Interchangeable parts : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > GSX-R600 / GSX-R750 General forum > 01-03 600 and 00-03 750
Old 05-04-2010, 01:26 PM   #1
demons
demons's Avatar
Motorcycle: KTM SM
I've been searching for some replacement parts for my bike, and to find info on some of my upgrades. Thought I'd compile a list of some of the things I have found out, to help others searching. Please correct anything wrong in my list or add other things. Maybe we could make a sticky?
In general:
00-03 750 is all the same. (some electronics are different)
01-03 600
01-02 1000.
750 and 1000 clipons are compatable.
Windscreen / rear seat:
00-03 750's
01-03 600's
01-02 1000's are all interchangeable
Fairings:
all fairing stays are compatable from same gen.
gsxr 600 and 750 are interchangeable from 2001-2003
gsxr 1000 from 2001-2002
PS: The side fairings from a 1000 are not really interchangable with other models.. everything else is.
Front fender:
01-03 600, 00-03 750, 01-02 1000 are the same fender.
04-05 600/750, 03-04 1000 are the same fender but won't fit the above models without modifying the rear fender mounts.
06-07 600/750, 05-08 1000 are the same fender and will bolt straight up to the list directly above (the previous generation) and will need the modification as above to fit the first gen K series.[/LIST]
Wheels:
600 01-05 - 17x5.5
750 00-05 - 17x5.5 / 17x6.0
all interchange
Rear wheel:
1000 01-04 - 17x6.0 should also fit a 00-03 750
SRAD rear wheel - 17x5.5 (needs sprocket, sprocket carrier and all the wheel spacers too.)
05 GSXR1000, 06 600/750 and onwards rims are lighter with thinner spokes.
Rear shock interchange ability:
600 2001-2003
750 2000-2003
1000 2001-2004 (a little bit higher?)
600/750 04/05 (7mm higher)
Exhaust:
Bolt on:
2001-2003 600
2000-2003 750
2001-2004 1000
04-05 gsxr 600-750
Are all the exact same 4 bolt pattern.
Headers:
01-06 1000 headers will fit.
you have to buy the same year pipe as you do headers.
05-06 headers are the most popular bc of the m4 gp slip on.
Rear rotors:
01-08 have the SAME REAR ROTORS
Engine:
In the 750 the 1000 motor will bolt right up with the exception of the top right front motor mount. They do sell brackets that allow you a bolton or you can have a fab shop make some for you. You will need to buy a 1000 motor kit (harness, cdi, speedo, throttle body, radiator, oil cooler etc)
Swingarm:
2000-03 750
2001-02 1000
2001-02 600
These are interchangeable, but som
96-99, 00-03, 04-05 have the same in the front pivot section, but the length is different (but not much).
03 1000 on my 600 and it fit perfect, but need the rear caliper and mount...
Tail:
04-05 will fit with modifications.
Front forks:
00-03 750 forks and brakes. its cheapest, easiest and the better setup.
04 +750/600 or 05 + 1000 Better, more expensive.
demons is offline   Reply With Quote
Old 05-08-2010, 04:11 AM   #2
ZGT
Motorcycle: beat up 02 750
Re: Interchangeable parts
http://www.babbittsonline.com/pages/...d/default.aspx this site tells you what all bikes can interchange parts
ZGT is offline   Reply With Quote
Old 05-08-2010, 04:37 AM   #3
mig1289
mig1289's Avatar
Motorcycle: 2001 GSX-R 1000
great write up bud. this will help a lot of people out!
mig1289 is offline   Reply With Quote
Old 05-08-2010, 07:06 AM   #4
DD1
Can I interchange the calipers off a 2001 1000 6 piston to my 2001 750 4 piston?
DD1 is offline   Reply With Quote
Old 05-14-2010, 01:26 PM   #5
devin g.
