GSXR 1000 Issues in JR Comp Dragster : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > GSX-R1000 General Forum > 01-02 GSX-R1000
Old 05-17-2010, 06:15 PM   #1
JC 5330
We have a 01-02 GSXR 1000 set up in my sons JR Comp Dragster...its 100% stock except for the slyder clutch. We have ran it for over a year with no issues but now...
If you raise the RPM over lets say 5K when the engine trys to return to idle it will drop way down in the 800 RPM range and start to black smoke and sputter for 5 or so seconds then it clears up and will come back to idle.
Its also way "Fat" or rich when I do this, we have never had this issue and I have changed what I can such as fuel, fuel filter, plugs and checked the Fuel PSI ( 43 psi)
Can anyone give me some advice on what to check...injectors, sensors, etc ??
Thanks Tony
JC 5330 is offline   Reply With Quote Quick reply to this message
Old 05-17-2010, 08:35 PM   #2
mathews
mathews's Avatar
Re: GSXR 1000 Issues in JR Comp Dragster
Check the TPS.Throttle position sensor
mathews is offline   Reply With Quote Quick reply to this message
Old 05-20-2010, 03:48 PM   #3
JC 5330
I belive it is the TPS...Thanks
Does 1.1 OHM's @ 1300 RPM sound right for the closed setting
and 4.3 OHM's for WOT ?? we dont have the stock dash or guages so I have to do this with an OHM metter
Old 05-23-2010, 06:02 AM   #4
gixxer1100 turbo
A couple of days ago we fixed a 01 1000 wich had the same symptoms..
After checking the manual we found out that it should have 1.1 closed and 4.3 open
the only problem was that it was not reacting right when closing the throttle...it also wasn't calibrated right (to be seen in the dash)
After fitting a new one and calibrating it,all problems were solved...
Since you haven't got a dash;
when I had to calibrate my secondary TPS it had to be 500 ohm exactly or else it would throw a errorcode..
maybe this also works for the TPS itself
http://www.bugmanweb.com/gsxr/gsxrfiles/c28stps.pdf
gixxer1100 turbo is offline   Reply With Quote Quick reply to this message
Old 05-23-2010, 10:09 AM   #5
jaykb2006
jaykb2006's Avatar
Motorcycle: K5 GSXR 600
Got any pics of this jr dragster ? sounds like a badass toy
jaykb2006 is offline   Reply With Quote Quick reply to this message
Search this Thread:
Advanced Search
