broke my chain, : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 05-29-2010, 02:26 PM   #1
piester
piester's Avatar
Motorcycle: 1998 GSXR 7/10
broke my chain,
and along with it went that rod that depresses the clutch. now i have half of it in the hole it goes in. any tips on how to get it out?
piester is offline   Reply With Quote Quick reply to this message
Old 05-29-2010, 02:38 PM   #2
THE SRADIATOR
THE SRADIATOR's Avatar
Motorcycle: THE SRADIATOR
Re: broke my chain,
You can try 3 things...
1-Get a Ouija board and perform a seance.
2-Tweezers thru the seal to grip whats left.
3-Remove the clutch cover and push the broken part back out. (remember there are 2 push rods in there!)
Did it shear off any of the motors bosses for the cover?
THE SRADIATOR is offline   Reply With Quote Quick reply to this message
Old 05-29-2010, 06:41 PM   #3
GreenDayFreakRct
GreenDayFreakRct's Avatar
Motorcycle: 98 SRAD 600(Sold) 2001 TL1000R
Re: broke my chain,
Kinda Dejavu isnt it? Least my chain did not break lol
Using the knowledge of the SRADIATOR I took the clutch cover off and used a giant screwdriver to push the broken Push Rod out. None of my tweezers could get it
Nothing else broke when your chain snapped? I would assume this was when you were riding? The pumps and everything are okay?
GreenDayFreakRct is offline   Reply With Quote Quick reply to this message
Old 05-29-2010, 09:25 PM   #4
THE SRADIATOR
Re: broke my chain,
Strange days indeed!
Old 05-30-2010, 11:01 PM   #5
piester
piester's Avatar
Re: broke my chain,
well tomorrow i will be able to dig into her and see if anything else is damaged. i looked over my clymer manual about how in depth this is going to be. all i have to do it swap water pumps from my old motor to this one. take the clutch cover off and take the preasure plate lifter off. tap out whats left of the broken clutch pushrod. slide the new one in and button her back up. i did notice that the mounting boss for the primary cover that is by the pushrob is gone. it looks like there are threads down in there still. i have the piece of the mounting boss that broke off. what should i do? i could try to weld it back on. i could jb weld it back on. i could get a longer bolt and drill the threads out of the broken off piece and use it as a spacer. what do you guys suggest? also, since i am in there looking at the clutch i see that there are 2 srings pushed up against eachother. would i get more bite if i threw a 3rd spring in there? ummm. oh and i have a brand new 530 non oring chain that i got for another bike. im gonna be putting that on to get the bike to a place to have them put a new chain on with one of those rivvet style master links. anyone see a problem with this? it looks to be the same widtch as my 525 oring chain. thanks guys.
oh and sradiator sorry i havnt called you back yet. things have been kind of hectick here lately.
1998 GSXR 7/10, pretty much stock
build thread: http://www.customfighters.com/forums...ad.php?t=42171
Last edited by piester; 05-30-2010 at 11:09 PM. Reason: forgot something and didnt wanna make another post
Old 05-31-2010, 12:38 AM   #6
THE SRADIATOR
Re: broke my chain,
"I could get a longer bolt and drill the threads out of the broken off piece and use it as a spacer."
I was thinking the very same thing!
Just be careful not to pierce the engine cases with that longer bolt or you will have an oil leak that you will have to seal.
Old 05-31-2010, 08:49 AM   #7
piester
piester's Avatar
Re: broke my chain,
Yeah. I planned on seeing how deep it would go before I pu her together
Old 05-31-2010, 09:08 AM   #8
KryptonBulbs
Motorcycle: 03 R1
Re: broke my chain,
Originally Posted by piester View Post
None of my tweezers could get it... ...Yeah. I planned on seeing how deep it would go
KryptonBulbs is offline   Reply With Quote Quick reply to this message
Old 05-31-2010, 09:15 AM   #9
TT750
Motorcycle: 99 750 (sold), 98 tlr (in progress), 07 f650 dakar (daily driver)
Re: broke my chain,
wonder if he got it all in, balls and all... i really don't see how a chain could just break.... and if the chain was that bad off then the sprockets can't be to shit hot eighter..
TT750 is offline   Reply With Quote Quick reply to this message
Old 05-31-2010, 10:06 AM   #10
piester
piester's Avatar
Re: broke my chain,
Chain and sprockets were brand new. Chain snapped at the master link. I believe the side plate wasn't on properly. Shit happens
Old 05-31-2010, 11:11 AM   #11
TT750
Re: broke my chain,
ah cool shit happens. was it a rivited master or a clip??
Old 05-31-2010, 11:39 AM   #12
THE SRADIATOR
Re: broke my chain,
Gotta use the rivet tool (ASSuming it was rivet type)!
Some folks try and peen the link ends and it's anyone's guess if it will hold or not?
Not saying you did just a heads up for those who have taken a short cut!
Many folks don't trust the clip type but i personally have never had a problem with them.
I have seen them safety wired and one guy used a small aluminum strip, folded over between clip and plate as a safety measure.
Old 05-31-2010, 12:24 PM   #13
piester
piester's Avatar
Re: broke my chain,
it was a clip link. its baffling. oh well. i just fished out the pieces of the clutch pushrod and put everythng back together on that side. taking a break right now as its about 120 degrees in my shed. next up is swapping out my water pump and fabricating a mount for my primary cover. replumbing the cooling system, chain, and riding the piss out of her.
Old 05-31-2010, 04:24 PM   #14
Dencho
Dencho's Avatar
Motorcycle: 1998 GSX-R 750 SRAD (SOLD)
Re: broke my chain,
Dencho is offline   Reply With Quote Quick reply to this message
Old 05-31-2010, 07:49 PM   #15
TT750
Re: broke my chain,
silly ? did the clip come right off or was it still attached to one part of the chain
Old 06-01-2010, 09:05 AM   #16
Lean With It
Re: broke my chain,
while you may not have a problem - personally I wouldn't run different pitch sizes.
Lean With It is offline   Reply With Quote Quick reply to this message
Old 06-01-2010, 09:21 AM   #17
TheGeek
Stupid. Who's with me?
TheGeek's Avatar
Motorcycle: Anniversary Edition 600 & Million Edition 1000
Re: broke my chain,
Try a magnet? Some of the magnet retrieval tools are about the same size and are pretty strong. And they're cheaper than a clutch cover gasket.
TheGeek is offline   Reply With Quote Quick reply to this message
Old 06-01-2010, 03:01 PM   #18
piester
piester's Avatar
Re: broke my chain,
already got the clutch pushrod out, the clutch cover gasket came off perfectly and sealed right back up. as far as the chain goes its really just to get me to the shop that is gonna put my new chain on. all i have left to do now is put my exhaust and radiator back on. plumb the cooling. fill her up and throw the bodywork back on..
Search this Thread:
Advanced Search
