Brake caliper rebuild : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 04-04-2010, 03:11 PM   #1
mortenmorfar
Motorcycle: 1999 GSX-R 600
Hi, so the season has started here in Denmark, so I have been working on the bike to get it ready, but I'm having some trouble with my front brakes.
The pin that holds the brake pads was seized in one of the calipers, and of course I broke it, so I had the Suzuki dealer drill it out, and in the process he poped the pistons out, and they had a fair amount of rust on the top, so I replaced all the pistons.
So I have put new seals and pistons in the calipers, and it all looks good, but I can't get all the air out of the braking system, I have tried 3 times now, but it's still not right, so could there be a leak by one of the pistons that allow air to enter but still keep the fluid inside ?
a girl who wears big underpants, has big stuff under her pants - Al Bundy
mortenmorfar is offline   Reply With Quote Quick reply to this message
Old 04-04-2010, 03:29 PM   #2
OmegaSoul498
Superbike Racer
Motorcycle: 1999 GSX-R 750 (stolen) K3 Seven Fiddy Blue/White-soon to be track
Re: Brake caliper rebuild
Are you still getting air at the caliper bleeders?
OmegaSoul498 is offline   Reply With Quote Quick reply to this message
Old 04-04-2010, 03:33 PM   #3
mortenmorfar
nope they are clean, but maybe there is an air pocket that doesn't want to move, I have tried zip tying the brake lever down over night, a little bit of air came out, but it's still not braking like it should.
Old 04-04-2010, 03:45 PM   #4
OmegaSoul498
Superbike Racer
I had the same problem after my rebuild. The MC was my culprit. Yours may have an air bubble in it and need bleeding. The way I did mine was to cover up everything wanted paint to remain on and then loosen the master cylinder banjo bolt. Then I squeezed the lever, looking for bubbles in the fluid (of which there were plenty). Then while holding the lever, I tightened the banjo bolt, and then released the lever. I gave the master cylinder a few taps and then repeated the process until I had no bubbles. After that, I rebled at the calipers just to be sure, and I've had no problems since.
I heard that the vacuum bleeder was the best method, but that one worked pretty well for me.
Old 04-04-2010, 03:52 PM   #5
mortenmorfar
Okay I will give that a try tomorrow
Old 04-05-2010, 02:11 AM   #6
86gixxxer
86gixxxer's Avatar
Motorcycle: first gen 750's & a '99 750
good advice: yeah, try to bleed it from the top banjo bolt. make sure to use plenty of towels/rags to absorb brake fluid. this method works for me.
86gixxxer is offline   Reply With Quote Quick reply to this message
Old 04-05-2010, 05:46 AM   #7
mortenmorfar
Stupid air :/, I think one of the bleeder screws are bad, but it could just be some leftover fluid that's coming out.
I will try and replace them both when the shops open tomorrow
Old 04-06-2010, 02:12 PM   #8
mortenmorfar
I think there are some air bubbles in the hose going to the left caliper, I tried to connect only one caliper at a time, and it was fine.. so I will wait for my mityvac and see if it can fix it
Old 04-06-2010, 04:06 PM   #9
zeusmiffy
zeusmiffy's Avatar
Motorcycle: 99 srad 600
hi my dad showed me a trick he's been a mechanic all his life he's now 60. start with the caliper furthest away from the master cylinder loosen the bleed nipple press the brake lever then when you go to let the brake lever out put your thumb over the nipple to create a seal this acts as a vacume drawing the fluid and air out of the system repeat this a few times filling the resevoir as you go and bingo some nice firm brakes dads you gotta love um
zeusmiffy is offline   Reply With Quote Quick reply to this message
Old 04-14-2010, 06:46 AM   #10
mortenmorfar
Mityvac sucks big time :/
I think I have a problem with my master cylinder, I have used over 1L of brake fluid, and it's still not firm like it used to be.
Old 04-14-2010, 07:46 AM   #11
OmegaSoul498
Superbike Racer
Clicky
Sometimes when you start fixing stuff, wear items will go ahead and give up the ghost. A cylinder rebuild is a good way to eliminate worn/worn out seals as the culprit, and it's cheap and relatively easy. If you rebuild, make sure you clean your cylinder bore thoroughly. Something I noticed when I took my brakes apart was that there was what looked like crystallized brake fluid gumming up the works. Also wet your seals with fresh brake fluid before you reassemble the master cylinder, and try to get as much air as possible out of the MC before you start bleeding at the calipers. Then bleed at the calipers, and come back to the MC to get those last little bubbles. A trick that may also help is gently tapping the MC with a screwdriver while you're bleeding it to dislodge any stubborn bubbles.
Old 06-08-2010, 12:24 PM   #12
mortenmorfar
Okay so I gave the bike to a dealer so he could look at it, turns out my spongy brakes was because my forks are bent, so the calipers doesn't seat right on the discs.
So I hope the forks I got from ebay are straight, otherwise it's going to get expensive :/
Search this Thread:
Advanced Search
Yamaha Motorcycles Victory Gunner Forum Honda Vultus Forum HD LiveWire Forum Ninja H2 Forum Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
