M1 4T to rotella T6!!!!!!!!!!!! : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Tech Forums > Oil and Lubrication
Old 04-18-2010, 10:12 PM   #1
Jerzey
Motorcycle: 2006 gsxr 600
so i changed my oil today from M1 to the t6 and OMG!!!!! this stuff is great my tranny shifts so crisp motor is quieter and over all im very happy! only thing is i came back and checked the oil level and u can see its already brown!. mybe thats because i didnt change the filter this time. i do a filter every other change. i do 3-4k oil changes. this is my 4th oil change since ive owned the bike.btw wix oil filter!!!
Jerzey is offline   Reply With Quote
Old 04-19-2010, 10:42 AM   #2
6spd
6spd's Avatar
Re: M1 4T to rotella T6!!!!!!!!!!!!
Because rotella is not made for motorcycle transmissions, how do you know it won't cause problems. Car oils today have all types of extra crap in it that's suppose to be good for engines, NOT moto transmissions.
6spd is offline   Reply With Quote
Old 04-19-2010, 11:21 AM   #3
Jerzey
rotella is rated for JASO MA safe for wet clutches says so right on the bottle
Old 04-21-2010, 11:46 AM   #4
gggplaya
gggplaya's Avatar
Motorcycle: 2006 GSXR 600
do they make it in 10W-40?
gggplaya is offline   Reply With Quote
Old 04-21-2010, 05:11 PM   #5
Jerzey
nope
Old 04-21-2010, 05:33 PM   #6
AndrewM
Superbike Champ
AndrewM's Avatar
Motorcycle: 06 750
I use it also in the truck and bike
Oil's are almost arbitrary, just change them regularly
AndrewM is offline   Reply With Quote
Old 04-24-2010, 11:12 PM   #7
kmysiak
kmysiak's Avatar
Motorcycle: K8 600
I used it and my bike didnt like it at all. Temps were 5 degrees higher and tranny was super clunky. I've switch to amsoil 20w-50 and everything is butter. Just shows every bike is different.
kmysiak is offline   Reply With Quote
Old 04-25-2010, 01:58 PM   #8
BumpStick
BumpStick's Avatar
Motorcycle: 06 GSXR 1K
I'm about to start using Rotella dino oil in mine, its the same Jaso Ma and they have it in 10w-40.
BumpStick is offline   Reply With Quote
Old 04-29-2010, 04:55 PM   #9
Fox Fader
Fox Fader's Avatar
Motorcycle: 01 Aprilia RST 1000 Futura, 06 GSX-R 1000 St. Fighter
You may want to educate yourself on oil, especially Rotella.
Fox Fader is offline   Reply With Quote
Old 05-18-2010, 07:26 AM   #10
Saturn8829
Saturn8829's Avatar
Motorcycle: K1 GSX-R 750 w/1000 engine
Question Re: M1 4T to rotella T6!!!!!!!!!!!!
i have been using the basic rotella 15w40 and love it trans does shift smoother. i have a friend that drag races underground. he said that it is a good oil but i should try mobile one delvac. said it works the best for him and that he was more impressed with it then rotella
Saturn8829 is offline   Reply With Quote
Old 10-31-2011, 10:28 PM   #11
hh3130
hh3130's Avatar
Motorcycle: 2002 GSXR
That's great, now I can use the same oil in my gixxer, excavator, truck, car,etc.
hh3130 is offline   Reply With Quote
Old 11-11-2011, 01:15 PM   #12
bfunk_101
Motorcycle: 2003 gsxr 1000
I did this same sway to the T6. Only reason was to do the synthetic oil for $30. just make sure oil has same additives required by motorcycle oils like Jerzy says. (T6 is compatible!)
bfunk_101 is offline   Reply With Quote
