, but when we disconnected the jumper cables my bike died. Figuring the charging system was probably broken since I didn't do anything else that might have caused the battery to drain, I tried letting the battery sit connected to the car battery for a few minutes. it gave me enough charge to get to a bike shop.
they told me I need a new battery, stator and regulator. and wanted to charge me a ridiculous amount, so I got the battery, had them charge it, and was able to ride back to my apartment.
I did a load test and it didn't look like any voltage was going to the battery at 5000 rpm. The shop said the alternator wasn't outputting anything too, so I believe that the stator needs to be replaced. but how can I tell if I need to replace the rectifier too?
tldr; I am pretty sure I need a new stator for my bike. How can I tell if I need a new rectifier? is it true that if the stator goes bad then the rectifier goes bad too?
thanks
cketcham is offline   Reply With Quote Quick reply to this message
Old 11-11-2010, 10:46 AM   #2
cketcham
Re: my 99 gsxr-750 has charging problems
for anyone who is interested in knowing what I did to get my bike fixed.
I replaced the battery and the reg/rec and it now works fine. I'm not sure if the shop people were totally talking out of their asses when they said I needed to replace everything since I performed a test before I changed anything that made me believe I needed to replace the reg/rec, I performed the same test after I replaced it, got the same result, except the battery charges now.
Old 11-11-2010, 10:50 AM   #3
THE SRADIATOR
THE SRADIATOR's Avatar
Motorcycle: THE SRADIATOR
You're a few rpm's behind the power curve on this one!
We've been diagnosing and fixing this problem for years now.
You may still have some wiring harness issues as a bad regulator sometimes cooks the harness as well.
Time will tell...
THE SRADIATOR is offline   Reply With Quote Quick reply to this message
Old 11-11-2010, 11:49 AM   #4
john kinzell
Motorcycle: gsxr 1000
stator is charred, what else do i need?
read this thread..
john kinzell is offline   Reply With Quote Quick reply to this message
Old 11-11-2010, 11:57 AM   #5
cketcham
actually the wiring harness had been removed previously and the reg/rec was directly soldered to the bike. I took out the old one, soldered in the new one and I haven't had a problem for 6 months. so hopefully things are good.
Search this Thread:
Advanced Search