Motorcycle: K4 GSXR 750
For the bolt ons, If i order a micron high mount exhaust for a 01-02 1000, it'll fit on my 03 gsxr 600?
devin g. is offline   Reply With Quote
Old 05-14-2010, 02:25 PM   #6
kosmo
kosmo's Avatar
Motorcycle: 02 1000 02 600
the 06 07 600/750 front nose fairrring doesnt quite interchange i have 07-750 forks on my 02-600 with an 02 nose.... the front 2 bolts line up but the back does not
kosmo is offline   Reply With Quote
Old 05-14-2010, 02:27 PM   #7
kosmo
kosmo's Avatar
great right up would have saved me alot of time if i had this when i built this bike
Old 05-15-2010, 07:58 AM   #8
demons
demons's Avatar
Motorcycle: KTM SM
Seems that way
Kosmo, thanks
Old 05-23-2010, 08:32 PM   #9
mig1289
mig1289's Avatar
Hey would the Stock header from a k2 600 fit and work on a k5 600?
Old 05-24-2010, 05:47 AM   #10
demons
demons's Avatar
Motorcycle: KTM SM
I think so, do a quick search in this forum, I think it also applies for 600 and 750. Let me know if you find out, and I'll update the first post
Old 05-29-2010, 05:51 AM   #11
Monroe731
Monroe731's Avatar
Motorcycle: K3 750
Does anyone know if there is anything out there with interchangeable parts with other bikes?? I know on my Triumph I replaced the lame 2 pot front brakes with some 3 pot off of a Busa I believe.
Monroe731 is offline   Reply With Quote
Old 06-09-2010, 08:11 PM   #12
Gixxerdude750
So will a 2001 Gixxer 1000 Front wheel/tire work on my 2001 Gixxer 750 as a direct replacement? Thanks!!
Gixxerdude750 is offline   Reply With Quote
Old 06-12-2010, 07:53 PM   #13
wayn0829
does anybody know if i can change my 03 750 frmae for a 600 frame or a 1k? what would be easier?
wayn0829 is offline   Reply With Quote
Old 07-28-2010, 10:48 PM   #14
babe
babe's Avatar
Motorcycle: 2001 GSXR 600, 07 Ninja 250
Thanks for the info. Helps alot. What about an 05 or 06 stock slipper clutch on an 01 600?
babe is offline   Reply With Quote
Old 07-29-2010, 11:14 AM   #15
Chugs
Let's ride!
Chugs's Avatar
Not a direct swap, but with a few modifications it may just work. I've been working on it. Not progressing too well.
Chugs is offline   Reply With Quote
Old 08-03-2010, 11:28 AM   #16
uktech1
I've got a '02 GSXR750 that needs an engine and a '05 engine. Anyone know if it will fit?
uktech1 is offline   Reply With Quote
Old 08-10-2010, 08:36 AM   #17
DaJesta
Motorcycle: Jesse
Thanks for the info above... its helpful!
My motor on my 03 600 seized and I am looking to do a motor swap on it... I would love to put a 750 motor in my 600 frame, but what will I have to change? Above it doesn't mention anything about the 600-750 swap.
Thanks
DaJesta is offline   Reply With Quote
Old 08-11-2010, 02:15 AM   #18
demons
demons's Avatar
Motorcycle: KTM SM
A 600 to 750 engine swap requires new engine mounts (can be bought from Hybridracing) and a complete engine (with speedo and some more parts).
Seach the forum and you will find lots of info.
Old 08-11-2010, 04:12 AM   #19
NCzYoung1
What options do I have in changing the fuel pump on my 2001 gsxr 600? The price drop is significant from an k1 to a k4. Would a k4 gsxr 600 fuel pump fit on my k1?
NCzYoung1 is offline   Reply With Quote
Old 09-10-2010, 11:41 PM   #20
Y2KGSXR750
Motorcycle: GSXR 750
Anybody know about the gas cap's? Common thing.. I have one, can't get the lock out to change it over to my new lock...going to try and pick it..
I need a new gas cap on my 2000.. and wondering what one to go with.. 03-02-01, or 05-06?
Y2KGSXR750 is offline   Reply With Quote
