hey all i just picked up a 00 gsxr6 when I start the bike it idles at 4500 or so ... after a while it will fall off to 1200 or so but its after the bike gets to temp... I pulled the tank off to check the carbs and there are two solenoid valves on the bottom of the carbs they did not have the electrical plugs connected to them . now I have not had time to try the bike yet.... but I was wondering if anyone else has had similar problems
any ideas would help
thanks
the choke really has no effect until the last little bit . i can ge the bike to idle fine after it arms up but if i give it any throttle the rmp will hang for 20 -30 seconds. its almost as if there is a vacuum leak somewhere but i have yet to find one
thanks for the help
says it in the directions that come with the jet kit, prolly has something to do with not regulating the air/fuel flow - which would render the jet kit pointless this is my ass talking
Motorcycle: 1999 GSX-R 750 (stolen) K3 Seven Fiddy Blue/White-soon to be track
Re: 2000gsxr 600 SRAD idle's high
I'm just curious. This is my first transition from one carb to four, so I'm full of questions.
